Question about Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho
Can it be incorporated to work with additional switch to turn on or off from remote location and can the lights be dimmed and how?
I'll tell you for $12.95 .
Posted on Nov 17, 2009
The back of my Turn of the Century fan's remote control has this switch in the back of the battery housing. It's marked with 'D' and 'CFL' on either end. Can someone tell me what this switch means?
The switch is allows you to tell the remote which type of light bulb you have installed in the fixture. The CFL setting is for the included compact fluorescent bulbs. With these bulbs, you can only turn them on and off. If you put in incandescent bulbs, set the remote to D. Then you can dim the lights in the ceiling fan, in addition to turning them on and off with the remote. CFL bulbs can't be dimmed with this fixture.
I found this described in the manual for the Turn of the Century Midori 52" ceiling fan. This fan is available at Menards: https://www.menards.com/main/lighting-ceiling-fans/ceiling-fans/indoor-ceiling-fans/turn-of-the-century-reg-midori-52-contemporary-ceiling-fan/20338/p-1444433460319.htm . The direct link to the manual is currently https://hw.menardc.com/main/items/media/HONGK003/Install_Instruct/3551058-3551059_install.pdf .
I hope this helps.
Apr 01, 2018 | Dryers
My 2009 Ford Escape remote starter....i click and it beeps once..then beeps three times. Will not start or turn over engine. What does this mean or is there quick fix?.....been working good for 3 yrs.
By some strange reason it happens also if the instrument panel dim light is all way up and you have to keep your dome light switch off or it will light even if all doors are shut. I put the dim light switch into normal position and my remote starter resumed its function! Thanks to F150 forum, I found this remedy there: 2010 REMOTE START
Jan 07, 2013 | Ford Escape Cars & Trucks
My Harbor Breeze remote control fan no longer responds to my remote controller. The first sign of problems was when the lights began flickering momentarily when I tried to dim them. Then the lights went...
this black box is a watt governor for the lights. just remove it, and wire direct. then you should be fine, just let me know the outcome!! the box should have vent slots in it. part # for hunter fan. i do not know if its the same as harbor breeze. --- part # 98480-02, this is what makes lights flicker. if need be replace remote. go to www.harborfans.com and click on support to find phone number for assistance. have a good day !!
Dec 15, 2010 | Dryers
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Light will not dim
Clean the contacts on your remote pcb as well as the carbon contacts on your remote pads and replace the batteries with a new one
Jun 06, 2010 | Hunter 27177 Remote Control
I think our house is haunted. Just installed
See my post below: (Sorry, we're in the same boat!) Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code/channel on the remote due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!!
- P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Mar 20, 2010 | Hunter 52" Ceiling Fan With Light And...
My new fan with light fixture is hooked up but it only works through the pull strings not from my wall dimmer. Can someone please tell me why and what do I need to do to have it work from the wall dimmer....
It depends if the fan and lights are ran for separate control. If only one power line is ran from the fan to the switch location than you are out of luck. You should install a switch instead of a dimmer because a fan is not designed to work with a dimmer. A dimmer works by rapidly turning the power on and off faster than our eyes can detect creating a dimming effect for lights. This is not good for your fan. The strength of the fan speed will be limited by the dimming/power output of the light dimmer.
Nov 21, 2009 | Universal Remote Control Hampton Bay...
Light and fan go on with the wall switch. But I cannot turn out or dim the lights with the remote. I can work the fan. I changed the batteries in the remote. Could it be the reciever for the lighjts. Where...
Dear rwk,
youe remote unit is OK as I can understand from your feed back. The problem lies with you the light control power device. The Triac of the light controller is shorted. It has to be replaced with a new one. If the wattage of the lights is within 250W, you can use a triac of type no BT136. It is located in the wall remote receiver unit.
Thanks
-Mitra
Sep 25, 2009 | Hunter Ceiling Fan Light Remote Control
Remote wont' work after changing battery
Seem like you have a bad lectronic control circuit in that fan.
Jun 29, 2009 | Oasis Hunter 54' Ceiling Fan
Fan and dimmer remote does not work
The remote is a Hampton Bay remote that should dim the light and fan on and off. I replaced the battery and do not have a red light when I press the button. Light and fan does not turn off with remote.
Mar 01, 2009 | Universal Remote Control Hampton Bay...
Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Logo
101 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Tom Chichester
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
