Question about 791XV The 791XV is a 2-way Security and Remote Start system. Th
Remote will not start car and doors do not lock after starting car
    Problem Solver:
  • 11 Answers
Make sure that your black/white wire is grounded.Check youur wiring at your ING harness.
Posted on Nov 16, 2009
Reprogram remote car starter
I have experience with mine that I have to press lock twice then hit the remote start or it will not start.
Jul 04, 2017 | Hyundai Cars & Trucks
I have a prestige remote start in a 03 Chevy S-10 Recently put in new battery and now have problems with the remote. When I use the remote the truck turns over 3x then the doors locks (never starts truck)...
Computer probably thinks someone is trying to steal your vehicle. All remote starts usually require that the door locks must be locked before the engine starts. Make sure the doors are locked before starting.
Feb 07, 2018 | Cars & Trucks
Having trouble with keyless remote control on 1993 lexus es300. Replace battery on remote- still not openning doors. Help Please!
Try reporgraming it
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Press any button on remote for a minimum of 1 second.
System should now lock and unlock doors once.
6. Close and open drivers door.
7. Press any button on remote for a minimum of 1 second. System should now lock and
unlock doors. Once to confirm programming, twice to indicate programming failed.
8. Repeat steps 5, 6 and 7 for additional remotes.
Jan 02, 2013 | Cars & Trucks
Remote start work but door will not unlock or lock!
Do the doors unlock when the remote starter is not running? If so, then you to connect to a different set of door lock wires.I usually connect to the factory alarm and disarm wires in the driver kick panel. They are blue for arm and pink for disarm. You test them by turning the key in the drivers door.
Aug 18, 2012 | 991 Responder LC3 SST Security/Remote...
Remote auto start will not start a 2007 chevy suburban ltz
If the keyless remote works to unlock and lock the doors, then it should start the engine. In order to use this feature, you have to lock the doors (make sure that all door lock by pushing the lock button twice) with the remote by pushing the lock button, then you hold down the start button on the remote for 2 to 3 seconds and it should start. You can start and stop the engine with the remote 2 or 3 times with the remote, after that it will no longer let you use the remote start until you physically get in the car and start the engine to reset the system. Check your driver information center options using the steering wheel controls. There is an option to enable and disable the remote start option.
May 10, 2010 | Cars & Trucks
My valet remote control RPN491 Starts vehiclr and unlocks doors but will not lock doors do I need to reprogram remoteto unlock doors?
Ok you said "unlock doors' but you said it already unlocks the doors. This remote should lock and unlock door on same button, if you are describing the 2 button remote. If it is not then it could be alot of things. Does the alarm lock itself? Does the alarm lock the door when you turn on the ignition? More info is really needed. Like what veh and what model alarm.
Sep 11, 2009 | DEI Valet Keyless Entry System
Viper works but remote start and keyless entry does not
On the remote start part, it might be as simple as relearning the tach. To do this, crank the car with the key, press and hold the valet switch until the led lights and stays solid now release.Try the remote start. Need to know what kind of car to comment on doorlocks.
Jun 14, 2009 | Viper Security and Remote Start System...
Need the steps to programme the remote
Remote Programming Instructions
1. Driver's door OPEN and unlocked, all other doors closed and locked.
2. Insert YOUR key in ignition, DO NOT TURN, remove key.
3. Using the MANUAL lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
4. Shut door.
5. Open door.
6. Using the lock/unlock button ON THE DRIVERS DOOR, slowly press lock and unlock 5 times (count the lock 5 times and unlock 5 times).
7. With the door open insert your key into the ignition, turn to on position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second,
release. The locks should cycle once. If not, start over and go slower.
10. Close the door. Open the door. Press the lock button on the remote. The locks should cycle. Close the door. Press the lock button on the remote, the doors should lock. Press again and the doors should unlock.
Jun 02, 2009 | 1995 Lexus LS 400
Remote start
first make sure you have the keyless start entry setup. if u do then you need to lock the door with the transmitter after you lock the door press the start button and hold it down until it starts. It usually takes three or four seconds.
Mar 16, 2009 | 2005 Pontiac G6
Remote starter does not work but will unlock and lock doors.
I have a 2003 sierra and my remote starter would not work, it would lock and unlock only, checked out this site found the solution, tried it and in two seconds i solved the problem, Just press the lock button and the start button and viola it works again, thanks for all your help , GGGreat site glad i found it John
Dec 08, 2008 | 2005 Pontiac G6
791XV The  791XV is a 2-way Security and Remote Start system. Th Logo
150 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
Tre Elkins
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
