Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore Dispenser Locks
I just bought a house with a side by side Kenmore fridge. The front panel on the freezer side has four buttons (cubes, crushed, filter, and lock). The panel was cracked and two of the push puttons (plastic) were torn. I ordered and installed a new panel, plastic button cover, and water filter. Everything works, but every time I open and close the freezer door, the Lock lights up and nothing works until I press and hold the lock button for about three seconds...then everything is fine until I open and close the freezer door again.
  • Anonymous Jul 11, 2008
    My Lock light eventually stayed on and I can't get it to shut off and therefore cannot dispense water or ice. Did the simple board fix your problem?
  • Anonymous Mar 29, 2014
    light comes on if I hold the switch with my hand. the switch wire seems to be loose. How do I open up the plastic switch cover without breaking it and adjust the wire enabling it to make contact when the door is opened
There are two boards behind the panel. There is small and simple board that bolts onto the panel itself, then there is a motherboard that bolts onto the door. I'm assuming you are speaking of the simple board, in which case there isn't much to it. Do you know if there is a fix to the board itself? The board is a $50 part and I would hate to replace if it doesn't fix the problem.
Posted on Jan 28, 2008
  • 42 Answers
You will be very glad to know I have an answer to your problem. I am guessing that your refrigerator was manufactured in 2002 between about March and November. This part does not really matter but I am giving you this as a history lesson. If I am correct Your model # starts with 253. and that means it was manufactured by Frigidaire for Sears. There was a glitch in the board that is in the panel you replaced that causes the problem you have described. You need to replace the board in the touch panel and your problem is gone. You will need to have the model number in order to order the part. The part will be available through Sears or other appliance parts dealers.
Please don't forget to rate me
Posted on Jan 25, 2008
  • Keith Smith Feb 14, 2008
    I am sorry that I did not receive a message from FixYa notifining me that you had posted another question. Yes it is the simple board (the customer interface board the customer uses to talk to the refrigerator).
    I can not take blame for free advice and that is not a cop out. I have in my service life run into this problem many many times and the simple board has always cured the failure. If you find you have a friend with the same basic model style you may ask to borrow their board to test. Chances are you will not find a friend with this one.
    I wish I could give you some kind of warranty but I would not steer you wrong on purpose and would not state the solution as strong if I had run into other causes for this problem.
    Please don't forget to rate me Either Good or Bad depending on what I deserve. I believe you will be able to rate me Good. supertechks
Kenmore w/GSI 23 Ice maker: door is distributing crushed ice in both the cube & crushed mode. Is there a reset function to get the cube mode to begin working again when that button is selected? thx,
it sounds like the mechanizme is jamed, (if it has one) remove the ice tray bucket and where the metal rod sticks out the back of the bucket see that where it goes into the fridge is not frosted up, hold the freezer door light button in and activate the ice dispenser watch to see if a solinoid activates a latch if it does not move free it up so that it can move freely up and down... (if this is your model)
Aug 22, 2011 | Kenmore Side by Side Refrigerator
Just got Neff ice cube, crushed ice maker and ice
Will probably find the freezer fan has failed.Push in the door switch on left hand front of freezer with the door open & you should here fan running,if not new fan required.
Jul 01, 2009 | Neff K3965XO Side by Side Refrigerator
Kenmore fridge not working, ice cubes wet, freezer frosting up
You may need a new defrost module. The coils ice up when it is not working. This makes the fridge and freezer only a little cold. About 150 to 250 bucks to fix if you call a service person. Under a hundred for the part.
Apr 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The icemaker in the door of our Kenmore Elite Trio frig just stopped working, exactly 13 mos. after we bought it. We did not get an extended warrantee, because we have never had a new appliance fail so...
Is the ice unit turned on? I pushed the off button by mistake and PAID someone to "turn it back on for me" The guy laughed all the way to the bank :( Also he said a good place to start , before I call next time, is have you checked to see if there is a ice cube frozen(caught) in the top.Pull out the ice catcher(bin) and check for the frozen cube of ice. Be sure to turn off the ice maker first or it may drop ice when you least expect it! My fridge is the origional for house (18 yrs) and after I've done this check list, the problem is fixed. Just thought I mention it. Good luck!!!
Mar 14, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Bottom Freezer Refrigerator Model #795.77562600 Serial #608KR00238 The control pad is locked up, it dispalys Er CO. You can't change from water, ice to crushed ice. The ice maker runs. It...
This first thing I would do is remove the panel on the back of the fridge to access the control board. It should be about half way up on the left hand side if you are looking at the back of the fridge. There should be four 1/4" screws to remove. In the middle of that board there should be a reset button. Press that button then let me know if that worked.
Nov 30, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Panel between fridge and freezer hot on Kenmore fridge
It is normal for that panel to get warm while the fridge is running. There is a hot gas tube from the compressor running through it to prevent frost built up. If it's feeling a little too hot try cleaning the coils under the fridge. This will allow the gasses to cool a little more efficiently thus allowing the fridge to cool quicker.
Nov 03, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
Kenmore refrigerator
1. Remove the switch cap and unsnap the two (2) tabs at the bottom of the front cover from the
housing first. Pull the bottom out and lift and the front cover from the housing. (Fig. 27)
2. Remove the two (2) hex-head screws securing the metal control panel cover to the dispenser
housing. This will also free the control bracket from the housing although it will remain tethered
to the freezer door by the wiring harness. (Fig. 28)
3. Disconnect the wiring harness connectors from the terminals
on the switches and light fixture in the control bracket.
Removing the Dispenser Assembly
1. Do the previous three procedures.
2. Remove the eight (8) hex-head screws securing
the dispenser housing to the freezer door. (Fig. 29)
3. Carefully pull the housing from the door.
4. Pull the water supply tube from the top of the dispenser housing.
5. Pull the wiring harness leads from the dispenser housing.
6. Disconnect the wiring harness connectors to the electric
foil heater that should get you in there
Feb 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Sears Kenmore Refrig #363-9554710 (side by side) - Remove panel on left front to access funnel guard
You will need to unplug the fridge or unplug the wires going to the dispenser from behind the grill at the bottom of the fridge.
Pop off the front cover over the switches and pop off the soft button cover that you mash to activate the dispenser.
You will see the screws that hold the dispenser assembely to the housing. remove them and the unit will slide toward you.
Post back if you need more help, I may have forgotten a step somewhere.
Oct 30, 2007 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
167 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
