Question about Koss CDR200 2-Disc CD Recorder
Cdr200 recording can I record from an outside source, such as a cassete playeronto a cd, if so how?, Thankyou
I need help hooking my koss up e-mail @ 61243rd
Posted on Feb 06, 2008
  • 103 Answers
Your CD recorder has 2 sets of phono (rca) sockets on the back. You probably have the outputs connected to your amplifier & speakers. All you need to do is connect your tape deck (or any source except for a turntable) to the inputs sockets on the back of the CD deck.
You might need to switch to external or analogue recording on the recorder.
If you are going to be doing a lot of this type of recording & want it set up more permanently, it might make sense to reconfigure your hi-fi. Shout if you want help with this!
Posted on Jan 09, 2008
Manual for pioneer cdr200 older model cd recorder only
Try Googling(pioneer)(cdr200)(manual) without parens.
Nov 24, 2017 | Pioneer Audio Players & Recorders
Convert cassets to cds on classic recorder model cdr200
Connect the Play or out from the cassette and connect to the rec or in on the CD recorder using some descent RCA cables. Good luck!
Jan 13, 2013 | Classic Electronics CDR201 CD Recorder
I have this 2-Disc CD Recorder but I don't have the manual on how to hook it up to my recevier. I'm not sure if I'm to hook it up to the Analog or to the Coaxial Digital. I did try to hook it...
No problem,You need to connect "CD" to" Receiver" in a regular way just to play ..
(output of CD-TO- input of Receiver) ..use either "RCA analog (red/white ) " or "optic " cable.(any standard optical cable )...optic is the best way to connect it..Remember your CD's "OUT" goes into" IN "
pls also remember,wherever you connect your CD on your Receiver,you should switch the source selector accordingly to correspond to the connection on the back...
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Koss CDR200 2-Disc CD Recorder
Can I record from a cassette player to the koss
should be able to go directly from tape out of cass deck to input of your koss, as long it has line level inputs (which it should). from there its play on the tape and record on the cd rcrdr. seems the simplest solution
Jan 30, 2010 | Koss CDR200 2-Disc CD Recorder
Yes, but you, like I could use an owners manual for this thing, as it isn't as easy to operate as the Philips Audio CD recorders. Owner's manual anyone?
You can just press input select for analog, press record, wait then press 'play' to start recording.
Aug 04, 2009 | Koss CDR200 2-Disc CD Recorder
Willthe b deck playback a normal cd? Sounds like your record laser is gone. It's a philips laser and they are known for it.
Jan 23, 2008 | Koss CDR200 2-Disc CD Recorder
can I record from an outside source, like a casset player to cd, on the cdr200, if so, how, thankyou
Nov 25, 2007 | Koss CDR200 2-Disc CD Recorder
It will record any line level source (CD, MD, tape, tuner). You can only record vinyl records if you have a phono pre-amp.
The best way to use a CD recorder is to use the "tape loop" on your amp/receiver. Does your amp/receiver have a "tape in" and a "tape out"? If it does you should connect your CD recorder to these in/outputs. That way, whatever your amp or receiver is set to listen to, is what you'll be recording.
Shout if you need more help!
Sep 13, 2007 | Koss CDR200 2-Disc CD Recorder
Koss cdr200 dual burner
I had an issue similar to this - I found if I didn't try to record from the internal player it worked ok. Does it say 'recover' when you try to record anytime? If you open the unit,you might see some capacitors on the power supply on the left hand side have leakedand the power is cutting in and out. 'Recover' usually comes up when a recording is interupted if you switch the unit off during recording.
Aug 28, 2007 | Koss CDR200 2-Disc CD Recorder
Koss CDR200 2-Disc CD Recorder Logo
195 people viewed this question
Top Koss Audio Players & Recorders Experts
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
