Question about GE JTP20 Electric Single Oven
I need to buy a replacement of 326B1230P001 GE double oven. Will other brand, e.g. Whirlpool?s with the exact dimension work? Any difference in voltage requirement?
  • matlock_mich May 11, 2010
    Most likely not. all ovens are 220 volts.
fridgetech
  • 473 Answers
SOURCE: 326B1230P001 GE double oven
You can go to http://www3.sears.com/ or http://www.appliancepartspros.com/. You will need the complete model # from the sticker on the oven. The # listed above is not correct. It looks like a serial #.
Posted on Nov 07, 2007
  • 5 Answers
SOURCE: 326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Posted on Aug 01, 2009
SOURCE: ge electric oven not working. displaying a s8
F8 means main board failure. The model number you gave is no good.
oven repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 08, 2010
SOURCE: GE double oven model JKP27GOJ1BG. Need oven and
www.homedepot.com/.../fc8b05c7-8537-430b-b27d-0d3df543bbd8.pdf - United States
Above is for the 24" Below is the 30"
products.geappliances.com/MarketingObjectRetrieval/Dispatcher?...31...
Hi this website above will supply you with the info you require, it has drawings and dimensions to assist you to do your cutout.
Posted on Aug 19, 2010
jumptrout51
  • 3361 Answers
SOURCE: GE profile oven 326B1230P001
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Posted on Sep 05, 2011
Dimensions of whirlpool wall double oven Mod. rbd275pdb12
Sears Parts Direct has the Installation guide for the Whirlpool RBD275PDB12 here: https://www.searspartsdirect.com/partsdirect/user-manuals/rbd275pdb12-whirlpool-parts-manual . The recessed dimensions are 49 1/2" high x 25 3/8 wide x 23" deep. The visible portion of the double oven is 51" high x 26 3/4" wide. The dimensions of the Whirlpool double oven are given on page 2; below the oven dimensions, you will find the dimensions for the cut-out box to ensure proper air circulation around the double oven. The direct link to the guide is currently https://c.searspartsdirect.com/mmh/pd_download/lis_pdf/INSTL/L0409153.pdf .
I hope this helps.
Jun 06, 2018 | Whirlpool Ovens
Fridge inline water filter
I assume you have an external filter, and you want to replace it? I'd buy an exact replacement and it should have instructions. All filter's seem to have different connection methods. If you don't want to replace, you can cut the tubing and connect the tube with a splice or compression or similar type of "splice" Talk to your friendly hardware source.
Oct 09, 2015 | GE JRP28SKSS 24" Double Electric Wall Oven...
Control board harvesting
No, the parts aren't the same. The W2BB model has this code for that same part WB27T10283, while the A2BB model has this code for that part WB27T10292. The parts Look exactly the same in the diagrams, however in my past I have discovered the hard way that connectors and things in the circuitry are often different even if they fit. They're pretty pricey too 250 bucks or so...good luck!
Sep 01, 2012 | GE JTP45 Electric Double Oven
GE profile oven 326B1230P001 error code F7 will not go off. what does it indicate?
Sep 05, 2011 | GE Profile JTP18 Electric Single Oven
I have a 326B1230P001 GE Double oven that displays ?F7? and beeps?..have cut power to it to try to reset it but it comes back beeping and the display goes through different changes by itself?.what is wrong...
F7 stuck keypad
Stuck keypad may mean relay is turned on.
Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jul 30, 2009 | GE JTP45 Electric Double Oven
Jul 30, 2009 | GE JTP20 Electric Single Oven
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
Jun 21, 2008 | GE JKS05 Electric Single Oven
Nov 06, 2007 | GE JTP20 Electric Single Oven
GE JTP20 Electric Single Oven Logo
622 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
