Question about Danco 89448A Universal Toilet Tank Lever, Chrome with White Porcelain Handl
After flushing it will sound like it is filling up again and then shut off again and then it mght repeat the same thing again after awhile.
  • Mike Linderman
    Mike Linderman May 11, 2010
    Sounds like you have the flapper chain that connects to the trip lever too tight it needs a little slack in it or your flapper is worn
  • 317 Answers
Lower the float a small amount...make sure flapper is closing completely
Posted on Nov 17, 2009
How to flush power steering
Suction the fluid out of the fluid reservoir and fill with clean fluid then run the engine and turn wheel from left lock to right lock, shut down and repeat fluid replacement in the fluid reservoir, do this about 4 times and the system will be flushed. Never run the system with no fluid, the new fluid is the flushing agent, it is very detergent.
Nov 11, 2016 | Cars & Trucks
How do you adjust the clip so the water level increases?
You don't adjust the clip as it attaches to the pipe to automatic turn off the water at the right level, but your water may be set at to high a level that it overflows into the bowl. When that happens you can do 2 things to correct it: 1 at the wall where the cold water comes out to the toilet you can adjust it to slow the supply of water to a little less. 2. You can adjust the screw inside tank to tighten (turning screw one way) to adjust water level to shut off quicker or adjust tank screw the other way to fell take water up higher. Flush the toilet and observe the power of the flush. Allow the tank to fill until the water shuts off. Repeat the procedure to adjust the float and water level, if desired.
Apr 26, 2014 | Plumb Craft Waxman 7030700T Perfect Flush...
My machine will not work. It makes a clunking sound when I try to run it. What is wrong?
it could be the timing, or it mght need a adjustment, or could have
a loose or broken part,, it would be a good idea to have the
machine serviced
Jan 07, 2013 | Simplicity SE3 Computerized Sewing Machine
Need to flush and fill cooling system
You just drain coolant from radiator & replace every 3 years
Flushing is done at a repair shop & is not necessary
You can fill with water ,run awhile & drain again, to accomplish
the same thing
Oct 05, 2012 | Cars & Trucks
Coolant level ok no leaks new 195 deg. thermostat still very little heat from heater defective heater core?
I am assuming your vehicle has the pink antifreeze called Dexcool. This is the recommended coolant for all late model GM cars and trucks. This coolant tends to form a pasty sludge in the cooling system which can lead to overheating and/or plugged up heater core. Try flushing the cooling system with a good aftermarket product such as prestone radiator flush. First thing to do is drain all the pink coolant, then add the radiator flush and fill with plain water. Run the engine according to directions on the flush container. Drain the radiator again and refill with plain water. Run the engine for a few minutes and drain again. Keep repeating this until all the pink antifreeze has been eliminated. Fill the system with 2 gallons of green antifreeze. Make sure the antifreeze container says it is compatible with aluminum engine parts. Hope this helps. If it does, then you won't have to replace the heater core.
Dec 16, 2010 | 1999 GMC Sonoma
You can squeeze my radiator hose and feel it cracking. So i took it off and broke it lose and it was coated around the whole tube. Now one of my friends say's he thinks it's liquid glass.. My radiator cap...
Someone may have put some sort of stop leak in the radiator before you bought the car. Drain the coolant, flush the system, replace the thermostat, and fill it with a 50/50 mix of the approved antifreeze and distilled water. Be sure and bleed all air from the system.
Oct 12, 2010 | Chevrolet Impala Cars & Trucks
We have an brand new Cimmaron two piece. It has only been in for a week. Twice the tank emptied compeltely on a flush and did not refill. We have to fill the tank manually to get things working. Once we do...
Sounds like the fill valve may have something stuck in the part that makes the water shut off. This can cause it not to refill as it doesn't let the inner mechanism work as it should. If your home is a little older and depending on the piping in the home it is possible in the change that some debris passed through the system when the water was turned on. Another possible issue is that when attaching the water to the tank the fill valve was turned to where the float for the mechanism is jammed against the side of the tank and is not moving freely with the water. If this is the case then the entire body of the fill valve will need to be twisted so the float can move freely. Aside from these things, you may want to simply replace the fill valve to avoid any further complications or issues. Don't worry, anyone can do it and is only about $10 to do. I recommend Fluidmaster brand, they come with really good instructions.
Aug 18, 2010 | Kohler Cimarron Comfort Height elongated...
The tv shuts off by itself. I will turn it on..and after awhile, it just turns off by itself, and then after about a minute I can turn it on again and watch tv for awhile, and then it will do it again.
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The faulty component(s) are heating up, tripping the fault control, and shutting down, it cools down again,and will restart, then the process repeats, it will eventually fail fully.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done. It is that sound that gives it away, this is a typical switchmode Power Supply problem.
Mar 04, 2010 | Televison & Video
Kenmore Dishwasher 5871525 stops running after a few minutes
sounds like a stuck key pad since you said the normal wash button flashed.. the other thing is try holding the door shut while you run it.. to see of it is maybe not latching properly..
Apr 10, 2009 | Kenmore 15762 Dishwasher
Washer Pauses and Shuts down Repeatedly
Check the cold water line into the unit. Remove the hose from the washer and clean the screen. flush the line while it is disconnected into a bucket or small garbage can. Your washer wont advance without a fill and most fills/rinses are with cold water
Dec 01, 2008 | Frigidaire Affinity ATF7000E Front Load...
Danco 89448A Universal Toilet Tank Lever, Chrome with White Porcelain Handl Logo
109 people viewed this question
Top Danco Home Experts
Donni Steen
Andrew Bugbee
richie46
Are you a Danco Home Expert? Answer questions, earn points and help others
