Question about Radio Communications
I have a 2510 thaqt i think the pos and neg leads were crossed and now radio doesnt power up , whats the fix ?
  • 3 Answers
Their is a black diode that crosses on the - and + lines this would be blown plus your fuse..
Posted on Nov 16, 2009
Has aftermarket amp and special unit that allows an ipod to show what song is playing on the regular factory radio. The problem is the radio lights up normally but no sound from speakers. Zi did hear a...
Something has been mis-wired. Ensure the speakers are in the speaker slots and the power (Neg and Pos labeled as well) are properly connected. It is fairly common to get the speaker pos and neg mixed up with the power pos and neg. Hopefully, no permanent damage was done. The problem is between your factory radio and the aftermarket power amp.
Mar 12, 2015 | Cars & Trucks
Someone hooked jumper box up backwards on van and tried ti start it it ran great before that after it wouldn't start at all changed the computer now it starts runs a few mins then shuts off what could it...
You will have to take it to the Dealer. You may have burnt out or the "Control Module" needs to be replaced or reprogrammed. Make sure the battery has not reversed polarity also.
Feb 13, 2015 | Cars & Trucks
Red light on charger flashes. battery doesnt seem to charge.
If the red light is flashing rapidly it means that your charger has determined that your battery pack is in need of replacement and a safety circuit will not allow it to be charged. You may have an actual fault in the pack OR it may just mean that you have allowed the pack to discharge below the manufacturer's recommendations and the safety circuit has been fooled into thinking that the pack is defective. You need to decide which scenario is more likely correct. Using a DC voltmeter, determine if the battery pack has any voltage at all and which connections are positive and negative. If there is zero voltage, then you probably should go shopping and send your current battery to a recycler. If the battery pack does show some voltage, that is a good sign. TRY THIS AT YOUR OWN RISK! You can attempt to partially charge the battery pack (while not in the charger and not in the tool) by using test leads to connect it pos-to-pos and neg-to-neg to a fully charged battery of similar voltage/amperage. Only connect them together for a couple of minutes. Remove the leads and test with the DC voltmeter again to see if voltage in the questionable battery pack has increased by more than a volt or two. If so, it is still taking a charge. Move it back to its charger to see if there is now sufficient voltage to not trigger the safety circuit and allow it to charge normally. Wear eye protection. Don't cross leads. Don't try this on an obviously damaged battery or one that feels hot.
Sep 25, 2014 | Dewalt DC9180C Heavy-Duty 1 Hour Charger...
Hi I have a sony CDX-GT500U car radio. The problem is that when i turn the volume up over 20 it cuts out. What can i do to fix this problem?
Check pos and neg wires on speakers and radio they may be crossed.Does the radio have bass to it or sound like tweeter
Mar 20, 2011 | Car Audio & Video
Wiring diagrams for clarion dxz535 car stereo
Here's how it goes:
Speaker wires:
grey=right front pos.
grey/black=right front neg.
white=left front pos.
white/black=left front neg.
violet=right rear pos.
violet/black=right rear neg.
green=left rear pos.
green/black=left rear neg.
red=12 volt switched power source
yellow=12 volt constant power source (direct to battery)
black=chassis ground
orange/white=illumination (switched source,not to head light switch)
blue/white=amp turn on lead (to remote turn on lead of amp)
blue=auto antenna (switched power source)
brown=phone mute lead (to cell phone mute lead)
RCA connector leads:
grey lead:
red=right front
white=left front
black lead:
red=right rear/right rear subwoofer
white=left rear/left rear subwoofer
(connect to external amp)
red lead:
red=right aux input
white=left aux input
(connect to external unit)
green lead:
red=right dual zone output
white=left dual zone output
(connect to wireless head phones)
That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
Sep 26, 2010 | Car Audio & Video
Oem Radio installation
*** 91 park ave with delco bose =
black = ground
dark green = lights on input
grey = panel lights
pink = on input
yellow = power input
orange = battery power input
nca = shield ground
tan = left fr spkr +
orange/black = left & right spkr -neg
lite green = right fr spkr +
nca = shield ground
dark blue = right rear spkr +
dark green/yellow = right & left spkr - neg
brown = left rear spkr +
purple/white = display dim output
pink = vehicle speed input
**** 91 park ave without delco bose =
grey = left front - neg
tan = left front + pos
dark green = right front - neg
light green = right front + pos
black = ground
dark green = display dim signal
grey = panel lights
pink = power antanna
yellow = ign input
light blue = right rear - neg
dark blue = right rear + pos
yellow = left rear - neg
brown = left rear + pos .
there YA go
Dec 27, 2008 | 1991 Buick Park Avenue
Motorola MCX1000 Model no :MBT44UXA7H00AK
sure, the red lead goes to the battery pos and the black lead goes to the battery neg as some cb radios have a reverse polarity idiot diode fitted, go with caution. With a multi meter you can find the neg terminal using the continuity or the low ohms
select on the meter...1 meter lead goes to the metal body of the set and the other lead goes to one of the power leads WITH THE SET TURNED OFF when the meter responds to a contact and shows low ohm reading you have found the neg lead..this lead is directly connected to the fram/case of the set. With a few sets
you need to have the mike connected in order to power up.
flyingfox@people.net.au
Jun 19, 2008 | Radio Communications
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
