Question about Motorola Mobility RAZR V3
Motorola razr malfunctioning
My motorola razr (not sure exactly what kind, its grey.) has been turning itself off. ill turn it on for maybe a minute, but then it turns off. if i charge it and try to turn it on it does the same thing. so im not sure what the problem is, maybe the battery? its been dropped before, but that was a while ago. it hasnt been in water or anythin.
It's now turning itself off and back on constantly. Got a fix?
See answer here Old Motorola RAZR ce0168 keeps turning itself of then on Got fix
Motorola Support
Dec 27, 2014 | Motorola Mobility RAZR V3
My Raz is on snooze [which I did not put on] and keys not responding. Can the snooze be turned off. Help
Make sure the key buttons are not stuck u can shut the phone off take battery out of phone for three minutes n if you have Simmons chip take it out too then put it back together after three minutes it should reset itself if not then it maybe internal
Feb 10, 2012 | Motorola Mobility RAZR V3
My Phillips Tv keeps turning itself off after around a minute,the power button remians on and green but no picture or sound. It is like the fuse keeps tripping. If you unplug the tv and switch it back on...
The main power supply is trying to fail. You might try giving us the model number since we can't guess exactly what kind of TV you have; LCD or plasma?? They suffer from some differing ills-
Oct 23, 2009 | Philips Televison & Video
My Motorola V3i keeps turning off by itself especially on calls.
well unfortunatly its def a battery problem.ul hav to get it replaced..u cud check it out with another battery borrowed frm a friend who has the same mobile
Thanks for using Fixya
Apr 28, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Please Help !!! my Motorola RAZR V3i is automatically shutting down ...
take the phone and have the firmware reflash this should correct the issue that you are having
Jun 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
White Screen
My problem is closed. Thankfully, my phone still was on warranty so it was replaced. People at the warranty place suggested that the problem might occured because I work in the data center.
Apr 18, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Power down
1> Change battery and see what happens in 10 minutes 2> Change motorola adaptor 3> Check if any bluetooth or any similar programms are always on. If you are not sure put back the factory settings. I don't think any personal data to be deleted. 4> Try to delete some unwanted data. 5> Worst scenario >>> Your motorola needs a mosterpack reflash program. TELL ME WHAT HAPPENS
Sep 03, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
D. E. Hev
Lawrence Oravetz
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
