Does RCA Make a blue ray-dvd player - Televison & Video
From what I know the answer as of the moment is no. RCA supported the HD-DVD format which lost and I haven't seen any blu-ray players made by RCA presently.
Posted on Mar 30, 2010
  • 3 Answers
SOURCE: blue ray player wont play blue ray ''Kung Fu Panda'' disc.
Unable to play BD-R or BD-RE discs in the Blu-ray Disc® (BD) player. Solution
sp.gif sp.gif The Blu-ray Disc® (BD) player does not support BD-R and BD-RE discs right out of the box. However, a free firmware update is available that will provide compatibility with BD-R and BD-RE discs recorded in the BDMV format.
If your computer is equipped with a DVD burner and compatible burning software, you can download the update from the Drivers & Software section of the Sony® eSupport Web site and then burn your own update disc on a DVD-R or DVD-RW disc. If you do not have the capability of downloading and burning your own firmware update disc, you can register the BD player online at http://www.productregistration.sony.com/ and a firmware disc will be sent to you automatically; the shipping and receiving time for the disc is approximately 7-10 days via U.S. mail.
NOTES:
  • The firmware upgrade does not support BD-R and BD-RE discs recorded in the BDAV format.
  • Disc may not be played due to inadequate recording capability of the recording device.
  • Disc may not be played due to a disc being in poor condition.
Region
sp.gif sp.gif Canada
United States
Products
sp.gif sp.gif BDPS1
BDPS300
BDPS301
Last Modified Date:10-27-2008sp.gifID:C444112
Posted on Nov 29, 2008
SOURCE: How to connect blue ray disc player to rca rear projection tv
Unfortunately, there are a couple potential problems. First of all, if you RCA rear projection tv is fairly old and is not a High Definition tv, you may not have an hdmi, dvi, or component connector cables inputs. Without these, you are left connecting your blu-ray only by the standard yellow (video), along with the audio (red and white) rca cables... either way, the High Definition portion of the blu-ray won't work with a non-High Definition tv. It may be time to buy an HD capable tv to use your blu-ray effectively...
Posted on Dec 29, 2008
  • 60 Answers
SOURCE: My lg blue ray dvd player wont play regular dvd's
sounds like a bad optic or a software issue
Posted on Jun 09, 2009
  • 441 Answers
SOURCE: can you play regular dvd's on blue ray dvd
yes you can, it will upconvert them to 1080
Posted on Nov 11, 2009
BobbyR1234
  • 173 Answers
SOURCE: Can not get DVD out of Blue ray player (insignia) wont open
You should be able to remove the case and retrieve the dvd from the player. You may or may not have to apply steady, gentle pressure on the dvd tray to force it open a bit if you can not remove the disc due to a covering. Make sure the device is unplugged before you remove the case.
There may be a few things that may have caused the problem to begin with. The first thing is that dirt or some sort of debris has cause the gears, tray track, or tray drive to jam. A close inspection with a flashlight should be enough to see anything that may be causing this. If you see anything, try removing it with tweezers if it large enough to grasp and then spraying the inside out really well with a can of compressed air.
The next things are that the disc tray gears or the gear belts have broken. you will also be able to see this with a close inspection. The following is a picture of what parts to look for:
The next thing could be that the disc tray motor has malfunctioned in which case would require replacement.
Another thing that could cause the dvd tray to not open is that the push button switch has malfunctioned either in the electrical circuits or the button itself has broken.
Other than cleaning out the inside of the player, I would suggest having a qualified technician replace any parts with the exception to the little belt, which in most cases you can do yourself easily if it is accessible without having to remove other parts (some models it can be reached easily and in others it may take removing overlaying parts).
I hope this helps give you and idea of how to solve the issue. Feel free to ask if you need further assistance.
If you would not mind, please rate my help. I would greatly appreciate it. Thank You
Posted on Feb 07, 2010
NEED CODE TO UNIVERSAL REMOTE RCR804BFDR FOR TO PLAY MY SONY BLUE RAY DVD BDP-S580
Use code search to find something that works. If a search through all codes contained in the remote fails, you may have to try a different remote. All universal remotes do not contain all possible codes.
Oct 20, 2016 | Sony Televison & Video
I have a Vizio DVD Blu Ray player i need the code for a RCA universal remote
RCA doesn't support Vizio DVD or blue ray player ..........
Dec 20, 2014 | Televison & Video
Is there an update for my rca home theater system rtd315wr?
Hi there.
You`re system can not play blue rays. it`s only a DVD player.
for blueray you need an BLUE RAY Player.
lg.Gue.
Jun 20, 2014 | RCA RTD315 Theater System
My rca blueray dvd player will only play dvd not blue ray
What model player do you have? What movies are you trying to watch?
Check if there is a firmware update for your player. If your player is older and your movie is a recent release, you may not be able to watch it unless there is a firmware update. (If no updates are available, the manufacturer wants you to replace the unit.) Due to changes in copy protection and codecs, new movies can't be interpreted on an older player.
I hope this helps. Please add a comment with the model number of your blue-ray player for more support.
Mar 08, 2013 | Televison & Video
Is there a remote code for a samsung blue ray (RCA model#RCR412S)
There is no setup codes to any of the remote controls to work with any blu-ray players with its blu-ray zone.
Mar 02, 2013 | RCA 3-Device Universal Remote with...
I need help setting the default video and audio combo.( no book ) I am new to this receiver and I changed the dvd player to a blu-ray which caused a need to change the audio input to the receiver. Thanks...
the blue ray player should have a audio output generally RCA audio.
just get this cable RCA Audio from the blu ray to a input on your receiver eg. dvd,cd,line 1,line 2 whateva your receiver inputs are lol
Jun 29, 2010 | Audio Players & Recorders
How to connect dvd player to tv
In order of best to worst quality, and depending on which connectors both have.
1. Hdmi ( Video and Sound in one cable )
2. RGB also known as color stream (Red,Blue, and Green RCA ) Sound Seperate ( Red and White RCA )
3. Composite ( Yellow RCA ) Sound Seperate ( Red and White RCA ) sometimes mono (single sound RCA)
4. COAX (cable) which most DVD players don't have.
All RCA connections on devices should be center color coded And grouped by connection Video 1 Video 2 ect.
Mar 16, 2010 | Philips Magnavox DVD Player MWD200F
Televison & Video Logo
267 people viewed this question
Top Televison & Video Experts
Electro Med Services...
