Question about LG KC910 Renoir Cell Phone
I want download video ring tone - LG KC910 Renoir Cell Phone
How do I change ring tone samsung gt s5830
You should just go into Ringtones, and select the downloaded tone as the default ringtone.
Mar 05, 2012 | Cell Phones
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
How do i mute ringing on my e71?
To mute the ringing tone instead of answering a active call,select Silence.
or u can try the following
To set a mute ringing tone for a profile, select Options >
Personalise > Ringing tone. Select a ringing tone
from the list, or select Download sounds to open a
bookmark folder containing a list of bookmarks for
downloading tones using the browser. Any
downloaded tones are saved to Gallery.
To play the ringing tone for a selected contact group
only, select Options > Personalise > Alert for, and
select the option similar to none,etc...
May 24, 2010 | Nokia E71 Smartphone
I download musics on Motorola. i want to use musics download as my ring tone. how? i need steps to use music downloads as ring tone
Go onto the music download and click on it then before playing it look at the options they'll either be "set as" or settings. Go on settings or set as and set it as ring tone. If this doesn't work or them options don't appear go onto your main menu and go on either settings or if your phone has one a ring tone setting. Then go onto sound settings. Then click on it and on there should be your downloaded music NOTE: Make sure it's on your phone not stored on your memory card.
Hope I helped Dr Reed
Apr 05, 2010 | Motorola Mobility RAZR V3i Cellular Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Ring tone downloading methed
  1. Have your ringtone downloaded into your PC via some internet site, or else.
  2. Now connect your phone to the PC via one of the methods: (Bluetooth,IR,Cable). You might be having a cable that was included in your sales package.
  3. You can then transfer the ringtone.
Jul 13, 2008 | Nokia N70 Cellular Phone
NEED TO CHANGE RINTONE AND HAVE LOST BOOK
not sure if this will work but go into downloaded ring tones pick one see the options and see if it says set as ringtone or message tone it should work also try going into profiles and perzonlize and go to ringing tone and pick downloaded tones hope that helps
Jun 30, 2008 | Palm Treo 500 Centro
Ringtones on my moto krzr
did the tones come pre installed on the phone? why dont you try using mp3 ring tones? download mp3 songs on your phone, then you can set them as ring tones. they work much beter than ordinary ring tones
Jun 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
I have a 6600 nokia phone..
1ST U FOMET UR MOBILE AND MMC AND THEN INSTALL MP3 SOFTWARE.
Feb 29, 2008 | Nokia 6600
LG KC910 Renoir Cell Phone Logo
29 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
