Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
I have a sony wega red light flashes three time
    Top Expert:
  • Sony Master
  • 14,553 Answers
In this model 3 blinks usually means "lamp door not properly closed".
You need to get at the door and examine it--some of these had problems where the door warps from the heat from the lamp.
On the back side of the door is a small plastic peg--when the door is in place it engages a plastic lever and switch---it is there to prevent the set from being operated with the door removed.
If you find the door is warped you can prove if this is your problem by engaging the lever with something not metal---plastic or even a wood match stick--
With the lever engaged turn the set on--if it works you need to replace the door--I can look up a part number for it if you need it---quickest way to get one is on Ebay.
If the set works with the door removed, DO NOT PUT THE LARGE FRONT PLASTIC GRILL IN FRONT OF IT BACK IF YOU OPERATE THE SET THIS WAY--IT CAN BE MELTED.
IT IS DANGEROUS TO OPERATE THE SET AS THE LAMP WILL BE VISABLE AND IS VERY BRIGHT.
LET ME KNOW WHAT HAPPENS.
IF this helped you, rate this solution as I do this here for free.
SD TECH
Posted on Nov 16, 2009
Sony wega wont turn on
see previous answer give for same question posted just a little different.
Mar 19, 2012 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony grand wega kdf 60wf655 will not start up. red light blinks three times. lamp replaced a year ago.
If the POWER/STANDBY indicator flashes three times, the lamp cover may not be attached securely. Review the lamp-changing instructions in your owner's manual, and make sure that the lamp cover is securely attached.
Jul 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony tv kf-42we610 tv will not come on and red light blinks three times
Three flashes usually means the lamp cover is not attached securely and the TV has gone into a "stand by" mode, recheck that the lamp,lamp door, and front panel is securely attached.
Good Luck !
Feb 07, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
I have a 60' sony wega r60xbr1 i just had a new light engine installed last night the tv was never turned on afterwards . I turned it on the screen come on shut off imediatly the red led flashes 4 times...
LOOK IF YOURS IS A SONY I had a sony grand wega 60 inch with the same problem as many tv turns on shuts off the red led FLASHED 4 TIMES. it is a heating issue if one of the three fans inside are not turning when the tv is on even on the first few seconds of turning it on the tv will send a fault code of four flashes . Then the tv shuts off so it wont burn its self up or damage the optical block. all with this same problem of 4 flashes take a flashlite and make sure your fans are turning if not that is your 4 flash problem. I hope this helps someone and if it does i have done my job .
Dec 29, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Flashing light
The LED used in most tv are dual color led,some have two lead, some have three. try to find the same size and replace it.
Jun 20, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Replaced the bulb, now the tv will turn off and flash red light
3 times red light flash shows that lamp cover is not seated / fixed properly.
Please check lamp cover and fix it securely.
Dec 11, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony Trinitron KV-32FS12
i think your tv had a lose contact or crack on board
Oct 18, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Wega
Please count light flashing again. Light flash time is "0.3 Sec" and there would be pause (light Off time) for "3 Sec". Start counting after pause to next pause.
May 31, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
1,243 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
