Question about Kenmore Washing Machines
Series 70 makes noise at the end of spin cycle when the brake sets it makes aloud rumbling noise.
    President:
  • 1,937 Answers
KENMORE top load, direct drive, neutral drain washers are made by Whirlpool.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
See the Sears diagram or the following Whirlpool Service manual
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The washer uses a brake system to stop the basket at the end of the spin cycle.
Just like a brake on a car, it's designed to slip a bit so that the basket / car doesn't come to an abrupt halt.
Over time, the brake shoes can jam against the brake drum and bring the basket to a halt too quickly with a lot of noise.
A way to solve this (that I tried and it works) is to pull the basket tube / brake assembly and if the brake shoes look OK, spray a small amount of silicone spray on the inside of the brake drum.
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Following are the Whirlpool Service manual for this type of washer and the Whirlpool parts list for their commercial washers although the consumer models are basically the same.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Posted on Nov 16, 2009
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
Oct 22, 2014 | Washing Machines
Noisy & will not progress to spin cycle
The tub must pump down before it will go into spin cycle. My pump was making rumbling noises and when I took the basket out (simple process) there were a couple of bobby pins stuck in it. (kids) Cleaned it out and checked the flowpath with a wet and dry vacuum on the drain connection. Still makes the noise. There is a small zip lock bag under the control panel that describes the trouble shooting and error codes. It also says how to go through the diagnostics steps. Hope this helps.
May 30, 2010 | Fisher and Paykel GWL11 Top Load Washer
Maytag Performa PAV2200 makes a rumbling sound while agetating. Suspect a worn bearing or belt? Could you shed any light on this?
Yes it could be the spin bearing at the base on top of the brake assembly. I would suspect that the brake assembly is the cause of the noise as this engaged when you the washer agitates. If it was the bearing it would make a loud noise in the spin cycle, too.
Nov 05, 2009 | Maytag Performa PAV2200
I have a kenmore 70 make ratchet noise ,will not
Probably bad lid switch. Your ratchet noise is normal during the wash cycle.
Mar 24, 2009 | Maytag PAV2300 Top Load Washer
Kenmore 80 Series washing machine - loud banging at end of spin
With the lid open, set the cycle to spin and press the lid switch button with a pen. Wait until the drum gets to full speed and release the lid switch. If the drum makes a knocking/ thumping noise and doesn't stop spinning within 2-3 seconds, the basket drive block is worn and needs to be replaced. (The basket drive block is located on the gearcase drive shaft, under the tub and agitator) If this has been happening for a long time you may need to replace the brake and drive tube assembly as well.
Basket drive block part number is 389140
If that's not it, let me know and I will try to help you further.
Mar 10, 2009 | Kenmore Washing Machines
Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
Spin cycle noise
pull up and down on your basket to see if it has up and down play in it
kind of rock it side by side too
Dec 30, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Nov 13, 2007 | Kenmore 22422 Top Load Washer
Series 70 Kenmore Washer Won't Agitate or Spin
baseball, sounds like a broken coupler, check out this post and post back, Catriver http://www.fixya.com/support/t144580-kenmore_8series_washer
Apr 26, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
113 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
