Resolution adjustment sony kdl37p3020
I recently bought a SONY KLD37P3020 and was wondering how to change my tvs resolution from 480i to its full 1080i
  • cowens2 Dec 09, 2008
    i have a sony hd tv i want to change it from 480i to 1080i
    Scholar:
  • 135 Answers
Hi, the user manual that came with it explains how to do this. Note however that most cable channels probably won't be broadcasting at 1080i, so you won't see much of a difference. You should also be using a component (red green and blue for video, and red and white for audio) or HDMI cable rather than a composite (yellow for video and red and white for audio) cable to get the best possible quality.
Posted on Jan 09, 2008
I have a Sony Bravia kdl-32s2020 LCD with MPEG-2 DBV-T. Are there any possibility to upgrade them to DVB-C MPEG-4. This model is also HD-ready. Haw can convert them to FULL-HD (changing SD receiver with...
This tv have the capabillity for the Full HD max resolution 1080i or 1080p.The problems u have is not the tv capabilities.The tv incomming broadcasting signals are vary like DTV,SD,480i,720i low end HD.Max HD resolutions are 1080p or 1080i.
Dec 01, 2010 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How to change a sony bravia resolution from 480i to 1080i
U can't not,only resolution can get,it the show u watching give u the resolutions.Want more HD 1080i must order a HD package from the cable,satalite or telicom companies.
Nov 05, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
I have sony bdp s300 tonight it began intermittent loss of HDMI signal. It comes and goes. Not the cable, just upgraded to the most recent software. No damage to the HDMI port. This one has me beat.
What brand of tv do you have?? Also what resolution does it display? 1080i, 720p,480i or 420p?some DVD's only use certain ones. U gotta make sure your TV can display the resolution from the DVD.
Jun 28, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Even when I receive HDTV chanels, the display reflects only 480.
No adjustments can be made on the TV since the channels are being pick up with the resolution they are being broadcasted. Once the TV tunes to a digital channel(s), it will show the resolution to be either 480i, 720p or 1080i
Jun 16, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Adjusting the resolution from 480i to 1080i
Typically TVs will auto adjust to the input signal it receives. If your cable box is only outputting 480i then all the tv will show is 480i. Ensure you have a good 1080i signal going in to the unit and check again
May 04, 2009 | Televison & Video
I have a sony 32 inch xbr TV (myt first non analog). HOw do you change the resolution from 480i to 1080i. What is the difference between 1080i and 1080p Thanks for your help. Maria
The resolution can only be change on your resolution source (ie cable box, dvd, etc). On your cablebox go to menu/setting->audio/video->output resolutions->and here you can change the setting. The main difference between i and p is how the video is scanned. I is interlaced, meaning you get the odd lines of video, then the even lines, and the picture may flutter but its better for fast action. P is progressive giving all the lines of video at once, better for still images, but slower of some tvs.
Dec 06, 2008 | Televison & Video
480i is displayed on the 62HM95 even when I play my Sony BluRay
I called toshiba (the television manufacturer) and they told me that the tv recognized the devices and then adjusts to the resolution according to the device of where its receiving the signal (HDMI).In this case my blu ray was not set to the 1080i resolution. Yesterday I set it up and BAM there it was.
Dec 03, 2008 | Toshiba 62HM95 62" HDTV
Wii hd componet cables
sounds like the screen size on the tv and wii needs to be adjusted. look in the wii settings to adjust that and also see if there is a output resolution that you can change to tell the wii that you're using component. component uses 480i-1080i resolution so there shouldn't be much that you have to change.
Mar 17, 2008 | Polaroid FLM-2011 Television
16:9 Enhancement (KV-36HS510) HELP!!
There is a hidden setup on cable box.  Search manual on box.  I have the same TV with a Scientific Atlanta HD DVR.  If you turn off the cable box and hold the Guide + Info Buttons down, it will go into supported resolution setup.  My TV now goes to the appropriate resolution (480i, 720p or 1080i) what ever the channel is broadcasting.
Dec 12, 2007 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Resolution
If you're talking about off-the-air (outside antenna) reception, the set should take care of the switching automatically. If you receive the video from a set top box, DVD player/recorder, SAT receiver or CATV receiver, you may have to set the output resolution of the device. Bear in mind, composite video (yellow jack) is 480i only, S-video is rated 480i or 480p, component video (RGB) can do all resolutions and HDMI can't do 480i but does all the other resolutions. If you are plugging your external device into either composite or S-video, you will only get 480 max.
Sep 10, 2007 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Televison & Video Logo
289 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
