Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Rtc3100c won't run
Rtc3100c installed didn't urn breaker off while i was doing it, where are transformer/fuse @ on trane unit?
    Sergeant:
    Champion:
  • 232 Answers
Depends on the model if its newer its in the electrical control box and its a standard car fuse. if it older then its a twist in OEM with a maroon top on the oustide of the electrical control box ( this is inside the airhandler )
Posted on Nov 16, 2009
  • mac5932002 Nov 16, 2009
    depends on the model if its newer its in the electrical control box and its a standard car fuse. if it older then its a twist in OEM with a maroon top on the oustide of the electrical control box ( this is inside the airhandler )
Possible cause of busted fuse on main breaker of TRANE water chillers?
Most common cause is undersized wire and or breaker. Make sure the unit has sufficient electrical wire size to unit and that it is the only thing on that breaker. Must Be Dedicated Circuit.
Aug 11, 2014 | Heating & Cooling
Trane executive series btd736a100b0
Assuming this is the outdoor unit you are hearing the "click" and then nothing then the most likely cause is no high voltage power to the outdoor unit. Breaker could have tripped or fuses blown.
May 10, 2014 | Heating & Cooling
Had 16 xi Trane heat pump installed 3 years ago. It ran well for the first couple of years. It began to stop heating and would blow cold air only. Have tried both aux heat and reg. heat to run and neither...
That's a complicated system that needs a qualified technician to service it. Lots of people can install them and they run fine, for a few years. Your indoor unit, operating on 2 heat elements, will feel like its blowing cold air even though its heating, just not so well. And not like you are accustomed to. Each element (5kw)=22.7amps, on average. So 3 elements operating should trip a breaker. Its probably been operating on 2 heat element plus the heat pump. And now you have trouble with the heat pump. If you can't TRUST the guys working on your equipment, try someone else. A second opinion. Normally a 3 or 4 ton unit will have 15kw heat installed, heatpump or not. 5 ton, 20kw. If yours is a 3-4ton, cooling, the 100amp(or normally two 60 amp) breaker should have been installed upon equipment change out. If yours is blowing cold all the time, something is wrong with your heatpump. The electric heat inside operates only when the heatpump can't keep up(real cold outside), the heatpump is in defrost(then it's actually in cooling mode), or if you have the tstat in aux/em. heat. Try a local trane dealer? Of a technician with 15-20 yrs under their belt. A trane dealer should have trane tech support also. BIG HELP!!!
Mar 01, 2017 | Haier Energy Star ESA3183 Air Conditioner
My Trane XE1100 air conditioner won't start at all, worked fine one day and the next it wouldn't come on
check breakers in breaker panel,I need more info.is it blowing air inside
Jul 01, 2013 | Heating & Cooling
I have a small house with a outside package unit American standard (Trane) Model# WCM030F100BB, italso says BAYHTRN110A. When I select cold from the off position on the thermostat it immediately pops the...
I would check the outdoor unit, Trane uses "Sump Heaters" on their compressors
and when one fails it will blow fuses at the disconnect or trip breakers.
The sump heater is a small metal pencil sized item at the bottom of the compressor
with something that looks like lamp cord going to it. Also when the start capacitor
fails it will exhibit this symptom. Look at the can shaped items inside the cover
If they are leaking, or bulged this may also be the problem.
(with the breakers off to everything including the inside unit to prevent shorting
the transformer)
These are the most common problems and the parts are less than 20 dollars each.
I service 155 trane units at my properties.
hope this helps.
Mar 19, 2011 | American Standard Heating & Cooling
I have a 24yr old trane hp the outdoor unit has tripped the breaker in unit,showing 12ohm short with 56ohms to ground,I figure that the compressor is shot so IM trying to work on my aux heat.the thermostat...
If this old unit has a outside transformer then you will need to shut off the breaker and take the wires off the compressor and tape them up. Then turn the breaker back on and it should run.
Jan 02, 2010 | Heating & Cooling
I need the full load amp rating of the Trane YHC063A. I have the minimum circuit ampacity, the max fuse and the max circuit breaker already
Look on the rating plate on the unit itself - look for something labled as FLA. If you don't have access to the condensing unit, go to WWW.TRANE.COM and search for your full model number.
Sep 09, 2009 | Heating & Cooling
Trane Air Handler and Trane Thermostat with no power. Please help
First of all put back the jumper wire you remved Rc to Rh and also put the red wire to either one then the white to W, the green to G and the yellow to Y .That is for the thermostat wiring for a not heat pump outdoor unit.Remember this electronic thermostat has a time delay so the unit will take a few minutes to start.All this if the problem is the thermostat.But also when nothing works it could be that the drain line is clogh and some air handlers have a flood switch who shut the unit off if drain is clogh(it could be located in the drain line out of the air handler or inside it on the drain pan.) newer TRANE units have it inside.
Aug 13, 2009 | Heating & Cooling
I want to find the transformer for the 36 volt inside unit. Is it in the inside unit or outside unit .I have no power to the inside unit however the outside unit has power,and the inside unit appears to be...
It's a 24v transformer. Your indoor unit houses the transformer for the outdoor unit. The outdoor has a low voltage (24v) supply running to it to push in the contactor for the outdoor unit to run. If your air handler inside has no power then it will kill your LOW VOLTAGE power to the outdoor unit. You will still have the high voltage power to the outdoor unit. You may have a fuse on the switch for your air handler blown if there is one. On the disconnect switch mounted to your air handler, you will have a door to open and a fuse in there. If not, check your main breaker at the panel. If you don't know what a transformer looks like, you may want to have someone familiar with electrical of HVAC help you. To check the transformer for power, you first need power to your air handler, which you don't have. I would say that is not your problem. I would assume your air conditioner is not running outside, correct? Your problem is the power (HIGH VOLTAGE) to your air handler. Loose wires, blown fuse, tripped breaker etc...
Aug 06, 2009 | Comfort-Aire HMC36AT-1 Air Conditioner
Thermostat wiring
99.99% of the modern residential units use only one transformer to power the 24 volts for both the furnace and the a/c unit. It will be located in the furnace. The outdoor unit will not have its own transformer unless its reeallllly old. Place a small jumper wire between w1 & w2 terminals on the thermostat. (The lux brand is not the professionals choice) (if you have problems replace with a honeywell or white rodgers brand).
Good luck.....
Apr 21, 2009 | Heating & Cooling
Heating & Cooling Logo
59 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
