Question about RCA F25432 25" TV
Tuner connection broke - RCA F25432 25" TV
  • 83 Answers
Set tuner cap re solder with tuner fix this problum solve esyly but don,t fix it your self if your not tv.techician.becous it is a dengerus for you.
tv. tuner is not costly.
Posted on Nov 16, 2009
The coaxial connector broke off of my Apex LD3288T tv. I removed the back panel and I can not see how to re-connect the coaxial connector. Does anyone know how to repair this?
Its part of the tuner in most cases and not real easy to replace for a novice---sometimes the tuner will have to be replaced as when it broke off it may have damaged the circuit board inside the tuner.
there is a possible way around this: With a box of any kind being used that has the Audio/video jacks for output of signal you run cables from them to a set of matching inputs on the rear of set, leave set on that input and change channels with the box--bypass the tuner completely.
If the tuner and board it is only sold as a complete unit it will be expensive to repair.
Dec 22, 2012 | Televison & Video
Antenna in broke off
Consider getting a box (cable or satellite) with video outputs and running those into the same type inputs on rear of set--bypass the connecter on the rear of the set.
Most modern sets the coax fitting is part of the tuner and if broken off the entire tuner would have to be replaced in most cases--not cheap and some models tuner is only available with a board.
Over 200 if the board has to be replaced or route signal into a rear audio/video input on the set?
The cabe connection going into the back of tv broke, can this be fixed
Often they can be resoldered depending on how it broke, If not the Tuner may need replacement. Tuners and signal boards are available from www.tvrepairworld.com
Mar 21, 2011 | RCA Televison & Video
My coaxial connector broke off. i have a new F connector now but i dont see where to solder it on to. can you help me find where i should solder on the f connector?
The connector needs to be soldered in two ways. The center connector needs to be soldered to the same point as the original. This may have broke off close to the small circuit board inside the tuner and you hopefully can see the broken piece sticking out. The tuner should ideally be removed to accomplish this. The tuner usually has two shields that snap in place that can be removed. You may be able to solder a short piece of wire to the remainder of the original connector. The outside of the f connector also needs to be soldered to the tuner shielding itself as a ground connection and you will need a soldering gun or higher wattage iron for this step. Use a lower wattage soldering pencil for the signal connection to the tuner board.
Nov 18, 2009 | Televison & Video
My cble connection is broke how can i replace it
In most cases, this requires soldering a new RF connector into place. Otherwise, the tuner will need replacing. Good luck.
Aug 09, 2009 | Symphonic ST420FF 20" TV
TV ANT Jack Broke off and lost cable viewing
Yes it can be replace only if it just a connector adapter connected independently unto tv tuner. But if it is with the tv tuner as a whole. You will replace the entire tv tuner. Just bring the part as reference to your favorite electronic store selling tv parts.
Apr 11, 2009 | RCA Alert Guard 20" Flat Screen 20F670T...
The coaxle broke where you put the cable line on
The coaxial connects inside the set to the tuner. It needs to be resoldered in to the board & secured on the outside to the tuner. Its a quick fix at any tv repair shop. Unless u tried stick something inside & damaged internals of tuner
Apr 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV input on the back of the unit broke cant connect coaxial cable
Try entering the model number on website below, they do worldwide delivery, and have one of the biggest database of replacements.
Appliance parts, electronics parts & more from PartStore.com
Feb 18, 2009 | ViewSonic N3251w 32 in. LCD HDTV
Cable connection broke off
yep if you can desolder the tuner with solder braid then put new tuner in resolder it thats it
bc
Feb 02, 2009 | RCA F32650 32" TV
it can be repaired.otherwise replace tuner
Nov 25, 2007 | Sanyo DS25390 TV
RCA F25432 25" TV Logo
49 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
