Question about Jabra Bluetooth Headset with Adjustable Ear-Hook Headset
Jabra OTE3 won't pair with Verzon LG phone. How do you get the blue tooth in discovery mode?
  • 638 Answers
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
Posted on Jan 05, 2010
Need operating instructions for Jabra BT 2080 headset
ok i hope that you are trying to connect the bt device to a phone or game system or computer,the first thing you need to do is turn the power on to what you are connecting the blue tooth device to.your phone computer or game system,next you will have to put your blue tooth device into discovery mode,now most manufactures of blue tooth devices use the power button for this feature,when you turn the power on to your device keep holding down the power button for 6 to 10 seconds this will put your device into discovery mode,usually a light will remain on,then you can search or add new device from what it is you are connecting to,it will ask you for a pin or pairing code,now most manufactures of blue tooth devices use a factory 4 digit pin pairing code,they are as follows,0000,1234,9999,or 1111 enter the code and your device should pair and work with what it is you are pairring it to .i hope this helps
Feb 26, 2011 | Jabra BT2080 Bluetooth Headset
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Feb 25, 2011 | LG HBM-710 Wireless Headset
HTC evo will not pair w my jabra stone, says incorrect pass code, how do I re enter the pass code?
By putting the blue tooth device in discovery mode it will reset it then your will have to enter the manufactures factory pin pairing code,Most blue tooth manufactures use a 4 digit pin pairing code,they are as follows0000,1234,1111,or 9999 this should be the code you are looking for i hope this helps
Feb 22, 2011 | Jabra BT350 Bluetooth Headset Headset
Unable to put phone into pair mode motorola hs810 to a i phone 3g
Most blue tooth device manufactures use the power button to set your device to discovery mode,first you must turn the power to on for your blue tooth from your phone menu,then most manufactures use the power button to put the blue toooth device into discovery mode,by holding the power button down when you turn your device on holding it for 6 to 10 seconds,usually a solid light appears on your blue tooth device,it is now in discovery mode,on your phone menu there should be an add new or search devices,once you've clicked that it should discover your blue tooth device,then you will need a pin or pairing code,Most manufactures use a factory 4 digit pin pairing code the y are as follows 0000,1234,1111,or 9999, if you have done the steps correctly the menu will say connect,press conect and you should be connected..i hope this helps
Feb 22, 2011 | Motorola Mobility HS810 Consumer Headset
How to reset a bluetooth i.tech i.oval 303
Most manufactures have a factory 4 digit pin that once you have put it to discovery mode,usually blue tooth manufactures use the power button to reset the discovery mode,by holding the power button down while turning it on keep holding the power button for 6 to 10 seconds a light should appear on your device,thus the device is in discovery mode,once your blue tooth device has been put into discovery mode you should go into your phone menu and turn the blue tooth power on,then it should have an add new or seach for device,click that and it should pair with the phone,you will need a 4 digit pin pairing code,Most blue tooth manufatures use factory pairing pins they are as follows 0000,1234,1111,or 9999 try them in that order,i hope this helps you
Feb 22, 2011 | Itech i.Tech i.Oval 303 Bluetooth Headset
My lg prime will not pair with my jabra bt3030 bluetooth headset
you have to make sure your blue tooth device is in discovery mode most devices you just hold the power button for 6 to 10 seconds when turning it on,if you have it in discovery mode they will pair and you will be asked for a pin or pairing code ,most blue tooth manufactures use a 4 digit code they are as follows 0000,1234,1111 or 9999 i hope this helps
Feb 21, 2011 | Jabra BT3030 Bluetooth Headset
It is not being detected by my new nokia C7
you must make sure you have your blue tooth device turn on to discovery mode most blue tooth devices you just hold the power button for 6 to 10 second when turning on the device,once it is in discovery mode your phone should find it,then you will need a 4 digit pn or pairng code,most blue tooth manufactures use a 4 digit code they are as follows 0000,1234,1111 or 9999 i hope this helps
Feb 21, 2011 | Jabra Radio Communications
I turned my headset on and now the blue light is on and I cannot turn it off.
your blue tooth device is in discovery mode you must pair it with your phone again,it just you held the power button down to long turning it on ,most blue tooth manufactures use the power button for the discovery mode,in case you don't have the pairing pin code again most blue toooth manufactures use a 4 digit factory code,they are as follows 0000,1234,1111 or 9999 i hope this helps.And if your blue tooth drained the battery and you need to charge it before you proceed ,to put it into discovery mode hold the power button down for 6 to 10 seconds when turning your blue tooth device on.i hope this helps
Feb 18, 2011 | LG HBM-760 Bluetooth Headset
I hav a jabra bluetooth....type ote3 and i lost my directions for connecting it to my phone. i hav a samsung gravity phone i went to settings under bluetooth and turned it on and searched for devices but...
1. Put the headset in pairing mode and make sure that the headset is on. To do this: Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra headset
(Follow your phone’s instruction guide to do this)
3. Once your phone locates the headset, it will ask you for a code to pair with it, the code for jabra headsets is usually 0000
Sep 02, 2010 | Cell Phones
Jabra Bluetooth Headset with Adjustable Ear-Hook Headset Logo
2,647 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
