Question about GPS
Loaded maps on 76csx had several errors...now just powers down, screen fades as if batteries are bad but they're not??
  • Richard Graves Nov 16, 2009
    unit wont stay on unless you remove chip (2GB)
    tried resetting w/chip in...doesnt work
    dont want to lose wavepoints...
  • 19,396 Answers
Hi, the card with the chip, more commonly called flash memory card is probably faulty and it is causing the unit to turn off by itself.
If the unit is starting without a card, then you will need to test your Sat Nav using a different memory card.
If you have maps and data on this card you can recover them using a computer , then attempt transferring them onto the new card.
You use this using a card reader that can be connected to a computer. Some computer may have built in card reader.Click here for an example: Multiple USB 2.0 Memory Card Reader Writer for SD T-Flash.
If the computer is not reading then card, then the content may be lost. In that case you can recover and download again the maps contacting Garmin.
If your Garmin is turning off even with a new card, then it is faulty, probably because of a short in card reader slot.
In that case the unit must be taken apart by a technician to be repaired.
A good thing to do would be calling Garmin at the number listed on the owners manual, checking conditions for repair, ensuring that maps on memory card can be recovered, and seeing if you are entitled to a replacement or how much repair will cost.
Regards.
Please do not forget to leave us feedback.
Posted on Nov 16, 2009
    President:
  • 1,462 Answers
Try doing a reset of your device.
Hold Enter and Page while turning it on. You will lose all your waypoints, tracks, routes you have stored so back it up to a computer first, before performing a reset..
If the problem persist after resetting, try removing the micro SD card and turning in the Device, if the device performs better, try to format the SD card andusing it..Tryit with a good SD card..
If you recently updated to the 3.90 firmware that could be part of your problem. Many users have went back to 3.70. Also if you have a class 4 or above sd card that could depending on which brand could be your problem..Try performing a software update to new version 4.0
We updater wont downgrade the version, here is the link to download the older version
http://www.gpsinformation.org/perry/7x_series/gpsmap76cs/GPSMAP76CSx_370.exe
Any one of the above solution should solve your issue..
Please leave me comment, if you need further assistance
Thanks for using FixYa!
Rnj VINODKUMAR
  • Vinod Kumar
    Vinod Kumar Nov 16, 2009
    Your memory card chip is corrupted so you get the device shut down...
    Please buy a new chip. copy all the content from your old chip to new chip and use the new chip...
    This should solve your issue..
    If you feel my solution as useful later, please accept this solution
    Thanks
My Garmin GPSmap 76CSx will begin to start up, but as soon as you release the power button the screen fades away.
This problem can occur when the map file is corrupted or can't be read. Try putting your sd card in a reader and deleting the GMAPSUPP file (in the GARMIN folder) and fitting it back in your device. Then reload the map from Mapsource onto your handheld.
Jan 14, 2013 | Garmin GPS
76csx I CAN'T ACCES THE MAPS ON THE GPS OR THE CARD
Features on the phone device makes compatibility to media attainable among several innovative functionalities. The phone in question least has an extensive capacity to display the entire global mapping program. For example, multimedia resources either as maps, picture grams require an expansive device components to capture display for experiences. The mobile phone in question as manufactures default only provides telecommunication resources with feature observation of media impressions. Acquiring an alternate device that has an extensive expectation would provide the requested impressions. For example, the entire global position device would provide experiences as manufacturers default. Also, computers either as desktop or notebooks provide the entire experience of telephony among several features of multimedia impressions similar to global position system programs. Computers however are multifunction's devices, also versatile that captures displays and manipulates resources.
Feb 25, 2011 | Garmin GPSMAP 76CSx Handheld GPS GPS...
I have a Garmin 76CSx that freezes on start-up screen, no buttons have any effect. Only way to switch off is to pull batteries out.
I had the same thing. Seemed to be a faulty SANDISK 2GB MicroSD card. When I pulled it out, the unit worked again.
Sep 30, 2009 | Garmin GPSMAP 76CSx GPS Receiver
Switches itself off when I try to turn it on
possibly a bad battery try changing it To test its ability to load correctly connect to a power source and load maps. if it appears tow ork Ok then you need a battery change as when off the power souce there is insufficeient power to run the screen
Jun 28, 2009 | GPS
While down loading maps the 76CSX just quit. The batteries are good. When I turn on the GPS it starts then fads away like there is no power, yet I have tryed 2 sets of new batteries.
It sounds like a corrupted upload. Reset the unit and retry the upload.
Usually reset is done by pushing page and enter while powering up
Apr 22, 2009 | Garmin GPSMAP 76 GPS Receiver
Garmin Nuvi 260W shuts off before it fully loads maps
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Mar 19, 2009 | Garmin nuvi 260W GPS Receiver
Problem downloading maps to my 76csx
With unit off, press and hold ENTER and PAGE while powering on to perform a master reset.
Doing a master reset will erase and data in the device and restore it to factory defaults. So if you have any waypoints/tracks/routes you may want to back them up first.
You may want to update your mapsoure software first and see if that helps the issue. If not reinstall the software.
oh and double check your micro SD card to make sure its not damaged and is inserted all the way in.
Jan 18, 2009 | Garmin GPSMAP 76 GPS Receiver
Topo maps a mess of meaningless lines
Sorry for late reply. You need to select an area on your topo map prior to downloading it. For example, if you plan to go to Algonquin Bice Lake (access point 4), then you need to select the map around the area (starting from) Kearney upto the Magnetawan Lake and beyond. Mark waypoints from the put-in to the campsite on Bice Lake (best to compare of the topo and Algonquin canoeing map). Then you can click Transfer, click Send to Device (GPS 76cs should appear) to download it. On the GPS, enter the Find Waypoint button and you should be able to see those waypoints. Good luck for your next trip.
Aug 03, 2008 | Garmin GPS 76 GPS Receiver
Tide station
please verify if firmware of your receiver is up to date.
the newest version of GPSMAP 76CSx is Ver. 3.60, realised on Feb 18, 2008
if not, make upgrade either by WebUpdater application or download it direct from www.garmin.com
enter: www.garmin.com
then click "On the Trail" -> Mapping Handhelds -> GPSMap 76CSx -> quick links: Updates&Downloads -> Unit Software
regards
frankie
May 19, 2008 | Garmin GPSMAP 76Cx GPS Receiver
GPS Logo
27 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
