Question about Samsung SGH-E900 Cellular Phone
NEED HELP HI MY PHONE IS JUST BLANK WHEN IT HAS SLID UP BUT WEN IN STAND BY MODE IT IS OK
  • 192 Answers
Brother it seems your phones belt problem. The belt connecting both of sides of your phone may loose or broken (Most probabely loose). You can fix it if you have little skill and screw-driver set. Open lower case by unscrewing it, detach PCB inside it, tight the connector of the belt in question. If u can not do it yourself go to nearby technician he will charge little and put it right. This is normal problem due to frequent use of slider.
Posted on Jan 09, 2008
My iphone was charged up then it went blank then wen i put it oo the charger its saying connect to itunes
You seem to have either entered restore or dfu mode your going to have to restore your phone
Feb 28, 2011 | Apple iPhone Smartphone
Craig mp4 player duz not stay on wen unpluged
Sounds like either you battery is low or defective or your device is set on a very fast sleep mode. The screen goes blank because it is set to go to sleep after 1 second. Go to menu and look for settings for the sleep mode
Sep 14, 2009 | Audio Players & Recorders
How to turn off wallpaper on my sgh i450
Simply turn on The Active Standby Mode......
Menu->Settings->General->Personalisation->Stanby Mode->Avtive Stanby Mode [ON]
Thats The only Solution...
Bye Take Care
Jun 07, 2009 | Samsung SGH-i450 Cellular Phone
Blank screen i can do anything but cannot see anythig.
Ok, totally power down this phone, then remove the cell and let stand for 5 min. reload the battery cell and power up. this should fix this software scramble but, if not, this is on board software failure and may need to be sent to manufacture for a rebuild.
Feb 15, 2009 | Nokia N70 Cellular Phone
How 2 work my N72 if screen is blank wen turned on?
u first uninstall the game then tak of the battery and keep out 4 som time. and then put it in.. tis mite help u.. if ther prob exists stil then u ll hav to contact the service center
Dec 13, 2008 | Nokia N72 Cellular Phone
My motorola v3
not possible with the v3
Nov 25, 2008 | Motorola Mobility RAZR V3
Nokia 5610
use from suite flat cable.meybe it work properly
Sep 08, 2008 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
Broken phone
Hi all,
I had simmilar problems ie screen ok when closed but fuzzy when slid open, screen going blank etc.
I replaced the flex cable that connects the screen to the main board and the phone now works perfectly.
Nick
Jul 17, 2008 | Samsung SGH-U600
Blank picture, sound ok,OSD display ok.
try volume up and power buttons in the stand by mode(off) if not menu and power.
Apr 10, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Nokia 6288 troubles
HI. 1ST U OPEN THE BACK COVER AND REMOVE THE BATTRY > NOW OPEN THE SCREW > PULL THE BACK COVER VERY CAREFULLY PULL UR MOBILE PCB VERY CAREFULLY AND REMOVE THE STRIP CONNECTOR SAME PROCEDURE FOR FRONT SIDE WHEN BOTH SIDES R OPEN THEN CLOSE SLID AND PULL THE STRIP FROM MOBILE'S SLIDE. THEN NEW STRIP ENTER THE SLID AND FLOWS THE SAME PROCEDURE IN REVERS CONDITION. NOTE -(WHEN U PULLED THE STRIP THEN MIND IT WHICH SIDE IS DISPLAY SIDE OR WHICH SIDE IS PCB SIDE.
Feb 20, 2008 | Nokia 6288 Cellular Phone
Samsung SGH-E900 Cellular Phone Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
