Question about Delta 31 - 255X X5 18'' x 36'' Drum Sander
Drive Belt broken
I need to replace the belt which is driven by the DC motor. The back of the belt reads: P120 Antistatic Aluminum Oxide JD24A-20 PES PA343.
I use Klingspor sanding belts and they stock the conveyor belt for the 255x. I have used their abrasives for year.
Posted on Feb 15, 2010
  • 2,176 Answers
The part number for the poly v belt is 406131330004 and you should be able to buy it direct from Dewalt at their website or find a local dealer thru their locator and or service stations listed there.
Posted on Nov 17, 2009
What would cause my toro zero turn lawn mower to quit pulling?
Put as you have stated it, the most simple answer is that it has a broken drive belt - unless it is shaft driven. If it is, then you need to take it in to a good mechanic. Also, if it is indeed belt-driven, and the belt broke, it's ability to pull would have been immediately obvious and you would have seen remnants of the drive belt either on the lawn or, when you checked it, it would still be, although broken, stuck up in the belt housing. . .
Apr 14, 2017 | Toro Garden
The turntable does not work. How can I repair this?
You'd have to determine whether its motor driven or belt driven. A broken belt is easy to fix, but a motor problem requires some troubleshooting.
With an ohm meter, you can check if the motor has continuity. If it does, then you need to determine if it is getting whatever type of current it needs; usually 117 vac or a lower dc voltage. If that checks ok, then you might have an issue with gears in the motor binding up, or a broken coupling between the motor and the turntable.
May 07, 2016 | Microwave Ovens
I am looking for a drive belt for a mastercraft 3x21 beltsander. the belt says 120xL031. cant seem to find one anywhere.
The belt you can replace with a is simply any generic 3x21 belt. You can find them at your local hardware store or order them from a website like Home Depot, etc and have them shipped to your home. Here is a link to take you to Home Depot specifically for an 80 grit, but you can look for other grits as well. 3" is your width and 21" is the diameter of the belt you need.
Gyros 3 in 21 in 80 Grit Aluminum Oxide Sanding Belt 5 Pack 12 32180 5 The...
Feb 14, 2015 | Tools & Hardware - Others
Precor error 20
Precor Error Code 20 Error Code: 20 Manufacturer: Precor
Model: All Models
Error Description: Error 20, Too many Maximum Power Requests in 1 Second - The error 20 observes a treadmill's power bit reading when the treadmill was operating at speeds of 1 mph or less. Power bits indicate the relative time that the motor controller drive circuit is turned on. Power bits is an indication of the amount of power the load is demanding from the motor controller. Error 20 indicates that at a speed of 1 mile per hour or less, an excessive amount of power is being demanded from the motor controller for an excessive length of time. Possible Reason:
  1. Starting the running belt under a very heavy load can cause the error 20 to appear.
    1. The user (especially a heavier user) is standing on the running belt as they start the belt into motion.
  2. A badly worn deck and/or running belt can cause the error to appear when the user steps onto the belt.
  3. Badly worn drive motor brushes may not be making proper contact with the drive motor commutator causing the error to occur when the user steps onto the running belt. The unit may also slow down or become sluggish when the user steps onto the running belt.
  4. A leaky or shorted drive motor filter capacitor (on units equipped with SCR motor controller) could increase the current demand enough to cause the error.
  5. A leaky or shorted drive motor inductor (on units equipped with SCR motor controller) could increase the current demand enough to cause the error.
  6. The high power demand is caused by a shorted or de-magnetized drive motor.
Recommended Action:
  1. Instruct the user to straddle the running belt while starting the treadmill at a low speed, such as 1mph or less, and then step onto the running belt.
  2. Determine the amount of AC input current being drawn by the unit under no load and loaded conditions using a clamp on AC ammeter. The current displayed can be used to determine the condition of the deck and/or running belt. These same readings should be taken on a like unit, in good operating condition with a known good deck and running belt. The readings from the unit in good operationg condition can be used as the benchmark. Compare readings and replace* the deck and/or running belt if necessary. *Some units have a reversible deck. Be sure if the deck is being flipped or replaced, a new belt is installed on the new deck surface.*
  3. Inspect and repalce both drive motor brushes if necessary.
  4. Measure the AC input current without a load using a clamp on AC ammeter. Electrically isolate the filter capacitor from the drive motor circuit. The drive motor leads need be kept intact so the drive motor will operate with the filter capacitor removed from the circuit. Re-measure the no load AC input. If the AC input current is significantly lower, replace the filter capacitor.
  5. Measure the AC input current without a load using a clamp on AC ammeter. Electrically isolate the inductor from the drive motor circuit. The drive motor leads need be kept intact so the drive motor will operate with the inductor removed from the circuit. Re-measure the no load AC input. If the AC input current is significantly lower, replace the inductor.
  6. Swap the existing drive motor with a known good drive motor.
Precor Error Code 20 20 Too Many Maximum Power Request in 1 Sec
Mar 18, 2013 | Precor C962i Treadmill 220V
Precor c966i error 20
Model: All Models
Recommended Action:
Mar 18, 2013 | Precor C966i Treadmill C 966i
Hi, My machine's motor is working but it is not revolving and washing the clothes.every other function like taking water, rinsing, spinning is o.k. please advise. Thanks
Hi from retired Englishman in SW France @20:27 Mon evening,
With you saying that the motor IS working and if your machine is belt driven (I don't know your specific model) it sounds as if the belt has either removed itself or has broken.
WITH THE POWER REMOVED FROM THE MACHINE you will need to remove the back- which is normally a simple task- providing you can get to the back easily!
You should be able to confirm the state of the belt. Even if it has only come off you should purchase a replacement as it is likely only to happen again.
Hope it IS as simple as the belt!
Cheers,
John C
Jan 31, 2011 | Whirlpool Inglis IP4400 Washer
No spin agitate or drain just motor noise
The noise coming from the motor means it is running but cannot drive the drive pulley and the pump pulley because the drive belt is either broken or has slipped off. The drive pulley and the pump are driven by a single belt. Replace the drive belt if broken or loose and has slipped off. Disconnect power then drain the water manually by placing the end of the drain hose into a bucket or a shallow basin. Position the bucket/basin as low as possible to extract as much water from the tub. Once drained, lay the machine on its back to access the belt under the machine. When replacing the belt, wrap it on the motor and the pump pulleys then on the drive pulley. Turn the drive pulley in such a way that the belt wraps around the motor pulley, pump pulley, and the drive pulley.
Nov 11, 2010 | Maytag Atlantis MAV6000 Top Load Washer
The drum of my washer does not spin freely. When I manually spin the drum, I found myself having to push it along to turn on one side. Also I found pieces of white plastic on my laundry? Please advise...
This drum is driven by motor which is coupled with a belt that connects the drum and the motor,the is a possibility of a broken belt,or the motor is stack, may be the motor is not receiving power for the motor to be driven to drive the drum.
To access this you need to open the screws at the back of the washer,the plastic pieces is a sign of some broken parts in the washer,if you find that it's the belt that slept off the puller place it back and test but unplug the washer from power before doing all this.
May 18, 2010 | Whirlpool GHW9100L Front Load Washer
Dryer heats up but the inside doesn't turn.
a dryer will not turn if the belt has fallen off the motor or if it has been broken    replace the belt
Nov 05, 2009 | World Imports Belle Foret N30002TB...
CD will not eject - it plays fine - but the tray will not open
If the tray mechanism is belt driven, the belt may have become loose or is broken and needs to be replaced (usually the belts are of a standard measure and can be purchased in electronic stores or via internet), but if there are only gears to drive the tray mechanism then it could be broken teeth on a gear wheel, faulty drive motor or faulty motor driver electronics.
Hope you can fix it.
Regards,
Triarcuate
Oct 17, 2009 | Denon DN-C615 CD Player
Delta 31 - 255X X5 18'' x 36'' Drum Sander Logo
220 people viewed this question
Top Delta Tools & Hardware - Others Experts
Jim London
Jim London
Andrew Taylor
Andrew Taylor
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
