Question about Boston Acoustics (BA7800) Computer Speakers
Adapting Boston Acoustics BA7800 for use with TV
I want to use my Boston Acoustics BA7800 system with a new TV. I got the system for use with my Gateway PC, and it works well.
I started to hook the BA7800 system to my new TV, but cable that connects the woofer base to the output source (previously the computer) has three 3.5 mm (1/8") stereo (TRS) connectors, but for the TV I need RCA male connectors.
Do you have any advice?
Thanks!
John
  • 2 more comments
  • jrd77 Jan 09, 2008
    My email address is delfsj@verizon.net
    Thanks
    Thanks. Now I see how to adapt to the RCA plug. However, there are three male 3.5mm stereo (TRS) plugs (pink, green, and black) coming from the speaker system - and on the TV there are only two RCA female inputs (L-white and R-red). How do I deal with that?
    Thanks,
    JD77
    Thanks. With regard to the three stereo male connectors coming from the speaker system, I think one of them (the pink one) is probably for the microphone going into the computer. That leaves 2 that I need to use - the green and the black - each of them will split into two RCA male plugs. I'm assuming one is for the stereo in the front - and the other for the back speakers. Will it be OK to plug the both of the "L" plugs into the "L" TV plug and both of the "R" plugs into the TV "R" plug (via the female RCA splitters)?
    I want to thank you both - BLACKLORD1 and Dyllan - for solving my problem. You both were very helpful - and I'm delighted with the Fixya service. Saved me a lot of time as well as meant that I have a solution that means I can now use the system in the way that I had hoped. Thanks!
    Sergeant:
  • 279 Answers
Here's what you need:
http://www.vpi.us/cable-audio.html
Scroll down to the 3.5mm Stereo Jack / RCA Plug x 2 Y-Cable
Converts your TRS connectors to dual RCA plugs. You said you have 3 TRS connectors. Does the TV have 3 sets of RCA plugs you can use with this? If not, you may not be able to get full surround sound, just stereo sound, from your TV - and you'll need some RCA splitters to plug two (or three) cables into one port. I know you can get those at Radio Shack.
-Dyllan
Posted on Jan 09, 2008
  • John Goodman Jan 09, 2008
    Yes, that should work fine. Whatever's plugged into the R plug will play whatever sound is intended for the right speaker, and the same goes for the L and the L speaker.
  • 2,427 Answers
Yes,, you local electronics shop will sell a 3.5mm to double RCA y converter or adapter :)
just buy it and use it thats all :)
  • 6 more comments
  • Rishi Roshan Ali Jan 09, 2008
    Here is one that what it looks like, but insted of a male 3.5mm you can get a female 3.5mm http://www.hardwarecooling.com/product_i...
    hole let me see if i can find a pic with a female one
    Here is a single RCA
    http://www.cablesforless.com/browseprodu...
    You can get a y adapter and use it with that, the Y adapter has 1 female rca to 2 male rca
    Ok HERE IS A PIC OF WHAT MINE LOOKS LIKE
    2x RCA Male to 1x 3.5mm Stereo Female Y-Adapter Cable
    THATS THE NAME OF IT AND YOU CAN GET IT HERE
    http://www.networkscable.com/specs/30s1-...
    or your locol electronics shop
    Ok that easy there are 2 ways
    1.) there is a conversion box that converts 3 3.5mm to 2 RCA used to convert Computer speaker system to adapt to the tv
    Its called A STERO RCA 3.5mm adapter you can get it at your locol electronics shop but it is a bit expensive
    2.) you can convert the 3 3.5mm to 1 3.5 mm using an 3.5mm adapter
    THE ADAPTER IS CALLED A
    Mini Stereo to duel rca adapter it made by logitech
    The adapter looks like a black box with 3 3.5 mm on one end and 2 rca on the other
    Its cheaper and easier to convert tyhe 3 3.5mm to one and then use the y adapter i specified above...
    ANOTHER CHEAP WAY WHIC I RECOMEND IS
    1.) connect the green 3.5 mm into the y adapter i specified above
    2.) hook it up to your dvd player and set the system or dvd player to play doble digital 2.0 where the entire system and all speakers will play so you dont need to hook up the orange and black ones
How do I take apart a Boston Acoustics BA7800 subwoofer?
If you've undone the 8 screws on the back panel... I would suggest the only thing holding it in is..... it's an interference fit... try carefully prising it out.
Nov 18, 2014 | Boston Acoustics (BA7800) Computer...
BA7800
hmmm...what kind of sound card you using, Laura?
Feb 17, 2008 | Boston Acoustics (BA7800) Computer...
No sound from rear speakers Boston Acoustics BA 7800
check whether the wire is connected properly on both the ends
Aug 08, 2009 | Boston Acoustics (BA7800) Computer...
Need cable to connect computer to BA7800 speaker system
YES, WHERE CAN I GET THE 3 PRONGED CABLE TO CONNECT MY SOUND CARD TO THE INPUTSON THE BACK OF MY BA7800 SPEAKER SYSTEM, OR JUST MAKE MY OWN WITH 3 GOLD TIPPED 1/8" CONNECTOR WIRES?
Jun 14, 2009 | Boston Acoustics (BA7800) Computer...
Install Boston Acoustic speakers BA7800 to a new Imac?
Partial Solution anyway - I just got a Mac Pro (2.66 Nehalem )and couldn't find the manual from my old Gateway 700XL. This is what I did: Plug the green wire into the analog output, and the pink wire (if you really need an external mic, but you shouldn't since our new computers both have a built-in mic) into the analog input. Just ignore the black wire. You won't have the 2 surround speakers, but I'm still looking for a fix for that. I got tired of the crappy speakers in my new Apple Cinema display (the ONLY crappy thing about my new system). As you know, the sound from the BA7800 is great, even with just the two front speakers and sub-woofer. I'll keep you posted if/when I figure out how to set up the surround speakers! Likewise, if you hear something, please post here and I'll keep checking back.
Apr 10, 2009 | Boston Acoustics (BA7800) Computer...
Trouble with rear speakers
This may be a software issue. If you only had two speakers before, the software will not use the rear speakers.
Go to Control Panel. Click on "Sound and Audio Devices". Under the Volume Tab, at the bottom, you will see a picture roughly representing the type of speakers.
Click on the Advanced button.
Click on the arrow in the pick box, and choose Surround Speakrs or the 5.1 Speakers.
Click Okay. Try the speakers again.
Apr 06, 2009 | Boston Acoustics (BA7800) Computer...
Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
Apr 01, 2009 | Boston Acoustics BA7500 Computer Speakers
Speakers have no sound.
Have you tried other speakers? If so did they work? You might try updating the sound card drivers.
Jun 11, 2008 | Boston Acoustics (BA7800) Computer...
Boston BA7800 PC speakers
I would not suggest it. PC speakers generally have their own amplifier built into the system and will not handle the power from a home system well.
Jan 30, 2008 | Boston Acoustics (BA7800) Computer...
Boston Acoustics (BA7800) Computer Speakers Logo
2,767 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
