Question about Linksys WRT160N Wireless Router
Hi, i have linksys wrt160n router The laptop does not connect to the internet-"validating identity, Firewalled" . The laptop in Toshiba M30 series with windows xp sp1. Please let me know what to do. Thanks, Trishlyn
  • 742 Answers
Try to turn OFF your router. Do this bu pulling off the power cord at the back of the router.
Now dont start the laptop yet. After 30 secs you turn ON your router by inserting the power cord at the back of the router. When the lights are stable, turn ON your laptop. It should get connected to the router giving it an IP address.
If you still have the same problem, then your laptop's wifi settings might not be compatible with that of the router.
So, try to reconfigure your laptop's wifi settings:
1. Click Start => Settings => Control Panel
2. Locate and open Network Connections
3. Locate your "Lan Connection" used with the router
4. Right click on the Lan Connection and click Properties
5. Under wireless "Authentication" chose WAP encryption method.
Click Apply then OK.
If this doesn't help, try the same steps and change WAP to WAP2 or simply chose the encryption method in the combo list (ONE AT A TIME) that fits your routers default settings.
Posted on Nov 16, 2009
    Guru:
  • 1,738 Answers
Upgrade to SP2, and install ipx/spx and protocl as well
If the wireless router is connected to the PC
You are using WRT160N router. This router has issues with the firmware.
Try to upgrade the firmware of the router. Firmware is the software of the router.
Download the latest firmware of the router. Go to the manufacturer's web site and download the firmware of the router.
Open the set up page of the router and upgrade the firmware of the router. Once you upgrade the firmware of the router, reset the router.
On the router you will find a small reset button, hold it down for 30 seconds. release it. wait for 1 minute. Now unplug the power to the router and plug it back in.
Now you will need to reconfigure the router according to the Internet service provider.
May 17, 2010 | Linksys WRT160N Wireless Router
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
Cannot connect wirelessly to my Linksys WRT160n, but wired works
Get Network Magic ... download for evaluation.
This is a tremendous network management tool well worth the $. If you dont pay, you can still use most features.
Get it and use it to get your connection going at least.
Let me know what happens
a
Oct 01, 2009 | Linksys WRT160N Wireless Router
Laptops stopped connecting wireless
how about to reset your router and setup it the proper address by your internet provider..
laptops only connect to the router automatically if you enable it reconnect and detect its network without manually connect internet, this procedure can see in your wireless properties by enabling it.
And also ask your internet provider if theres a problem also with their internet connection.
Jul 18, 2009 | Linksys WRT160N Wireless Router
Linksys router 160N will not work.
You probably have encryption turned on in the router, as you should... But your wireless NIC in your laptop may have the wrong settings for encryption set... Compare the two and change your NIC to match that of your router... You may have to know the passphase or password depending on your level of encryption... If by entering a valid IP by hand and it still did not work, may mean that your DNS server IP address(es) werent set correctly, you should use the router's IP address as your default gateway and primary DNS server IP address, since most likely your router is connected directly to your ISP modem... Hope this helps!!
--Joshua79
Apr 04, 2009 | Linksys WRT160N Wireless Router
PC will not connect unless Laptop is turned on?
first reset the connection, and try to connect the pc with switch and when net start working the connect the laptop
Mar 11, 2009 | Linksys WRT160N Wireless Router
Router installation
THis can be a problem with the wireless settings of your router, I believe your laptop is trying to connect wirelessly to your router, This can be solve by accessing the router setup page and do some changes on its wireless settings settings like the SSID and the most important one the wireless security..If you're not familiar on how to do that I will advcie you to call LInksys tech support so one of their tech can walk your through with that process, they are open 24/7 this is the number 800-3267114.......
Hope that helps.........
Sep 16, 2008 | Linksys Wireless-N WRT150N Router
Linksys WRT160N Wireless Router  Logo
514 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
