Question about Samsung RF265AA Bottom Freezer French Door Refrigerator
Not making ice sounds like it wants to but doesnt makes a clicking sound often
  • Samsung Master
  • 4,655 Answers
Double check your model number but the problem is most likely related to start components of the compressor. Sea Breeze
Posted on Nov 24, 2009
Why doesnt ice come out just clicks
Sounds like it's not going into thaw or defrost mode before the dump cycle. Or you may have ice built up on the teeth and comb section of the scraper that pushes the ice out. When it clicks try and push it with your fingers and force it to move towards the ice.
Apr 26, 2014 | Freezers
Subzero 690 ss icemaker making a clicking sound why
If the noise is coming from the ice maker head itself. Then it sounds like the gear is slipping. They are plastic and it is very common for them to crack or break. Most ice makers are the same. Click Here to see a post on a Whirlpool ice maker with a broken gear.
Good Luck From David at refrigerator repair.
Apr 04, 2013 | Refrigerators
My whirlpool side by side is not making ice and im wondering if the sound it usually makes, like water filling up, doesnt happen anymore have anything to do with it???
The ice maker not working: ---
Its the problem of water inlet valve. It's a dual valve. This valve has two tubes in it. One for water dispenser and one for ice maker chamber. The one side of valve is working, but other side of the valve is not working. The valve is got stuck in one position
Click this link below to troubleshoot the problem: ----
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
This will help. Thanks. Helpmech.
Nov 01, 2011 | Refrigerators
My side by side wont make ice and it usually makes a sound like water filling something but doesnt anymore should i replace the valve part that regulates water or the ice make part???
yes its indicating towards faulty water valve.
Ice in icemaker is melting. refigerator is making buzzing sound for several seconds at a time like a faulty switch that is having a hard time making contact.
it sounds like the compressor is the problem.
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
Mar 17, 2011 | Maytag MZD2766GES Side by Side...
Fridge makes a clicking sound, stops if lever for ice/water press
this model has a p c control in the back and the clicking sound is common when its failing . Pt # wr55x10656 ) there is a up date kit for this frig . ck on the kit before replacing the board as its included in the kit . hope this helped ****
Jan 04, 2010 | Hotpoint HSS25GFP Side by Side...
Ice maker will not dispense water or ice.
sounds like maybe the switch that is press to release water not working so it doesnt sent the signel to let water out dispenser
Sep 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Kenmore Coldspot Ice maker is not working on our side by side refrigerator
Just above the tray that holds the ice cubes is a wire bar. If the bar is down, it will make ice. If the bar is up, it will stop making ice. When there is enough Ice in the tray, when the bar comes downm, it will hit the ice. If the bar is not completely down, no ice will be made.
I bet the bar is stuck, or you don't have a water supply to make ice (or it's plugged - de-ice the freezer).
Richard
Jan 21, 2008 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice Maker Making Noise
sounds like your icemaker is jammed.
first ofall just feel around the icemaker and see if you can find a peice of ice jamming it that you can remove. if that doesnt work heat it up with a blow dryer until any ice that is there will melt away and it will free up..
there is one other possibility: the stripper could be jammed against the side of the icemaker in which case you'll have to remove the icemaker from the refrig and unjam it..
hope that helps and good luck
Dec 15, 2007 | Jenn-Air JBL2086HES Bottom Freezer...
Clicking sound coming from the icemaker
you said it is making ice but is it ejecting the ice if not the heater could be bad if this is the case replace ice maker
Dec 11, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
161 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
