Question about Maytag PYE2300AY Electric Dryer
We have a three year old Maytag electric dryer. It has started a high pitched whine. Still drys and tumbles. Venting works well. Suggestions?
    Sergeant:
    Champion:
  • 289 Answers
Maytag dryer's are also amana dryer's.that has a main bearing in the back of the unit.this is the first indacation that your main bearing is going bad,.do a service call now and save your dryer.
Posted on Nov 16, 2009
Hi. My Neptune dryer was not sounding as I remembered it. A higher pitch than usual while it was drying clothes. Then I noticed it was reluctant to start when pushing the "start" button, with...
burning smell is because the drum is not rolling and the motor is trying to turn, hopefully it did not damage the motor: more then likely it the drum rollers/glides, might want to check the idler arm here is a website that will help. depending on fast you need your dryer a good and cheap place to buy parts is on eBay, of course they can be purchased locally, Good Luck Tim:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Jan 10, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My dryer has a high pitched squeek that gets louder as it drys, sounds like its coming from the back but I can't access it. What can I do to fix it ?
ROLLERS OR MOTOR PULLY GOING BAD, YOU CAN NOT ACCESS THIS FROM THE BACK YOU HAVE TO TAKE THE MACHINE APART FROM THE FRONT
Nov 07, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Dryer won't heat up! It tumbles fine, but no heat! My Maytag dryer is only two or three years old!
This problem is normally caused by a faulty thermostat and or heating element. Test and replace if needed
Sep 23, 2009 | Maytag Dryers
Dryer makes a whining noise when drying
The belt is not the problem but more likely the drum rollers or drum bearing will need to be replaced.
Jan 29, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag performa dryer doesn't fully heat
A couple of suggestions. STOP, be sure the gas it turned off before disconnecting the line. Move it to an open area and check all venting. A good cleaning makes a huge difference. I believe your problem to be the heating coil is on it's way out, "works sometime". Write down the Make, Model, Seriel Number & Year of MFG...someone may ask for it..Check Your local appliance store for price & availablity Easy to replace on most model dryers.
When reattaching the gas line, be safe not to overtighten the coupler. A safe test for leaks is NOT a match... a drop or two of dishsoap around the fittings will bubble if it is not sealed. Good Luck
Jan 02, 2009 | Maytag Performa PAV3200
High pitch squeal
IT IS MORE THAN LIKELY A STUCK DRUM ROLLER OR IDLER PULLEY. I HAVE SEEN IN WORST CASE SCENARIOS WHERE IT HAS BEEN THE MOTOR ITSELF WHEN SUBJUCTED TO LOTS OF LINT AND DUST FROM PLUGGED VENTING. I WOULD CHECK THE FIRST TWO AS THEY ARE THE MOST COMMON. DO NOT OIL THEM.
Dec 28, 2008 | Maytag MDE2600 Electric Dryer
Maytag SE1000 Dryer - high pitch buzz, then total non-start
Often, after a power surge that exceeds the parameters of surge suppression devices on the circuit board, the unit will do this. You will more than likely have a failed control board now and will need to replace it.
Dec 03, 2008 | Dryers
Samsung SlimFit 30" high pitch whining noise
I have had the same high pitch tone problem for several months after about 20 minutes of use. It is so bad it's rendered the TV almost unwatchable. I contacted a repair place from Samsung's website. I was told that is likely the flyback transformer. I don't know what it is, but it sounds cool like a flux capacitator. I was told it would be about $100 to fix. However, I have had very little luck getting the repair shop to order the part and do the work.
Sep 04, 2008 | Samsung TXR3079 TV
Maytag PYE2300AY Electric Dryer Logo
134 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
