Question about Canon BJC 3000 InkJet Printer
Printing problem the printing comes back with breaks in the ink.
  • Lynnbeth Jan 09, 2008
    It happens all the time. The ink cartridge is new. What else could I do?
    Problem Solver:
  • 19 Answers
When was the last time you replaced the cartridge?
Does it happen all the time or just every now and again?
Posted on Jan 09, 2008
  • Douglas Green Jan 09, 2008
    another thing you might want to do is use a little bit of rubbing alchahol on a q-tip and try and clean the print head itself. Won't hurt if you have to replace it anyways.
    President:
  • 4,402 Answers
Replace ink cart if still does it need new print head
  • Cary Farah
    Cary Farah Jan 09, 2008
    replace the print head.
Blank pages printing
Sounds like the printhead is pretty severely dried. As standard cleaning cycles haven't helped I would recommend picking up some LC900 cleaning cartridges from eBay etc. These are cartridges filled/partially filled with cartridge flush and break down ink inside the printer.
Most of them contain a mix of ink and flush and you can carry on printing as usual. Given the severity of the dried/blocked printhead you have I would recommend just running cleaning cycles, but leave 10 minutes or so between cleans to avoid overheating the printhead.
Oct 16, 2012 | Brother MFC-5440CN All-In-One InkJet...
Ink
is it the exact ink replacement or did you have a company refill it ?
Robert
Aug 29, 2008 | Canon PIXMA iP1600 Printer
My Xerox 8550 says 'ink sticks are jammed'. Yet,
This could be a print head problem. If the print head is calling for ink and the sensor is bad the ink melter will continue to melt ink and over flow the print head. In which case the print head need to be replaced.
Also it could be a problem with the ink melter. If it isn't melting the ink it will cause this error.
To get to the ones at the end of the chute I stick a long screwdriver and break it free from the melter.
Harry
Jun 04, 2010 | Xerox Phaser 8560MFP Laser Printer
When printing a document on printer it prints a line and then a solid black line beneath that.
Sounds like a bad ink cartridge. The ink is probably clogged up in the print head where the ink comes out of the cartridge. You should either bring it back to where you purchased it for a replacement, or you can try priming the ink.
To prime the ink:
1. Get a wet paper towel
2. Get a dry paper towel
3. Take the bad ink out of your printer
4. Move the ink back and forth from the wet towel to the dry towel touching the print head (part on cartridge where the ink comes out) to the towel.
5. You should begin to see the ink come out in a higher consistency
This will help unclog any ink stuck in the pores of the print head. If that doesn't work, you may need to get a replacement from where you purchased it.
Hope this helps :)
Apr 30, 2010 | Dell 922 All-In-One InkJet Printer
All-in-one printing half text. breaking words i.e. there are breack in printing
Try running the cartridge cleaning. Most likely one some of the ink jets are clogged. You can also try removing the cartridge and cleaning the ink jets with some alcohol
Mar 14, 2010 | Office Equipment & Supplies
Son returned on Spring Break - claimed printer
Hi there
You say you pulled out the inks but I not to sure but do your printer havd a head under the inks if so take out all the inks again and gave them a good clean and also if it have a head under the inks take this out there may be a little gray leaver there that you pull up and then the head you can pull out if so gave this a good clean as well, and replace all and try again, Good Luck.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 14, 2010 | Canon Pixma MP480 All-In-One InkJet...
Epson 9600 no ink coming out
That happens to me as well I'm using epson R230x pigment ink. At first yellow does'nt come out. and fixing the yellow by pumping it with a solution and putting everything back ALL HEADS ARE NOT PRINTING ANYMORE....
Sep 26, 2009 | Epson Stylus Pro 9600 InkJet Printer
Won't print PRIXMA iP1500 Going through the actions of printing but no ink appear on paper. Deep cleaning done, reset done, new cartridge done, alignment printing done, still no ink.. and it did print a...
If using aftermarket inks you sometimes have to rap them on a paper towel to break an air lock.If you see ink coming out after rapping them try to print again.If nothing comes out you may have a bad print head or purge pump.
Try cleaning the head (without cartridges)in a 10-20% ammonia warm water mixture for 30-45 min.
Completely dry the head before returning it to printer.
Jun 19, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Epson CX3650 printing gaps
Remove ink cartridges one by one and put it back in. If same thing happens, try to do head cleaning and nozzle checks consecutively from the computer.
Start -> Control Panel -> Printers & Faxes (Windows XP) / Printers (Windows Vista) -> Printer Icon (right click) -> Printing Preferences -> Maintenance
You should be able to see nozzle check, click it and follow the prompt. Line patterns that corresponds to the colors of the ink cartridges would be printed. If breaks on the patterns appear, continue with head cleaning. Try to do this about 3 times until all patterns are complete.
Dec 21, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Hi, I haven't used my Canon S330 printer for some months, and when I plugged it in just now, it wouldn't print. I replaced both cartridges, and still no printing. The cartridge moves fairly quickly back...
in the print head there are hundreds of minute holes from where the ink of the cartridge comes out when you remove the head check whether the ink is coming from the holes in the head .if the ink is not coming the head may be dry and if the very less ink is coming then some of the holes are blocked. the ink has to come out from that holes for printing.
thanks.
Sep 18, 2008 | Office Equipment & Supplies
Canon BJC 3000 InkJet Printer Logo
old marine
old marine
