Question about Hoover F7431-900 SteamVac Vacuum
Won't dispense solution
I used the upholstery attachment, and it worked fine. I converted to clean my carpet, and the solution will not dispense. I've owned this for a long time and know how to use it, but can't figure this out. My tanks are secured properly.
  • DKJK Jan 11, 2008
    I took the handle off, and the plastic post had become disconnected from the trigger. With the help of a flashlight and a lot of patience, I got it hooked back on, and reassembled the handle. It worked beautifully then.
    Thanks for the cleaning tips. I'll keep them in mind.
  • JBubis Aug 20, 2008
    My trigger isn't depressing rod enough to engage the spray. I took the handle off, and the rod is connected to the trigger and to the lower rod, but there isn't enough oomph to engage the spray. It worked fine last time I used it and the unit's been sitting in the garage since. Can't imagine what would have happened.
    President:
  • 1,673 Answers
Check the filter inside the dirty water tank. If it is pushed all of the way to the top, then it won't spray or suck. Also if this has the type of hose that has a block attached to it, when you removed the hose, did you put the other block back in place. Check the seal that the solution tank sits on.
Posted on Jan 10, 2008
Where is the belt located on my hoover steam shampoer
There is probably not a belt. The brushes on the carpet cleaner head and attachments work from air and there is a roller bearing deep inside that will wear out and the brushes won't turn. I've found no way to fix this. I consider it a design defect.
Apr 20, 2011 | Hoover SteamVac Carpet/Upholstery Deep...
How do I hook up the upholstery cleaning attachment
Right, how to hook up the upholstery cleaning so the water will drain?
Sep 20, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Instructions on how to put attachments on hoover steamvac to clean upholstery
Remove solution tank.
Remove hose from storage rack.
Remove recovery tank and lay cleaner flat on floor. Remove lid,
Now, remove front panel from recovery tank by sliding it straight up.
Take your hose and slide the U-shaped end (converter) into the place where you removed the panel. Slide halfway down opening until it is firmly in place.
2nd step: You should have a tube with a "plug" on it hanging from the converter end. Open door on hoodl abeled "Stair upholstery/Cleaning Connection". Extend black tabs by pulling tan collar toward tube. Press connector collar down firmly to ensure that it is fully connnected.
It's sort of like a childproofed plug and socket. Pull back on the collar and push in the olug. Not hard at all once you've done it the first time.
Make sure you put the lid on the recovery tank correctly so you have suction. Attach whatever brush you want to use on the other end until the tab locks into place.
Sometimes you have to bleed the air from the line by turning on the cleeaner and letting it **** against your hand or hard surface for 15 seconds before its ready to use. This gets the solution to flow to the tool.
Aug 06, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover model 5870-900
you dont have the lid on correctly, if you can lift the lid up, then you have it on incorrectly.
Jul 20, 2009 | Hoover F5870-900 SteamVac Vacuum
No suction from upholstery attachment
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Problem: Low suction
Problem: Clean solution won’t
dispense
Problem: Brushes/brush indicator
won’t rotate during floor cleaning
Possible cause
Possible solution
• Not firmly plugged in
• Plug unit in firmly
• No voltage In wall plug
• Check fuse or breaker
• Blown fuse/tripped breaker
• Replace fuse/reset breaker
Possible cause
Possible solution
• Recovery tank full/automatic
shut off engaged
• Remove and empty recovery tank
• Blockage In tool on end of hose
• Remove tool and clear blockage
• Recovery tank lid not on
correctly
• Make sure lid is on securely
• Recovery tank front panel not
replaced after stair or upholstery
cleaning
• Replace recovery tank front panel
(page 14)
Before using tool
It may be necessary to remove air from
the system (“prime the pump”) so the
clean solution will flow to the tool. Follow
these steps:
1. Attach tool to hose and turn the carpet
cleaner ON.
2. Put the tool on a hard surface or
against your hand to block off the suction.
3. Wait a few seconds (can take up to
15 seconds). Then squeeze the trigger
and begin cleaning.
GOODLUCK!!!!
Jun 17, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How do I attach upholstery parts?
Remove the main head and put on the air guard.
Take of the bag assembly and attach the hose.
Mix up the solution in the "Suds o gun".
Attach this to the end of the hose.
When you switch on, foam will dispense from the gun.
Gently sponge this into the furniture.
Please leave feedback
Feb 14, 2009 | Kirby G4 Bagged Upright Vacuum
How do I shampoo my upholstery
Instructions are HERE. Try shampooing on a part of a furniture that is not visible much... sometimes this may not work well.
Jan 30, 2009 | Kirby Ultimate G Bagged Upright Vacuum
Eureka Atlantis 2591A Extractor - Won't spray
Hard to say without seeing it, is there a function type knob that you would switch from carpet to hose? Did the hose attachment lid close ok? Other then take, if this is new, it has a years warranty on it, just take it to a waranty shop for repair.
Apr 20, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Cleaning uphoustry
I CANT FIRGUE OUT HOW TO PUT IT TOGETHER
Mar 05, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
109 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
