Question about Dryers
I just got a used white westinghouse spacemate III stacked. I think the heating elemnt needs to be replaced. Where do I get the replacement and how hard it is to do it on my own? Thank you~
5 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: Whirlpool dryer won't heat
hi. thanks for letting me answer.the only part that was not mentioned. is the timer contacs Y & R . the heat contacts in the heating circuit. thanks
Posted on Sep 29, 2008
  • 3 Answers
SOURCE: dryer won't turn on
have you checked the outlet? I had an outlet go bad and cause this problem for me.
Posted on Apr 03, 2009
  • 111 Answers
SOURCE: why dosent my dryer get heat
Look at the gas valve coils to determine if they are faulty. If the igniter radiates but then shuts off before it ignites the gas, then the coils are probably bad. Replace the coils and your problem should be solved. Also, if you find the igniter working properly then the problem may be with the radiant heat sensor. The sensors are usually located close by the igniter so are easily visible. Hire a repairman to replace these faulty parts.
Posted on May 24, 2009
oldTech2332
  • 2341 Answers
SOURCE: i have a roper dryer model # res7745pq0 doesnt
What you need to check are the two thermostats mounted to the heater housing BOTH should have continuity
Posted on Aug 11, 2011
I'm looking for a manual for white Westinghouse spacemates 3 to change dryer drum belt
You can do it without a manual. Unplug the unit. Remove the screws on the back that hold the top lid on. Look down inside the back and you will see the belt running from a pulley on the motor to a large pulley on the drum. It may has the access through a rear panel. Most don't need an adjustment for tension, just peel the old one off if necessary and replace the new one. Take the serial numbers etc off the plate on the back when you look for a new belt. Check the drum and motor rotate smoothly before fitting the new belt.
Nov 15, 2014 | Dryers
Dryer wont heat up the elemnt tested good
Make sure BOTH hot legs of your 220 are active. Sometimes, one half of your circuit breaker will trip. When this happens, you will have 120 volts to your drum motor, but an open circuit to the heating coils. Just re-set your breaker by cycling it off and on again. Otherwise, check for continuity of the thermal switch (in line to coils).
Oct 30, 2009 | Whirlpool LTE5243D Top Load Stacked...
The stackable washer will not agitate
Give me a model number. Fridgedare and White westinghouse made some of these stacks for Kenmore. I'll need to know the manufacture. Reply with the whole model number and I'll help.
Aug 27, 2009 | Kenmore 98702 Stacked Washer/Dryer
Hot Surface Indicator Light has not turned off since last night.
if the hs ind light does not turn off then that particular heating elemnt needs to be replaced.heat sensor is built in the elemnt.when elemnt is turned off and it cools down it makes a switch to open and inturn ind light turns off.but sometimes thst gets stuck and light remains on.but do not worry abt element,it remains off,its just that indicator light that remains on.
Jul 30, 2009 | Jenn-Air JED8430 Electric Cooktop
Dryer won't turn on
Apr 03, 2009 | Kenmore Dryers
Kenmore Dryer not heating
thermal fuse kit.it is blowing due to improper ventilation.their is a clog somewhere from dryer to where dryer vents outside.thermal fuse is located at top of your elemnt cage.you will replace the thermal fuse and your high limit fuse at the bottom of the elemnt cage.but have your venting checked or swept out.
Mar 09, 2009 | Dryers
My hot light stays on and every thing is cool to touch
yes , hopefully you have a seperate indicator light for each of the elemnts, makes it easier to see which has gone bad, but if yo know which burner you were usins at time of incident then you can assume that it was that elemnet. replacement of the elemnt is required, for a it has a short in the theremistor, not a hazard, more of an inconvience, so i would have it taken careof but no need to rush its not an emergency, its only an faulty indicator, the elmnt is not actually heating
Mar 06, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Fire Mondel # PLEB30T9FC
very possible hat the element is no good, does it look physically burned???? if so replacing the elemnt is the only option,2 screws and 2 wiredis all, simple to replace, unplug/disconnect power first,,, the wires are always live to the elemnt!!!!!!!
Dec 21, 2008 | Frigidaire GLEB30T8A Electric Double Oven
RCA oven bottom heating element burned up
youd be better to leave the old elemnt in tillits replaced, the wire leading to the elemnt is ALWAYS live, even when not on there is ALWAYS power to the elemnt wire
Dec 02, 2008 | Kitchen Ranges
We need to install the lower heating element in the upper oven
ill aasumme that yo can see the elemnet in question, and its not a "hidden bake" elemnet located under the oven floor.. should be an easyrepair, with a little bit of patience. don trush shoudl only take 10 min anyway. TURN OFF POWER> LIVE WIRES TO ELEMENT AT ALL TIMES. REGARDLESS OF UNIT ON OR NOT!!! ther ewill be 2 screws along the bottom of the element holding the elemnt in the unit. after emoving carfully slide the old elemnt out a few inches, slowly pull out, for the wires are still attached to the back of elemnt and you want them to stay there you dont want them to disconnect and fall behind unit, (you will then need to remove the unit form the wall to access htem). so pull slowly espescially if you feel resistance in the wiring. after you getit out far enough simply unplug and plug in the new one reinstalll and you shoud be fine
Nov 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Dryers Logo
185 people viewed this question
Top Dryers Experts
