Question about Rowenta Commercial Garment Steamer - White
Need instructions for Rowenta garment steamer, Model IS1425. Their website has steam irons, steam generators and many other products, none of which are this small garment steamer. May sound silly to need instructions, but more steam is coming out of the water resevoir than down the hose and out the nozzle onto the clothes. (I don't know if this the Rowenta Commercial Garment Steamer - White, but it wouldn't let me enter anything else!)
SOURCE: rowenta commercial steamer
got this off the manual for the IS 7800
CLEANING
Remove water container and clean the main unit with a damp
cloth. To maintain maximum performance, your steamer must
be descaled occasionally. The descaling intervals will depend
on the water quality and the frequency of use. The unit should
be descaled at least once a year or every 100 hours of use.
For descaling proceed as follows:
1. Unplug the unit and remove water container from main unit
by releasing container lock and pulling up.
2. Fill it with fresh water and shake vigorously to remove any
scale. Pour out the water and repeat if necessary.
3. Purchase a quality decalcifier agent and follow the instructions
of the manufacturer for the proper ratio of the mixture
to water and use.
4. After filling the water container turn it up and down to
descale.
5. Attach reservoir to unit, plug in and switch on.
6. Let the appliance run until the water container is almost
empty and do not steam any clothing with this mixture.
7. Unplug and detach the water container. Rinse it with fresh
water.
8. Fill water container with fresh water and repeat steps 5 and 6.
Note: If after descaling you believe that there is still buildup in
the boiler, repeat steps 1-8.
Posted on Oct 31, 2008
laura_b1215
  • 15 Answers
SOURCE: Re Conair garment steamer ctx12c
check out www.HandBookLive.com for a video manual under Appliances category (both GS4 and GS10 models have videos and show how to attach a hose in a Quick Start chapter- I am just not sure about the model you are asking about. It could be different
Posted on Nov 05, 2008
SOURCE: My Rowenta Garment Steamer will not steam up.
I had the same problem and noticed that there is a small plastic piece that pushes into the water reservoir to release water into the boiler. Mine broke off, and no water leaves the reservoir into the boiler. It looks like suspect design to me, and I havent found a replacement part but I may try to epoxy the piece back on to solve the issue (I hope)
Posted on Apr 23, 2009
  • 26 Answers
SOURCE: Is there a product to run through a rowenta pro
To start with, use distilled water for steaming. This will prevent calcium build-up. I buy bottles of distilled water for ironing/steaming only. I have never had calcium build-up from using distilled water for ironing/steaming. Do not use tap water!!!
You can buy some CLR (stands for Cacium, Lime & Rust) (can be found at Walgreens, CVS, Target, Walmart, etc.). You can run this product through your steamer to eliminate build-up.
Posted on May 19, 2009
SOURCE: on and off petal switch not working
When I took mine apart I noticed the switch had melted near the contacts. This makes me not want to fix it, but instead, look for a better model. Hope this helps.
Posted on Jun 13, 2009
Rowenta pressure iron and steamer model DG5030? We have purchased the iron and cord, now we need to assemble the part.
Google Rowenta and go to their website, they will have parts diagrams and wiring diagrams. Hope this helps, please post solved on fixya.com. So I get credit for a solved problem if it does.
Apr 30, 2014 | Irons
Rowenta garment steamer is 9100 lights up but no steam
Look at the manual again maybe theres a button that you have to turn on. Or call the nearest repair man maybe he knows or can tell you.
Dec 26, 2012 | Rowenta Commercial Garment Steamer - White
ROWENTA IS8050 INSTRUCTION MANUAL
Rowenta IS8250 Garment Steamer instructions are no longer available from Rowenta.
May 28, 2012 | Rowenta Commercial Garment Steamer - White
ROWENTA STAM IRON - NO STEAM !!!!
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 22, 2010 | Rowenta Commercial Garment Steamer - White
Need replacement water tank due to a crack that leaks for the Rowenta 8050 steamer
krups bought out Rowenta. contact them at http://www.krupsusa.com/ to see if they have the parts or know where to get them
please take a moment to rate this solution. thanks
robert
Nov 23, 2009 | Rowenta Commercial Garment Steamer - White
Is there a product to run through a rowenta pro garment steamer to eliminate build-up?
May 14, 2009 | Rowenta Commercial Garment Steamer - White
Rowenta Commercial Garment Steamer - White Logo
126 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
