Question about Asko D1716 Built-in Dishwasher
Our Asko D1716 dishwasher functions to fill and empty but the pump which causes the sprayers to rotate and distribute the water does not function. The local appliance repairman diagnosed the problem as a bad pump (he called it a motor). Since the pump is a $400 part plus labor, is it possible that the problem is something else like a bad motor capacitor or relay? When the cycle calls for the pump to come on, there is no sound except for a very soft hum.
Hi !
Got a D1706 ( in 2002 ) paid $1000 and as os April 2010...same problem as yours, I will trow it away ( dishwasher ) and will never buy at such cost. I'll get a GE or LG.
Stupid Sweden dishwahers
Posted on Apr 18, 2010
I have an ASKO D1716. Once started, it does not stop. I tried the rinse cycle and it advanced towards to setting 2. But, it continued to operate long past its normal time limit. (I have two of the...
here is a site with the fault codes and how to check for them.
To start the trouble-shooting programme, press the
Temperature selection button five time within 15 seconds. code chart info click on the link below.. Jay
Asko D1796 Use And Care Manual Fault Indications
Feb 10, 2015 | Asko D1716 Built-in Dishwasher
When the cycle has finished and I open the door the washing tablet is sitting in the tablet flap that is open
Hello Vanessa,
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1716 and 2) filling with water, draining, heating, but not dissolving the detergent, it often is a busted wash impeller within the main motor/circulation pump.
Unfortunately the impeller itself is not serviceable, the entire motor/pump must be replaced if indeed it is broke.
Here's something you can try first though, this will indicate if the unit is circulating the water properly. Try placing both spray arms at 12 o'clock position and placing a cup upright in the top rack. If the arms move and the cup fills, you've got circulation...if neither, you don't.
Also be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet. Check those other possibilities first and tell me what you find.
I'll watch for your reply.
Regards,
Macmarkus :)
Apr 19, 2011 | Asko D1716 Built-in Dishwasher
It doesn't sound like the dishwasher jet arms are spraying water and the dishsoap was still on door at end of cycle.
Welcome to FixYa.
Based on your description and provided the dishwasher is indeed 1) an Asko D1716 and 2) filling with water, draining, heating, but not circulating, It sounds like a busted wash impeller within the main motor/circulation pump, unfortunately.
First though, do you hear a quiet sound of a motor starting once the unit has completed filling with water ? And be sure the unit is actually filling with water, this image below indicates the normal water level to look for....
The pump obviously it will be super quiet if the wash impeller is broke as I suspect it may be...almost like a fountain, since the Asko are very quiet under normal conditions. You will have to either get right down with your ear to the bottom or run it with the door open by activating the door switch with a screw-driver and look for visual/audible clues.
If so that is a tell tale of no wash action yet the motor runs, hence broken impeller. If you don't hear anything it may be a wire come off the main motor/circulation pump...but not likely.
This unfortunately is common with Asko built dishwasher`s and it is a case of being a victim of their own design.
What happens typically is the ball-bearings from the upper rack holders ( which are plastic, hence fatigues due to heat and fall apart ) come out making their way into the sump, hence breaking the wash impeller from the motor.
Let me know what you find and I'll try and help you move forward from there. If you need direction to remove the circulation motor and pump I can do that, but it is a pretty involved repair and requires pulling the unit from the cabinet...you may opt to call in a pro.
Regards,
Macmarkus :)
Jan 29, 2011 | Asko D1716 Built-in Dishwasher
DOES NOT FILL WITH WATER. TRIED DIFFERENT CYCLES.
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Aug 22, 2010 | Asko D1716 Built-in Dishwasher
Water won't spray
Sounds like whatever caused the clogged drain may also have clogged the sprayer arm.  If it is clogged it will not spin.  Remove the arm and if it is clogged see if you can clean it out.
May 29, 2009 | Asko D1776 Stainless Steel Built-in...
Insufficient water in the dishwasher for spinner arms to operate
If the machine functions properly when you add water, then it is likely there is a problem with the water supply. Start at the valve under the kitchen sink.
First I would turn that valve off and remove the water line. Then turn the valve on slowly. Use a small bucket or a large cup to catch the water. You should also have a lot of towels on hand.
If you are not getting much water through it, you may need to change that valve. If you are getting a good flow of water through it, inspect the water line checking for crimped or crushed parts. (is the line copper? braided steel?)
Reconnect the water line to the valve and disconnect it at the dishwasher. Now flush water through the line. how is the flow?
Lastly inspect the water inlet valve on the machine. I found a walkthrough for that at http://www.easyapplianceparts.com/repair.aspx?appliance=dishwasher&part=dishwasher-wont-fill
Actually, you might want to check that first. It may be as easy as cleaning a screen. I'm a plumber, not an appliance tech, so I tend to take a global approach to water supply.
Best of luck
Mike
Mar 25, 2009 | Asko D1716 Built-in Dishwasher
Asko D1716 won't start
Ensure the water is turned on and the door is fully closed, make sure delay start is not set.....
if DW still won't start, I would begin by checking the door switch.
This link will download the owners manual for your unit. Click here
to download the manual.
Hope this helps.
Please take the time to rate this solution.
Jan 31, 2009 | Asko D1716 Built-in Dishwasher
Viking (made by ASKO) Dishwasher Problem
You can find parts, solutions and manuals at link below. Hope this helps, Sea Breeze
Click below
http://www.retrevo.com/s/Asko-D1716-Dishwashers-review-manual/id/21338ci577/t/1-2/
Dec 18, 2008 | Asko D1716 Built-in Dishwasher
Dishwasher flooding
When you say that you tried other solutions.. it's hard to know which you've tried and which you haven't so I will suggest some basics first.. ( if you've tried them, then disregard)...
Have you checked or addressed the following:
  1. Cleaned the drain filter
  2. Checked the drain hose for crimps or restrictions
  3. Sure the drain system ( such as your feed thru the garbage disposal isn't clogged or restricting flow)
  4. Checked your water pump for an obstruction or you can determinbe if it is actually pumping
  5. The feed and returm hose ..to anf from the pump are not clogged, pinched or restricting flow.
These are the basics that you should have examined or confirmed aren't causing the problems you are seeing. One other as well.. are you sure your water inlet valve is completely shutting water from leaking in and over-filling the system? Check these items and you should be able to diagnose where the problem is.. Hope this helps you,
Sep 21, 2008 | Asko D1716 Built-in Dishwasher
Asko D1716 dishwasher problem
I also have an Asko D1716 dishwasher. The water stopped flowing. I replaced the water inlet valve and I have another problem, but the replacement of the fill valve is now letting in water. You can call Asko at 1-800-898-1879 to order the parts. If you order from Asko, I'm told you have some warranty on the parts. Anyway, the screws take a star drive and there is a front plate and back plate you will need to remove. There are approx. 4 screws on the front and 4 screws on the back. Just remember to unplug it before starting any work. The fill valve is in front of the machine. There are 2 screws holding it in place from the front. You will need to remove it out the back though to replace it since the fill tube to the tub is short and it wont allow you to pull it out the front. The repair is really easy once you get started.
Hope this helps,
Sargeantfod
Jun 11, 2008 | Asko D1716 Built-in Dishwasher
Asko D1716 Built-in Dishwasher Logo
217 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
