Question about Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher
Bosch dishwasher model no SGS4002GB
Dishwasher starts any programme with pump working fine and water going in ,however after approx 10 mins the programme stops although the dishwasher continues to make a noise.Any help would be appreciated.
  • Anonymous Mar 23, 2014
    I need to change the current programme.
Check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
Posted on Mar 27, 2008
Dishwasher wont fill up with water
When you start the dishwasher you have probably noticed that it first drains water and is very important to hear that drain pump running all the time or stops after a while? Why?
If the drain pump runs constantly then the fault is in the phase of "drain water" or is activated anti-flood system. Reset point of pressostat is not reached after max. 120secs. Programme stop and can be continued after error remedy by pressing the programme key.
If the pump is running for a while and then stops, then the fault is in phase "fill up water". Switchpoint of pressostat is not reached
after max. 60 secs.
Usually built-in dishwashers has anti-flood system that responds in the event of water in the bottom of the dishwasher. Such a case, find and repair water leaks.
Dado
Aug 06, 2014 | Electrolux 23 in. ESI6104 Built-in...
Stops working part way through programme
It seems it is drain problem and check out your drain hose and drain pump for problems and clean all main motor and pump as much as you could do
Dec 09, 2013 | Siemens 24 in. SE25A266 ExtraKlasse...
CAN I SPEED UP THE PROGRAMME AS I AM CHECKING TO SEE IF WATER WILL BE TAKEN AWAY BY THE PUMP?
Let the unit fill, then open the door and press two button either side of the eco button simultaneously until the end light comes on. This will reset the program and run the pump for approx 1 min.
Mar 14, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
Whirlpool ADG7540 approx 4 years old (maybe a bit older) I have ran diagnositic check and the start light flashes 4 times stops briefly then flashes 4 times again over and over along with a continuous...
Yikes, we have just identified this exact same problem tonight. If you've had any success with fixing it, we would sure appreciate hearing how. Best of luck with your machine
Mar 03, 2011 | Whirlpool 24 in. ADG7540 Built-in...
Shortly after turning my indesit idl530 on a fault code appears
the problem you are getting is a f01 fault,this is water in the base part of the antiflood devise.to check this if you tip the appliance backwards and water comes from the back at the bottom this is the problem,if you do this till it stops and then leave for approx 24hrs to dry out any water that may have gone on to motor,then check by switching on to start a program,if appears to work ok but then goes back to the same fault(draining all the time and light flashing)you will have to remove base and check for leaks.
Jul 04, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Cda dishwasher
green light on right flashing and beeping noise..Problem solved by thowing a few pints of water in the bottom of the dishwasher...must have 'primed' the pump..which must have been the problem; working fine now. David- Crosby
Apr 19, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Programme will not run , starts beeping after 5 minutes into cycle
turn your dishwasher on the first thing it should do is a quick drain then fill after the fill open the door and see how much water is in it hold my rating till we are through
Jan 31, 2008 | Maytag 24 in. MDB5600A Jetclean II...
I have a dishwasher that only works intermitently...
most fault codes are 10, 20,30.........90 not familar with c2. ther is a fault earky on in a prog where if the pressure switch does not retun to empty the prog stops and displays 10 or 30. the pipe leading from the front of the sump to the pressure switch can sag. tieing it up to stop the sag can cure this..
Feb 27, 2007 | AEG 24 in. Favorit 60870M Free-standing...
Bosch 24 in. SGS43C12 Classixx Free-Standing Dishwasher Logo
405 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
