Question about Frigidaire ATF6000ES Front Load Washer
When you open the door there is an odor that come from inside the wash tub
    President:
  • 2,702 Answers
This is due to the build up of scum in the washer pipes the best thing to clean it out with is bleach ,,,do a cold/hot water wash with nothing in the washer only a strong mix of bleach, when the wash has finished do another cold/hot wash again this time with only water in the washer to flush out any bleach left in the washer then leave the door open a little when you have finished your washing from then on,this should kill of any more nasty smells
Posted on Nov 16, 2009
Want to remove odor from dryer
Hi photoed1
The odor that you are experiencing may be from the growth of mold.
Inside the washer, some small pool of water may be left standing and is harboring mold spores.
Even though you may operate the washer regularly, the mold spores are not being washed away.
Here is a couple tips that might help to eliminate odor issues in your washing machine.
First, and the most effective is to, leave the lid or door to the washer open.
By leaving the door open, it promotes air circulation and evaporation of standing water.
The reduction in odor occurred quickly and dramatically.
Another tip is to run the washer empty for a quick rinse cycle.
Add an entire cup of bleach at the start of the cycle.
The bleach is effective at destroying organisms, such as mold and bacteria.
However, running it once will not be completely effective.
I suggest pouring another cup of bleach into the wash tub, after the cycle has completed.
This will leave bleach as the standing pool and should prevent the growth of mold or bacteria.
However, if you do this, before doing a load of laundry you should run an empty rinse cycle again,
to avoid damage to the clothes from the bleach left standing in the wash tub.
Please take time to rate me
Bud
Apr 18, 2013 | GE Dryers
My front loading washing machine has a musty odor. what can I do?
The odor that you are experiencing may be from the growth of mold. Inside the washer, some small pools of water may be left standing and is harboring mold spores. Even though you may operate the washer regularly, the mold spores are not being washed away.I have a couple of tips that might help to eliminate odor issues in your washing machine. First, and the most effective in my research is to, leave the lid, or door to the unit open. By leaving the door open, it promotes air circulation and evaporation of standing water. The reduction in odor, will occur quickly and dramatically.
My second tip is to run the washer empty for a quick rinse cycle(on hot water cycle). Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
  • Additionally, inspect the door gasket for gunk or mold. Clean the gasket well. This is another gathering spot of bacteria and mold growth.
Jun 28, 2010 | Kenmore Washing Machines
Stale odor within tub
Front loaders are known for building up mold and the smell.
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
Dec 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
The inside of my washing machine smells
Regular cleaning maintenance is required to prevent odor build up inside the machine. The LG WM2688HWM has a TUB CLEAN feature, a special cycle for the cleaning of the inside of the washer. This cycle uses a high water level with higher spin speed.
  1. Remove any clothing or items from the washer and close the door.
  2. Open the dispenser drawer and add liquid chlorine bleach ONLY to the bleach compartment.
  3. Close the dispenser drawer slowly to prevent the bleach from spilling.
  4. Turn on the machine then press the EXTRA RINSE button for 3 seconds.
  5. Press the START/PAUSE button to start.
  6. Leave the door open to dry the washer door opening, door seal and door glass after the cycle is complete.
Dec 02, 2009 | LG WM2688HWM TROMM SteamWasher
Washing Machine Stinks
My second tip is to run the washer empty for a quick rinse cycle. Add an entire cup of bleach at the start of the cycle. The bleach is effective at destroying organisms, such as mold and bacteria. However, running it once will not be completely effective. I suggest pouring another cup of bleach into the wash tub, after the cycle has completed. This will leave bleach as the standing pool and should prevent the growth of mold or bacteria. However, if you do this, before doing a load of laundry you should run an empty rinse cycle again, to avoid damage to the clothes from the bleach left standing in the wash tub.
Nov 21, 2009 | Dryers
Clothes dont smell clean after washing them
Oct 25, 2009 | Maytag Washing Machines
I have a strange odor
It is normal for all models of washing machines to have a gallon or two of water left inside the bottom of the washer and in the drain pump. This is not the cause of odor. The smell is being caused by residue left on the inside of the plastic outer tub.
The best way to clean a stinky washer is to use a washer cleaner that is able to be used with clothing in the washer. The added bulk of the laundry will raise the water level to include the splash area 3-5 inches above the normal waterline. This splash area always has the worst buildup.
After the odor is gone you'll need to change washing habits to keep it away.
Oct 19, 2009 | Washing Machines
Odor coming from inside washer
There is a tub beyond the tub you see. Run a load of water with chlorine bleach. This will kill the mold & mildew spores that are causing the odors. ****Do NOT add clothing to this washload****
If possible, keep the door open when not in use. This will allow the inside to dry and mold & mildew cannot grow.
Jul 02, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Bad odor
glisten and affreash is the cleaning agents
besides this only way to get smell out is a complete inner and outter tub job but also try leaving both soap dispenser and door open for the air to dry up and vent the washing machine
Feb 24, 2009 | Frigidaire FTF2140E 3.5 Cu. Ft. Front...
Maytag HE 4t/ Kenmore Elite Smartwash Serial# CST0411376 MODEL# 11045088403 TYPE 199 712 CN/AP MY WASHER HAS A AWFUL ODOR INSIDE THE TUB. I HAVE CLEANED IT OUT WITH ALL KINDS OF CLEANERS TO TRY...
The following link provides guidance on how to maintain a front loader to keep the mold, mildew and odor away:
http://www.fixya.com/support/r513372-front_loader_mildew_odor
These are recommendations provided by the manufacturer. Most important of all, keep the rubber bellow clean and clear of debris and make sure you leave the door slightly open when not in use. This will minimize the build up of any mold or mildew and allow the tub to air out. The odor typically comes from the the residual water that stays in the wash tub under the basket and small articles of clothing getting stuck in the rubber folds of the door bellow. (I once found 17 socks stuck in a customer's washer and they wondered why it smelled so bad). NOTE: It is NORMAL to have residual water in the wash tub. If you do not routinely use a hot water setting, run the washer on a sanitary cycle about once a week, or so, with a small amount of bleach to get rid of any bacteria. Since some users conserve and only wash in cold water, they do not bacteria get rid of any bacteria inside the wash tub. I personally own one of these washers and have never had any odor or mildew problems in 8 years by following this simple advice. If you have any further questions/concerns please let me know. I hope this helps you.
Aug 06, 2008 | Washing Machines
Frigidaire ATF6000ES Front Load Washer Logo
62 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
