Monitor power is low, it barely comes out on both chanells. I get plenty of power from the mains, but relatively none from the monitors.....help
  • ribdar Nov 17, 2009
    yorkville powermax 2150 each monitor mix is supposed to put out over 200 watts of power with out any external amplification.....the mon knobs were maxed and the monitors were connected directly via high quality speaker 1/4 cords...there's also an option to raise the entire level of the monitor mix...this was maxed as well...is it possible to have this repaired if it is in fact faulty
  • 4,234 Answers
Can you please update this with the make and model of the amp involved as well as a description of how the monitors are connected?
Generally, the monitor feeds are lower in volume that the mains, but you should get reasonable output. Check for secondary level controls that are independent fro the sliders (if you are using a mixer).
Dan
Posted on Nov 16, 2009
Testimonial: "fantastic recomendation!!!! extremely fast response time!!!!! A+"
  • ABRsvcs Nov 17, 2009
    If you are getting clear output but at a low level, it suggests that either a buffer section or pre-amp section is defective. This should be a relatively simple fix, but tracking down the offending IC may be a bit tricky. Yes, it can be fixed. Most likely one or more 4558 ICs have failed. These are the most commonly used ICs for mixer applications. These cost around $1 each and are readily available.
    If you can indicate your location, I may be able to recommend a repair shop.
    Dan
Monitor is locked
Sounds like a main board fault. Power supply is working, but the start voltage, that should come from the main board after power board ON, do not come now. Check for the reason. In most cases, the fault should be with main board; and troubleshooting to this board is somewhat skilled work. It will be best to contact the authorized service centre for Sony in this case, because, if power board is irreparable, and need replacement, you can't get it from open electronic spare part market. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Dec 25, 2013 | Sony FWD40LX2F 32 in LCD TV
What's your problem?the screen turns very dim to where you can barely see the picture
Your monitor is going bad or your video card is going bad. Try using another monitor on the computer to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and see if you can barely see the icons and desktop on it. If the borrowed monitor is bright and clear and you can see things ok, then your original monitor is going bad. If the borrowed monitor shows the same problem of barely being able to see things, then your video card in the computer is bad.
May 06, 2012 | HP Pavilion Slimline s3600t Desktop PC
I need the drivers. or the web site can not find it on the web
Hi
The .inf drivers for almost any computer monitor is already built into ALL operating systems.
There are, generally, no drivers necessary or available for monitors.
This is the way it works. A computer's Graphics Card (which is, effectively dedicated a mini Motherboard with its own dedicated RAM Memory, Heatsink and/or Cooling Fan and Microprocessor - GPU), purely to power and manage the overall graphics capability of the computer. The Graphics Card does most of the work involved in taking encoded or decoded image files from your computer, from a DVD or VCD, from the internet or from a typical, external imaging source like a Smart Phone, Webcam, Digital Camera, Camcorder or a Media Player and then and interprets these image files into the analogue or digital signal (depending on monitor type) it sends to the monitor for it to resolve into an image.
A monitor has a range of Resolutions it can operate within, and if the Graphics Card or Graphics Chip Setting are set too high or too low, outside this range, the next time the computer is restarted or shut down and powered up again, the monitor might be incapable of resolving the image and therefore remain blank, as the computer boots, leaving the user blind to its Desktop.
Other faults preventing monitors from displaying images include foreign metal objects or bent, touching, pins shorting in the connectors at each end of the VGA (Analogue) and DVI (Digital) Video cables that link the Monitor to the computer. The cable may also have a failure or a fault somewhere along its length or a failed connection at the junction of cable and connector.
The quality of the image displayed on the Monitor is mainly governed by the resolution of the image, which is controlled by the software governed settings of the Graphics Card
If none of the above is preventing the Monitor from functioning then the Monitor might have an internal fault. The inside of Monitors and TVs are a hostile, non User Repair Friendly working environment, with lots of capacitors storing relatively high charges even when the monitor in not connected to the mains electricity, that can seriously injure or even kill an inexperienced repairer.
Internal monitor repairs are rarely economical because a successful repair often requires the replacement of a faulty internal component, the cost of which, when added to the labour cost involved in the repair, is unsustainable, given the widespread availability (due to the rapid uptake of HD technology) and relatively low cost of Warrantied new and 2nd user models in the marketplace.
If your Monitor is powered by an AC/DC Power Adapter, check for any faults with the Adapter that might be preventing the power from reaching the Monitor and if, found, consider a replacement adapter from here or from similar sources to this:
http://www.ebay.com/itm/NEW-AC-Adapter-Balance-Digital-Technology-EZ17J-LCD-/320744475938?pt=LH_DefaultDomain_0&hash=item4aaddc4d22
If the monitor proves to be faulty and none of the above solutions remedies the fault, it may be time to consider buying a new Monitor.
Definitely do not waste any more time looking for Monitor Drivers.
I hope this helps.
If this Answer goes some way towards helping to resolve your Query, Problem or Fault, please take the time to Rate it. This helps Answerers, like me, better understand the needs and the point of view of the Asker and guides us in exploring the best ways to provide useful, high quality Responses.
If you need further help, please do not hesitate to post another Question or add a Comment to this Question.
Sep 03, 2011 | Balance CM2019 19" LCD Monitor
Computer not booting up,power is on hard drive light comes on but nothing on the monitor
  1. Are you sure that the Monitor has power? light is on?
  2. Disconnect all devices (one by one) and see
  3. Did you try to connect the monitor to a different PC ?
  4. Try unplugging the power cable, then wait about 30 seconds and try
  5. Did you try to connect the PC to a different monitor?
  6. If none of the above help, your monitor may be bad.
Jun 23, 2010 | Biostar P4M800-M7A Motherboard
Dell 2407wfpb lights on but stays blank..
Shine a bright light on the screen and press the Menu button... if you can barely see the outline of the menu come up in the middle of the screen, it means that your inverter / backlight needs to be replaced. You can get a new backlight / inverter for relatively cheap, so if you can do the repair yourself, it's worthwhile.
Otherwise it's the LCD panel itself, in which case you should go monitor shopping.
Sep 11, 2009 | Dell UltraSharp 2407WFP 24" LCD Monitor
Intel Desktop D845PEBT2 could not boot up
i,d suggest that the power cut may have been a surge or spike.
This May have blown your power pack, and caused possible motherboard Damage.
** Did you use the same lead for the PSU** and have you checked the (main fuse in the Plug ? )
If the monitor light remains orange, this is a possible graphics card fault, or driver that is not allowing the monitor to come out of standby mode. You could try installing a different graphics card, or swapping the monitor cable to the on-board graphics card if it has 1.
If none of the above works, assume the motherboard has suffered damage.
Mike @ Compurepair.
Jun 12, 2009 | Intel Desktop Board D845PEBT2 Motherboard
Samsung SyncMaster 510N Monitor is flickering and blinking like a Tube Light After playing games for 20-30 min . It flickers when some darkness comes PLEEEZE help me
Does the monitor remain on does it switch off?
Problem seems to be hardware related ie monitor itself is defective.Try connecting to another known working system.If monitor is defective it could be a power/inverter related issue or panel could be defective.
Please provide feedback and rate the solution.
rahul
Feb 22, 2009 | Samsung SyncMaster 510N 15" LCD Monitor
Hp 1703 Video for 1second then Black Please Help if you replace the main boards ( Power & Video Or just the Power Board) will this fix the display issue. thanks
You may want to check your power and connection cables are not showing bare wire, which is the metal hanging out of the rubber insulation cord. So just check for that and if not that I would call HP.
Jan 30, 2009 | HP Pavilion F1703 17" LCD Monitor
PS/2 power supply connection
You seem to have an oddball monitor if what you describe is correct. The power supply to a monitor[Display Screen is that what you mean?] is either direct to main power- in which case the power cord is either built in with a power plug for wall socket, or has a socket on the back for a separate main power cord. Or is powered from a low voltage converter that delivers low volts usually via a coaxial plug like this illustration PS2 connection does dot come into the equation as far as I know unless you have got hold of something unusual. Tell you what take a shot of the back of the monitor and lets have a look see mean while here's is a shot of a typical low voltage power supply available anywhere.
May 26, 2007 | View and View Technologies VNV AquaView...
Monitor
-Turn off both computer and monitor
-unplug monitor from computer(still plugged into power supply)
-turn on computer and monitor(monitor is still unplugged)
-After computer is on for about 30 sec. plug monitor into computer
-turn off both monitor and computer(now connected together)
-turn on monitor then computer and should be good to go!!!
Mar 25, 2007 | Sony CPD E230 17" CRT Monitor
27 people viewed this question
 Grubhead
Grubhead
