Question about HP 920 Plain Paper Fax
Fax history is it possible for me to receive a history of faxes from july 2007
    Novelist:
  • 158 Answers
Depending on your model, You need to press the MENU button, or check if there is a REPORTS button. For either case, scroll through the display until you come to the PRINT REPORTS mode. It may be worded differently on your machine, but what you are looking for is the FAX ACTIVITY report. You can also get printouts of TRANSMISSON OR RECEIVE ACTIVITY, and also CALLER ID, iIf you encounter a command called PROTOCAL DUMP, this also is a printout of fax activity.. Whether your activity report goes back to july 2007 is unknown. Normally an activity report shows a certain number of activities per printout, say the last 50 fax operations. It is not based on a certain timefrane.
Posted on Aug 07, 2008
Why cant I send a fax
I share a informative links please visit and check it your error options.
Read More... Cannot send fax using all in one printer and Interpreting Error Codes in Fax Communication Error or Fax History... and If any more Help.. HP Printer Support
Thanks,
Sep 08, 2014 | Office Equipment & Supplies
Can't fax because the fax log is full and want to know how to erase
HI...............
How to Delete a Fax Log History on an HP????
The HP printers come with the HP Solution Center software. The software allows you to adjust settings, transfer images, send a fax and make copies right from the control center instead of using the printer control panel. When you make a fax, receive a fax or block faxes, a log is kept in the HP Solution Center. You can use the software to view faxes and delete a fax log history.
Difficulty:Moderately Easy Instructions
    • 1 Open the HP Solution Center by clicking the "Start" button. Navigate the mouse to "Programs" and click on "HP" to open the drop-down box. Click on "HP Solution Center." If you have the "HP Solution Center" icon on the desktop, you can click the icon to open the software.
    • 2 Click on "Settings." A drop-down box will open up. Click "Fax Settings and Setup," which will open another drop-down box. Click "Fax Log," which will open the fax log window.
    • 3 Read the "Sent Log," which is the first tab on the window. The information will tell you the date, duration of the fax, name of the fax, fax number, how many pages and the status.
    • 4 Click on the first fax in the log to highlight it. Click "Delete" at the bottom of the window to delete the fax. Continue this step for each fax until every fax you want deleted is gone.
    • 5 Click on "Received Log" and delete each fax. Click on "Blocked Faxes" and perform the steps again to delete each of the faxes in this log that you want to delete.
HOPE THIS SOLUTION WILL HELPFUL TO YOUGOOD LUCK.................
Sep 24, 2011 | HP Officejet 6500 Wireless All-in-One...
There is a fax failure when receiving a fax. The activity report said REMOTE FAX ERROR. What have I not set correctly? We have never set up the fax before so have no previous history. We are using a...
If you have specifically requested a "double" ring pattern for your fax from Telus, then you have the right setting, otherwise, select the Any ring pattern to avoid fax transmission failure.
For more troubleshooting steps, please refer to this Lexmark article about Main Contributing Factors to a Fax Receive Failure on Inkjet All-In-Ones.
Sep 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Does the C6100 have fax history printout capablity?
Hi
Yes, Photosmart C6100 series does have the capability to print the fax history i.e. known as fax log, but its is only possible if you have not performed any resets recentlyt
How to print that?
Please follow the following steps to print it
1. Press the setup button on the printer
2. Go to the option that says 'Print Report'
3. Press Ok on print report
4. Scroll down using the arrow keys and go to fax log
5. Press Ok on fax log
6. This would print the history
All the best!!
Oct 29, 2010 | HP Photosmart C6100 All-In-One Printer
Fax series 920, can receive but not send faxes, error code 344*
Do you have or are you sending a fax to a party that has a DIGITAL PHONE SERVICE?
Jun 04, 2009 | HP 920 Plain Paper Fax
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
Printing report on received faxes
Fax machines usually only store the last 50 transactions
Aug 05, 2008 | Brother MFC-8220 Fax
Panafax UF-333
Can't change mode TEL to FAX.
Apr 18, 2008 | Panasonic Panafax UF-333 Plain Paper...
Sending Faxes
When the last page of your document has been sent successfully, the machine beeps and returns to Standby mode. When something goes wrong while sending your fax, an error message appears on the display. If you receive an error message, press Stop/Clear to clear the message and try to send the document again. You can set your machine to print a confirmation report automatically each time sending a fax is completed. If you get the error message write it down it should always supply an error message if the fax did not go through.
Jul 25, 2007 | Samsung SCX 4521F All-In-One Laser Printer
HP 920 Plain Paper Fax Logo
284 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
