Question about Ideazon MERC Gaming Keyboard (DHMERC)
Dongle won't connect
I bought a gigaware usa-b to serial connector to connect my smartRF04EB board to my dell laptop. However the dongle won't connect and I'm not sure how to get it to. All of the hardware is connected properly and the driver for the gigaware connector has been installed.
I have a CC2430EM module attached to the smartboard. I'm using the USB connector to power the smartboard rather than a 9V battery.
How Can I connect my wireless Logitech mouse to my laptop?
You should search for small wireless USB dongle (receiver) and insert it into USB port of your laptop. You bought The dongle with mouse. Sometimes it is placed inside mouse on bottom side. See picture.
A mouse driver is usually installed automatically in a while after the dongle is connected to PC.
Logitech M310 Silver 1 Wheel USB RF Wireless Mouse Model 910 001675
Jan 18, 2016 | Logitech Cordless Mouse
Lg dongle won't connect need help I have all lg electrical equipt
some dongles are made by only to connect to the desktop or the laptops only. better thing is ask the service provider who sold that dongle.
Sep 02, 2012 | LG ANWF100 Wireless dongle
What hardware is needed to use a dell m5040 for dialup internet service
You could use a dongle adapter for wireless dial up service.
However if you prefer to have a landline connection for Broadband then you will need a telephone connector.
Jul 12, 2012 | Computers & Internet
Bought dongle E173 works on dell computer Xpworks on laptop windows 7 but wont install on PC Specialist windows XP why ????
Hi there! If the E173 worked with your windows 7 then that means the E173 is working properly, try to check first if the PC specialist windows XP computer can detect the dongle if not then try to use a different USB port now if is detected but won't install try to find it in the drive go to my computer then look for the removable disk or the e173 then manually install it but if after trying different USB ports and the dongle is still not being detected then check if it is compatible with that computer or you can try to use another USB device to check if the ports are working properly.
Hope this helps!
Sep 01, 2011 | Microsoft Computers & Internet
I was just given a 180e embroidery machine ( I am a total novice) and I am not sure how to connect the dongle and get designs that are in my computer. Thank you so much cat
I am not exactly sure of this particular model. But the dongle should just plug into the computers port on the back of the computer.
Jan 19, 2011 | Bernina Artista 180
I just bought a toshiba laptop and i forgot my pascode
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
Or ring up local Toshiba Agent prove it is your, a receipt etc, and they will give you a special code to unlock.
Mar 23, 2010 | Toshiba Satellite L505-S5966 Notebook
My toshiba tecra8000 laptop displays toshiba logo for 1 second and then it displays password.Bios batteries have been removed.code no of flash eprom on mother board is unknown tome.If I get the code no of...
Mar 09, 2010 | Toshiba Tecra 8000 Notebook
CK 3200 LS severe background noise heard by other party - Can download software update ok and pair bluetooth laptops ok, but when I try to send download to Parrot on some computers I get message no dongle,...
get your laptop and car ready then call parrot techinical, they will talk you through it, you need to select the correct serial port. it also depends on what type of donlge you are using.
Nov 13, 2009 | Parrot 3200 Ls Color Handsfree Bluetooth...
Passcode for the Logitech cordless presenter
Brand new GigaWare mouse cannot copy and paste; why?
Apr 21, 2009 | Logitech Cordless Presenter Mouse
Aspire
To connect to a basic wireless network (WAN) you need to have a 802.11g (or n) network adapter, I would assume that this is located inside the laptop already (99% of new laptops come with a wireless adapter installed). You should not need a dongle.
Dec 08, 2008 | Acer Aspire 5315 Notebook
Open Questions:
keyboard stop responding in game Intermittently I have a ideazon merc stealth keyboard. I use it for gaming and have not had any issues with it until recently. The problem started about 2 weeks ago when I launched the game Americas army. When I launched the game I didnt notice any thing unusual. But when I started to play the game my keyboard's backlighting began to flash and flicker. When the keyboard began to flash and flicker I lost all controll of my character. It did this intermittedly and without a logical pattern. The amount of time the keys went out was anywhere from 1 second to 3 seconds ata time and the interval is any where from 3 times every second to 10 times in a few seconds and continuosly repeating but in no logical pattern. I closed americas army and played sevweral other games with no problems. I then prceeded to launch call of duty 5 world at war. It did the same thing in the multiplayer but not in the single player or co-op modes. It has been doing this for 2 weeks now and it only does it when I play americas army online or call of duty 5 world at war in multiplayer mode. No other games seem to reproduce this issue. I have uninstalled and cleaned my programs and drivers folder and reinstalled the latest drivrs and software and have updated everything. I have disabled the MM drivers for it and that seemed to help for about 2 games. I have unistalled my .net frameworks and reinstalled them. and I tried with the .net framework uninstalled. I have reformatted my hard drive and have a clean install. I have even gone so far as to uninstall the sp3 service pack. I dont know what to do next. My pc specs are as follows Field Value Computer Operating System Microsoft Windows XP Professional OS Service Pack Service Pack 3 DirectX 4.09.00.0904 (DirectX 9.0c) Computer Name disguised User Name disguised Motherboard CPU Type Intel Pentium 4 630, 3377 MHz (15 x 225) Motherboard Name Unknown Motherboard Chipset Unknown System Memory 2048 MB BIOS Type Award (09/25/08) Communication Port Communications Port (COM1) Communication Port Printer Port (LPT1) Display Video Adapter NVIDIA GeForce 8600 GT (1024 MB) Video Adapter NVIDIA GeForce 8600 GT (1024 MB) Monitor Plug and Play Monitor [NoDB] (MPF4150066323) Monitor HP 2009 Series Wide LCD Monitor [NoDB] (CNC9080TTZ) Multimedia Audio Adapter Line 6 TonePort DI-S Audio Adapter Realtek HD Audio 2nd output Audio Adapter Realtek HD Audio output Storage IDE Controller NVIDIA nForce 430/410 Serial ATA Controller IDE Controller NVIDIA nForce 430/410 Serial ATA Controller IDE Controller Standard Dual Channel PCI IDE Controller SCSI/RAID Controller JMicron JMB36X Controller Disk Drive EPSON Stylus Storage USB Device Disk Drive ST3250410AS (232 GB, IDE) Optical Drive HL-DT-ST DVD-ROM GDR8164B Optical Drive SONY DVD RW DRU-830A SMART Hard Disks Status OK Partitions C: (NTFS) 119232 MB (64045 MB free) D: (NTFS) 119240 MB (77019 MB free) Total Size 232.9 GB (137.8 GB free) Input Keyboard HID Keyboard Device Mouse HID-compliant mouse Network Network Adapter NVIDIA nForce 10/100/1000 Mbps Ethernet (192.168.1.101) Peripherals Printer Adobe PDF Printer EPSON Stylus CX6000 Series Printer Microsoft XPS Document Writer Printer Send To OneNote 2007 USB1 Controller Standard OpenHCD USB Host Controller [NoDB] USB2 Controller Standard Enhanced PCI to USB Host Controller [NoDB] USB Device EPSON CX5900/CX6000/DX6000 USB Device Generic USB Hub USB Device Ideazon Merc Stealth MM USB Human Interface Device USB Device Ideazon Merc Stealth USB Human Interface Device USB Device Line 6 TonePort DI-S USB Device Logitech Mic (Ultra Vision) USB Device Logitech QuickCam Ultra Vision USB Device Logitech USB Camera (Ultra Vision) USB Device Microsoft Fingerprint Reader USB Device USB Composite Device USB Device USB Composite Device USB Device USB Composite Device USB Device USB Human Interface Device USB Device USB Human Interface Device USB Device USB Mass Storage Device USB Device USB Printing Support Field Value CPU Properties CPU Type Intel Pentium 4 630 CPU Alias Prescott-2M CPU Stepping R0 Engineering Sample No CPUID CPU Name Intel(R) Pentium(R) 4 CPU 3.00GHz CPUID Revision 00000F4Ah CPU Speed CPU Clock 3372.84 MHz (original: 3000 MHz, overclock: 12%) CPU Multiplier 15.0x CPU FSB 224.86 MHz (original: 200 MHz, overclock: 12%) CPU Cache L1 Trace Cache 12K Instructions L1 Data Cache 16 KB L2 Cache 2 MB (On-Die, ECC, ATC, Full-Speed) Motherboard Properties Motherboard ID 09/25/2008-C55-MCP51-P5N-ESLI-00 Motherboard Name Unknown BIOS Properties System BIOS Date 09/25/08 Video BIOS Date 03/07/08 Award BIOS Type Phoenix - AwardBIOS v6.00PG Award BIOS Message ASUS P5N-E SLI ACPI BIOS Revision 1301 DMI BIOS Version ASUS P5N-E SLI ACPI BIOS Revision 1301
Jun 02, 2009 | Ideazon MERC Gaming Keyboard (DHMERC)
Computers & Internet Logo
170 people viewed this question
Top Ideazon Computers & Internet Experts
David
David
Joseph Wright
Dayton Computer
Dayton Computer
Are you an Ideazon Computer and Internet Expert? Answer questions, earn points and help others
