Question about HP TouchSmart IQ770 PC Desktop
I have h p touchsmart on my computer. I up graded
I have h p touchsmart on my computer. I up graded to window 7 and cannot turn it on. My screen flickers
    Problem Solver:
  • 7 Answers
How can u upgrade your system? did u read before you upgrade? may be it is not compible... get your windows cd... re format and install freah copy of windows.
Posted on Nov 16, 2009
HP TouchSmart 310-1125f display is black
Hearing fans and hard drive spin up doesn't necessarily mean system is working - just without video. If you heard a POST beep or the Windows Startup sound that would be different - and good. Is there any video on the screen at all, even just a blinking cursor in upper left of display? If not, your problem is probably hardware such as ram or motherboard. If this system has a VGA or HDMI output to connect to another monitor or TV would be a good check, but AIO system usually don't have that option. Other than that, and this is a shot in the dark: Ensure the system is off, disconnect the power plug, and hold the power button in for 30 sec for a power reset. Then plug in system and try powering it up again. If no go, you may have a hardware problem and will need a PC Tech. Hopefully it is just loose ram.
Apr 08, 2015 | HP Touchsmart 310-1125f Windows 7 4gb Ram...
Won't load windows
You may want to try pressing F11 before the Windows Logo screen and select the option to restore from a previous point.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01835735&tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=4007372#c01835735_command
Using System Restore when Windows 7 cannot start normally Use the following steps when Windows does not open normally.
Show me how
  1. Turn off the computer and wait at least 5 seconds with the computer in a full off state.
  2. Turn on the computer and press the F11 key repeatedly as the computer starts.
  3. Under I need help immediately, click Microsoft System Restore.
  4. Use the steps in the Restoring Windows 7 to a previous point section to use System Restore.
Jan 05, 2015 | HP Touchsmart 300-1003 Amd Athlon Ii X2...
Touchsmart HP laptop screen goes white when I tilt the screen
Very likely that the screen cable is damaged around hinge area. It has to be replaced. (just the cable, not the whole screen).
Dec 29, 2013 | HP Pavilion TouchSmart 14 Sleekbook with...
I have a hp all-in-one touch screen 19" windows 7
thanks for the show and tell
I'd sell it and buy real desktop, would.
Oct 12, 2017 | HP TouchSmart IQ504 PC
My touchsmart iq770 wont run windows vista unless im in safe mode and i have lines through my screen
Go to support.hp.com and look up your computer.
Download and install the Vista drivers.
If you don't see Vista drivers the computer won't run Vista. Go back to XP.
If this helps please vote for my solution.
Sep 03, 2010 | HP TouchSmart IQ770 PC Desktop
Screen Brightness
windows 8 to 10 have the brightness control in the action center or power settings or look in the charms bar if your using windows 8 or 8.1 (note: if brightness doesnt change it maybe due to the OS not knowing how to change the brightness let me know if that ends up being the case)
Dec 17, 2017 | HP Wireless Optical Mouse
Loaded windows 7 and hp touchsmart locks up on start up screen also screen keeps flickering every 10 to 20 seconds
easy restore back to factory settings then it will not do that again (this just means the computer dont like windows 7) if it came with any restore cds/dvds just restore it
Feb 03, 2010 | HP TouchSmart IQ770 PC Desktop
HP IQ770 TouchSmart doesn't load up or stay on
Step 1: Disabling Automatically restart option to view error messages
1. You can prevent the computer from restarting by turning off the Automatically Restart option:
2. Click Start .
3. Right-click Computer , and click Properties
4. Click Advanced system settings .
5. Click the Advanced tab and select Settings in the Startup and Recovery section.
6. Remove the check mark next to Automatically restart under System Failure .
7. Click OK to close the Startup and Recovery window and click OK , again, and then close the System Properties window.
8. Restart the computer.
Check if it happens again
If it happens again do a hard drive scan(FULL)
Download the latest BIOS update from hp.com
Step 2: Reinstall Microsoft SATA disk driver solution
1. HP Vista computers that use the Microsoft SATA disk driver do not experience automatic restarts. If you updated your Windows XP computer to a Windows Vista capable computer using an HP upgrade solution, this Microsoft SATA disk driver is available to reinstall.
2. To reinstall the Microsoft SATA disk driver, follow the instructions below.
3. Click Start on the taskbar.
4. Click All Programs , PC Help & Support , and then select Recovery Manager to open the Recovery Manager window.
5. If prompted, click Continue .
6. Click Next to continue.
7. The next window asks if you want to perform a program recovery. Select No , and then click Next .
8. The next window asks if you want to perform a driver recovery. Select Yes , and then click Next .
9. Click Next again to continue.
10. Select Standard Dual Channel PCI IDE Controller from the list of drivers, and then click Next . The reinstallation process takes a few seconds.
11.Click Finish to restart your computer.
Feb 02, 2010 | HP TouchSmart IQ770 PC Desktop
I up graded to window 7 and cannot use my touchscreen
Check the HP website to see if there are drivers for win7
Nov 16, 2009 | HP TouchSmart IQ770 PC Desktop
When computer opens, incomplete Touchsmart windows appear
it mean your windows is corrupt just format & reinstall fresh copy of windows.
Jan 07, 2009 | HP Hewlett Packard ALL-IN-ONE-TouchSmart...
HP TouchSmart IQ770 PC Desktop Logo
148 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
