Question about Cameras
I have a Nikon AF-SNIKKOR 18-55mm 1.3.5-5.6GII ED and it is ''locked'' at 55. I cannot get it to zoom in. The problem started after the lens was shaken by my camera bag falling to the fall....any suggestions?
  • 685 Answers
Sounds like the lens is jammed and the fall did some damage to the lens. You could apply a little more force to the zoom and it may or may not pop back into place. It is work a try since impact/shock is not covered be the warranty; and the cost of repair is almost as much as a new lens.
Posted on Nov 27, 2009
What is 55-200mm?
That's the focal range of a zoom lens. Unlike a single focal-length lens (or a "prime" lens) a zoom lens lets you adjust the focal range. "55-200mm" specifies the lens's focal range from 55mm at the low end to 200mm at the long end.
You can read a general description of zoom lenses at
http://en.wikipedia.org/wiki/Zoom_lens
Nikon current has two different 55-200mm lenses:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/
2156/AF-S-DX-Zoom-NIKKOR-55-200mm-f%252F4-5.6G-ED.html
and
If you're asking about the L110, it has a permanently-affixed lens and will not use either of the above lenses.
Aug 11, 2011 | Nikon Coolpix L110 Digital Camera
I have a Nikon D3100 and want to buy a zoom lens 70-300.Please help I am confused is a Nikon AF Zoom-Nikkor 70-300mm f/4-5.6G compatible? And is it automatic focus?
That lens will work with the D3100, except for the autofocusing. In order to autofocus with the D3100, you need AF-S lenses, such as the AF-S VR Zoom-NIKKOR 70-300mm f/4.5-5.6G IF-ED or the
AF-S DX NIKKOR 55-300mm f/4.5-5.6G ED VR.
May 22, 2011 | Nikon Cameras
Nikon 55-200 is locked on 55 and won't extend to zoom. Worked the last time I used it, and was on the camera when it stopped.Nikon 55-200 is locked on 55 and won't extend to zoom. Worked the last time I...
Assuming that you've already tried a good firm hand on the zoom ring then all you can realistically try is to give the lens a few good firm slaps onto a desk to try and free up whatever has gone wrong. Brute force usually sorts them out, but it is "kill or cure". This lens lacks a macro mode, so this is not the usual simple case of adjusting a lens control and then slapping your forehead with embarrassment...
The lens is otherwise uneconomic to repair as it's one of the cheaply built kit lenses and so you can easily obtain another for less than the cost of repairs.
Jan 26, 2010 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G ED...
Replacement rubber zoom band nikkor 17-55 2.8
yes...check with Nikon or I have seen replacement rings on ebay even...I'd check with nikon or a local nikon repair facility for parts..
Jan 25, 2010 | Nikon Zoom-Nikkor 17-55mm f/2.8G ED-IF...
Nikon DX AF-SNIKKOR 18-55MM 1:3.5-5.6G11 ED auto focus don't work
If you're looking at the camera without a lens on it, there should be a little flat protrusion in the lower left. Make sure that it is protruding and not obstructed.
Dec 19, 2009 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon lens 55-200 nikon dx vr
So does mine, that is the VR releasing, it is normal.
Jun 24, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
May 24, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Manual Focus won't work
Which camera are you using? If the body has AF/MF switch, put that also to MF.If this fails to help, take out the lens and try to change it to MF.
Feb 05, 2009 | Nikon Zoom-Nikkor 55-200mm f/4-5.6G IF-ED...
Problem with the Nikkor AF-S DX 55-200 zoom lens.
I just had the same exact problem! However, in my case I was finishing up a photo shoot at work, went to switch lenses, and when I picked up my 55-200mm zoom lens, the tip of it fell off!! I was able to put it back into the end of the lens, but now I am having the same autofocus problem and sound effect. I think it is because it is off track inside the lens. But I have only had mine for 5 months! I'm preparing to send it to Nikon for warrenty repair.
Apr 13, 2008 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
Cameras Logo
222 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
