Question about HP Compaq EVO N180 Notebook
Had problems with my compaq EVO N 180. Hp suggested I upgrade bios. During upgrade computer seized. Now it will not start. HOw can i jumper the bios.
  • 458 Answers
You can attempt to reset Bios By Pulling the CMOS battery, you will need to disassemble laptop, Not sure offhand if you have a plug in battery or one thats soldered on... Basically in a laptop there are 3 main types of Cmos battery connections.. 1 is plugged in to the motherboard using a 2 wire plug... 2 is a battery tray on the motherboard that the battery snaps into and out of... 3 is a battery that is soldered to the motherboard from both the positive and negative sides....
With any 3 of these.. You need to remove the battery... HOLD the power button (make sure your laptop battery is removed as well and unplug the AC Adapter... )
Then Reattach CMOS Battery and reassemble and attempt to power on
Note: The Soldered On Batteries Can Be Desoldered and removed...
Do Not Remove the solder from the contact points!! You need to use a pointed flat tool and your soldering gun... Use your tool to pry the battery away from its connection pad... To Do This, First Heat the soldering gun, carefully heat the 2 contact pads of the CMOS battery, as your heating them get the solder to melting point and then quickly pry the battery off the board, heat the 2 connection pads again and pull the battery away from the motherboard.... You should have the 2 contact pads still with solder left on them...
Posted on Nov 16, 2009
How can I change boot sequence in Compaq Evo N410c?
You need to access your BIOS configuration. 1. To do this, shutdown your computer and boot it by pressing the power button. 2. You need to hit F10 when the computer first powers up in order to get into BIOS (Note that the key is usually different for different computers. If F10 doesnt work, try F2, F12, Delete or F9. 3. Once in the BIOS, you should find the boot sequence option.
Hope this helps!
Apr 11, 2011 | Compaq Evo N410C Notebook
"1801 Microcode patch error. Missing
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=12454&prodSeriesId=96295&prodNameId=97121&swEnvOID=1093&swLang=13&mode=2&taskId=135&swItem=PSG_I15378-37635
And follow the instructions here to upgrade the BIOS. I suggest using their instructions as they will be far more accurate than mine for this specific system and BIOS update.
Feb 10, 2011 | Compaq Evo D500 PC Desktop
I have faced a problem on Compaq Evo W4000 that there is an error i.e 1801 microcode patch error so how i can remove that error
Give a try to update BIOS. Click here and follow the intrsuction
  1. Obtain a formatted 1.44-MB diskette and place it in your A: drive.
  2. Download the SoftPaq to a directory on your hard drive. The file that is downloaded is an executable with a filename based on the SoftPaq Number above.
  3. From that drive and directory, execute the downloaded file and follow the on-screen instructions to build the ROMPaq diskette.
  4. Place the newly created diskette in the A: drive of the computer to be upgraded or restored and cycle system power to boot from the ROMPaq diskette.
  5. Follow the on-screen instructions to select the Compaq System ROM and flash the firmware. WARNING: DO NOT TURN OFF POWER OR ATTEMPT TO REBOOT THE COMPUTER DURING THE UPGRADE PROCESS!!!
May 10, 2010 | HP Compaq Evo w4000 PC Desktop
Hi we have had a power spike and I have had to flatten and rebuild our Compaq EVO 310. This resulted in losing the drivers and then finding out that my partner does not have the original compaq disks for...
hello: the drivers you need can be download on hp /compaq site and reset the bios you can take battery out and the bios are back in standaard settings with startup you can make your own settings again
Nov 04, 2009 | Intel Compaq EVO D500 (RBMDTCPQP42400) PC...
Bios ROM checksum error (Compaq SR5237CL with M2N68-LA MB)
A BIOS checksum error can be caused by a nearly flat BIOS battery.
I would replace the BIOS battery first before attempting to upgrading the BIOS.
Some motherboard BIOS firmware is upgraded by running a program that has been copy to a DOS boot disk or the upgrage maybe done from within the BIOS setup. These firmware upgrage and instructions are on the motherboard WEB site, in your case the Compaq/HP WEB site. Make sure you select the upgrade for your model motherboard.
NOTE it is possible that if you make a mistake you could ruin your motherboard, if you are not sure seek help from a computer savy friend.
Use this link :-
http://h18000.www1.hp.com/cpq-country/cpq_support.html
Sep 17, 2009 | HP Computers & Internet
Blue Screen of death
According to this link, the memory of Compaq Evo N610c can be upgradable to 1024 mb.
http://h18000.www1.hp.com/products/quickspecs/11382_div/11382_div.HTML
Memory Upgrade for Compaq Evo N610C, the Compaq Evo N610C takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with of Memory. You can upgrade your Compaq Evo N610C to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with standard Memory installed. For best system performance use the maximum amount of allowed Memory per slot for your system. (Souce: http://www.memorystock.com/memory/CompaqEvoN610C.html)
So you have to install 512mb memory module on each slot to make up 1024mb of memory.
Did you install 512mb memory module on each slot or did you just install 1GB memory module in one slot?
Try to go back to 256mb RAM and see if you will have the same blue screen error. If you did not receive any blue screen, try to add memory into it or just insert 512mb first and then oserve again if you will have the blue screen error.
You may also want to go to these links for other suggestions.
http://www.pcfixreview.com/blog/2007/07/12/bad-pool-caller/
http://www.registrysimple.com/bad-pool-caller-fix.php
May 08, 2008 | Compaq Evo N610C Notebook
1801 Microcode Patch Error
I bought a Compaq Computer, 2.0Ghz, 256MB, 20GB for my College project. When i put the power on, it restarts almost immediately (so many times repeatedly). Then after such reboots, it successfully brings a message "1801 - Microcode Patch Error" and a F1-Boot directive.
Mar 20, 2008 | Compaq Evo D500 PC Desktop
Upgrade 238622-001, Compaq Evo T30 Thin Client 300Mhz 32MB Flash/64MB/Win CE NET/IE 5.5 w/o
You need to replace the 2mbit bios chip used by the WinCE Evo with the 4mbit one used by the NTe and XPe Evo, then you need an add on flash module, since the onboard flash is too small. After that, just find the OS file and flash away. You can find the OS files and a utility to flash from the HP support site. You'll need a crossover ethernet cable, not a patch cable, to do the flash.
Jun 25, 2007 | Compaq EVO T30 Network Terminal
HP Compaq EVO N180 Notebook Logo
151 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
