Question about Heavy Machinery
How to take off front hydraulic cylinder cap to
How do you take off front hydraulic cylinder cap to replace the seal on an old didier log splitter? It has a large cap with what looks like a nut on it. I tried to turn it out but a metal piece came out of a slot on the side of the cylinder. The cap can be pushed out with a large screw driver and hammer only one half inch then stops dead.
TURN THE NUT WITH A PIPE WRENCH AND USE A PICK TO PRY THE REST OF THE RETAINER RING OUT OF THE SLOT. (YOU CAN LOOK INTO THIS SLOT A YOU TURN THE NUT, MAKING SURE THAT YOU HAVE ALL OF IT OUT. AFTER THIS IS DONE THE NUT CAN BE TAPPED OR PRIED OUT. I PREFER USING A BRASS PUNCH TO KNOCK IT OUT.
Posted on Jun 16, 2010
I have a 45 ton Grudge Log splitter. the ram works but has no power to split logs.
indicates insufficient pressure from the pump
bypass at the ram/piston seals---seals or scored cylinder
have it checked by a hydraulic specialist
Nov 12, 2016 | Tools & Hardware - Others
Hydraulic oil spewing from fill cap
http://www.northerntool.com/images/downloads/manuals/1114.pdf
Check the assembly and note that the ram returns to its position when you activate it EVEN if you release the valve handle. Also make sure you don't have too much fluid in the reservoir.
Jan 22, 2016 | Northstar Horizontal/Vertical Log Splitter...
How do I change the seal in a 22 ton Huskee log splitter?
Picture of the cylinder my help, I have had different hydraulic cylinders apart. I don't know which one they put on a Huskee.
Feb 27, 2015 | Cars & Trucks
I have a didier wood splitter and the hydraulic need seals. part number is 200889.where can i get the seals. here is my e mail .harleyman5787@hotmail.com
Most companies have a website that offers repair parts . You'll be asked to enter the model number and serial number to be sure to get the correct parts you'll need. Some websites give you a contact number where you can call them directly to order the parts that you want. Google the manufacturer name. That will put you on the right track. Good luck .Hope this helps you.
Feb 05, 2015 | Sewing Machines
Adding hydrolic oil to yardworks 4-ton wood spliter
Replace the Hydraulic oil in the log splitter after
every 150 hours of use. Take following steps to
replace it.
  1. Make sure all moving parts stops and the log splitter is unplugged.
  2. Unscrew Oil Drain Bolt with Dipstick to remove it.
  3. Turn the log splitter on the Support Leg side over an 4 liters capacity container to drain the hydraulic oil off.
  4. Turn the log splitter on the the motor side.
  5. Refill fresh hydraulic oil at the volume as per the hydraulic oil capacity of a particular model indicated in above specifications table.
  6. Clean the surface of Dipstick on the Oil Drain Bolt and put it back into the oil tank while keep the log splitter vertically.
  7. Make sure the level of the refilled oil is just between 2 grooves around the Dipstick.
  8. Clean the Oil Drain Bolt before thread them back. Make sure they are tightened to avoid leakage before place the log splitter horizontally.
Periodically check oil level to ensure it is between
2 grooves around the Dipstick. Upon Lower oil
level, oil refilling is required.
Source:
http://www.qci.net/files/5_Ton_Log_Splitter_-_USE_THIS_MANUAL.pdf
Sep 22, 2013 | Hardware & Accessories
I need a replacement foam air filter element for the Briggs and Stratton engine on a Didier log splitter Model 130202
you need briggs part number 27987
and assume this is a horizontal shaft engine
your local small engine shop should have one
cheers pauly46
Jan 17, 2011 | Garden
Log splitter how to flush hydraulic system
removing hydraulic oil from the system
  • fully extend the cylinder. and shutdown.
  • remove the one end of the hose that is from the rod end of the clylinder.
  • two ways you can go here. either: detach the one end of the hose that is attached to directional control valve and leads to the cap end of the cylinder and place the end in a pale then retract the cylinder by physically forcing the rod back in and all the oil will drain out of the cap end into the pale and the rod end will fill with air.
  • or u could hold the directional valve in the position to let the oil flow back to tank while physically forcing the rod back in. the oil in the cap end will drain to tank and rod end will fill with air.
  • drain the tank of oil.
  • if you wanted to be extra thurough remove the remaining lines and drain the oil out of them.
  • reattach all lines.
  • replace oil filters/strainers. should be one on the return line going to tank. and one on the suction line before the pump. But there may not be a second filter.
  • fill tank with new oil.
  • extend the cylinder using the pump. allowing the air to bleed off the rod side. may chatter at bit while extending. if excessive chatter remove line end to allow the air in the rod side to bleed to atmosphere and continue till fully extended.
  • reattach line. probably a good idea to run a couple cycles.
  • and repeat the entire process for a thurogh flushing.
  • ! note: dont be dissconnecting lines with pressure in them or while the system is running.
  • ! note: be sure to have enough oil in the tank so the pump is not sucking air. this will eventually cause unrepairable damage to pump if sucking air for too long.
  • i just wrote this off the top of my head and ive only worked on industrial hyraulic systems and never on a log splitter before so just keep that in mind. hope it helps
Dec 04, 2009 | Plumbing
WE HAVE A DIDIER WOOD SPLITTER AND NEED REPAIR PARTS. ANY IDEA WHERE TO FIND THEM? THE HANDLE TO RUN THE RAM IS BROKEN. WE HAVE BEEN TOLD THE COMPANY IS OUT OF BUSINESS. MODEL IS C-26A, PART NUMBER IS...
Well , i OWN a modified Didier ; 3pt and is selfpower now . MOST parts available from Tractor Supply . pumps , valves and so forth . Most any industrial hydraulic supply can get seals for cylinder , if it leaks.
Nothing quite like a Didier anymore.
Sep 28, 2009 | Saws
Wood splitter slow action
What's going on is the seals are worn out on the inside and the fluid is bypassing. This is why it is slow.....while operating it, feel it. If it is hot, it's bypassing....the actuator (cylider that houses the piston) needs rebuilt.
If you can get the specs on this, it is really easy to reseal....pressure testing is another thing....take it to a rebuild shop. get this done and it will last another 30 winters!
Mar 12, 2009 | Plumbing
Heavy Machinery Logo
639 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
