Question about HTC Touch Pro Smartphone
I can't align the screen - HTC Touch Pro Smartphone
How to align screen e755 pocket pc
To align your screen
select Settings, System, Align Screen to ajust the touch screen,
If the screen alignment loses calibration it may not be possible to adjust alignment useing the above method.
In that case the align screen command can be executed by simultaneously pressing the power button and scroll button.
useing the stylus when comanded touch the cross hairs and the Pocket PC will align the screen
Feb 24, 2011 | Toshiba e755 Pocket PC
My htc p3400i mobile donn,t show screen only see align screen?what i do
showing align screen written in under
tap the target firmly and accurately at each location on the screen. the target will continue to move until the screen is aligned._1037.jpg
Jan 27, 2011 | Computers & Internet
Imate, ultimate 8502, when i started to boot, hangup at "align screen" i already tapped the screen at 4 corners, but still hangup at align screen, so pls guide me what i have to do
imate, ultimate 8502, when i started to boot, hangup at "align screen"
Jan 02, 2011 | i-mate Ultimate 8502 Cell Phone
I have an imate pda2k pocket pc and is working good. Out of curiosity i tried hard reset and it ends to align screen. Everytime i made a hard reset the screen show " tap the screen to setup your pocket pc"...
tap and hold on align target until it moves to next corner or next step, if you are using windows 6 or 6.5 you should be very much accurate on taping and holding to align the screen.
Nov 01, 2009 | i-mate PDA2k Pocket PC
Palm treo smartphone upon reboot gets stuck on "align screen"
yes u cant exit the screen until u do the align test for the touch screen its a easy fix on the back of the phone on the left side top there is a hidden pen that comes out of the phone and when u get the pen out use the point of the pen to touch the center of the circle on the align screen test it will ask u to do this in every corner of the screen after that the phone should get out of the align screen test and be able to work good luck
May 29, 2009 | Palm Treo 755p Smartphone
Screen alignment could not be done
I accidentally click on something and my screen alignment for my HTC mobile phone has run significantly... When I tried to align the screen from the setting, it only write that tap firmly and accurately on the target. the target will continue to move until the screen is aligned. Till now, i tried many times but the alignment is still out
Mar 25, 2009 | HTC Touch HD Smartphone
Imate pda2k pocket pc shows align screen
go to start, setup, system, screen, and then click align screen. and then it will give u some small circles to tap on it. u tap correctly on the circles. after few clicks it will automatically tell u that ur screen has been aligned. ur problem is solve by a cute pakistani. pakistan live long. love u.
Oct 06, 2008 | i-mate PDA2k Pocket PC
Align screen
Align screen, message : Tap the target firmly and accurately at each lotation on the screen , the target will continue to move until the screen is aligned
Sep 01, 2008 | i-mate PDAL Pocket PC
Align screen
settings>screen>align screen
99% solved.
Aug 26, 2008 | O2 XDA Mini S Smartphone
Align screen
WHEN I AM SWITCH ON MY POCKET PC IT IS SHOWING ME (ALIGN SCREEN) AND TTAP THE TARGET FIRMLY AND ACCURATELY AT EACH LOCATION ON THE SCREEN .THE TRAGET WILL CONTINUE TO MOVE UNTIL THE SCREEN IS ALIGNED.
WHAT IS THE PROBLEM REPLY ME DETAILY
Jun 23, 2008 | RIM BlackBerry Pearl 8100
HTC Touch Pro Smartphone Logo
112 people viewed this question
Top HTC Cell Phones Experts
Ashutosh Khandelwal
Level 1 Expert
D. E. Hev
Tech Leprechaun
Tech Leprechaun
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
