Question about Ricoh Aficio 1515MF All-In-One Laser Printer
I HAVE A RICOH 1515MF ANS THE PRINTER LIGHT TURN TO red and there is a flashing green light 2 inches below it
  • 192 Answers
Press the printer button, it will tell you on the screen what the problem is. Generally it is because your computer is telling the printer that it wants to print on a size paper that you don't have loaded in the machine.
Posted on Nov 16, 2009
Red light of ricoh sp200 is parmanently on
Red light all time when ink is finished and refilled it.
Feb 25, 2014 | Ricoh Aficio 1515MF All-In-One Laser...
I've super G3, print comes light and very very light 2 inches from left. pl help
Print the copy counter of the machine, check if the life of the drum unit is already reached. If the drum is ok, then you have to clean the laser unit. maybe dirt is blocking the light coming from the LD unit.
Apr 12, 2013 | Ricoh Aficio 1515MF All-In-One Laser...
Panasonic tv PT50LC13 has no picture red light flashes when i turn it on green light flashes and turns off
This model was recalled by Panasonic-----massive recall. Start by having the lamp examined or tested---that is the place to begin.
Oct 17, 2012 | Panasonic Televison & Video
How do you scan with the Ricoh Aficio 1515mf. I don't have instruction manual.
scanner button, put the document and choose the user. In the end you click on the green button to start
Jan 11, 2011 | Ricoh Aficio 1515MF All-In-One Laser...
There is a little green light that is flashing when I try and print certain documents.. Is this the error warning? Also it is telling me to replace my photoconductor, would this be the reason it is not...
The flashing green light means that the machine is receiving the print data that you are sending when trying to print. Depending on how the dealer set up the machine, yes it will shut down and stop printing when the "replace photconductor" indicator comes on. You will either need to order a replacement unit or have a local service guy come out and reset the counters. If you order your own unit, it will come with installation instructions and they are designed to be end user replaceable.
Good Luck and Thank You for using Fixya
WheatlandServices
Nov 18, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
I have ricoh 3030 model printer ,it pings both side but can not print . However it is good with LAN.
See if you can web into it with the ip address. If you can the login is admin and there is no password. Check the configuration and make sure your ip and subnet is correct. If that is good have someone watch the machine while you send a test page to see if the print light ever comes on. If the print lite flashes but nothing comes out, you may have "user codes " turned on....turn user codes off.
Feb 13, 2010 | Ricoh Aficio 1515MF All-In-One Laser...
HOW TO REBOOT RICOH AFICIO 1515MF??
need to enter service programs print out 5990-2
then exe 5801 memory all clear
put all the settings back to where the were set
the printout will show you default and current settings
Nov 10, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
The red light is blinking and it doesn't print.
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem.
Oct 02, 2009 | Kyocera FS-920 Laser Printer
Ricoh aficio 1515mf photoconductor reset
Found some information here:
http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
Try the following
press the yellow “C” button
enter 107
press the red “C” button and keep it hold till the display changes
turn the power off with the big red switch on the front side
turn power on again.
OR
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
Jun 01, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio 1515MF All-In-One Laser Printer Logo
283 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
