Question about Craftsman Garden
Turn switch on, it does not run. It ran fine when I boxed it up last season. Its electric
  • 279 Answers
Work the switch a number of times. Sometimes when we leave tools a long time unused, they get something on the switches.. Just work it bit and it may be okay. Good luck...Lee
Posted on Nov 16, 2009
2009 Honda Shadow Aero ran fine yesterday, stopped for about 3 hours would not start last night. Turned over would not start, help?
sounds like a CDI issue!
could also be an ignition switch or run/stop switch issue.
is the bike lacking any power when running?
Maybe stator pick-up coil as well.
Have electrical components checked at the dealer.
May 24, 2014 | 2004 Honda VT 750 Shadow Aero
Stalls when engaging first gear
Check clutch switch may be stuck bike thinks you are putting in gear without pulling clutch
Mar 11, 2014 | Suzuki DR 350 S Motorcycles
Electrical problem?
I had the same problem with my exmark. I found that there was a yellow wire that has a deans connector that plugs in around the backside area of the key ignition. that wire vibrated off. check that, it may fix it. good luck!..
Dec 07, 2013 | Husqvarna EZ4824 24 hp 48" Zero Turn Lawn...
I have a 10-year old Carrier Gas pack Model #48GS024060301. Turned on the heat for the first time this season and the unit did not turn on. I was able to turn on the house circulation fan and since it...
If the induction motor ain't going I would look for a blown 3 amp (purple) fuse on the control board. If that was good I would check if any of the roll out switches were tripped. If a rollout switch was tripped check or air restrictions somewhere.
Oct 17, 2010 | Heating & Cooling
Do you have a pre-start checklist?
Pre-start checklist?
I assume the heater ran fine last season. If so, assume it will run fine this season. Simply remove the top cover, check the combustion chamber area for signs of visitors such as mice, wasps, dirt dobbers, etc. Remove debris.
We always drain the old fuel & start fresh.
Replace the top cover and fire it up. If it runs fine then leave it alone. If it won't continue to run troubleshoot and find the problem.
Troubleshoot a spark plug type heater http://www.reddyparts.com/SP_tips.htm
Troubleshoot a hot surface ignitor type heater http://www.reddyparts.com/HSI_tips.htm
Sep 23, 2010 | Reddy Heater-170,000 BTU Kerosene Deluxe
Pool pump shuts off after a couple of minutes and seems to be hot
You problem could be one of several things. First, pumps have a thermal protection switch that shuts the pump down when overheated. You could have rust after only one season that overheats the pump and it shuts down. The switch could be bad. There could be an electrical issue when running it on a long cord of the wrong gauge. Plug the pump into an outlet without extension cord and see if it makes a difference.
Apr 18, 2010 | Pool & Spa
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Bike seems as if its running on 2 cyclinders
r all the mufflers the same heat--make sure carbs r ok n gas is gitten to um--inspec plug wires n the rest of ign for wear and bad contacts--with an ohmeter n repair manual varius test can be done-sayonnara
Feb 02, 2010 | 1985 Honda CB 700 SC Nighthawk
Garden Logo
44 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
