Question about Samsung SyncMaster 175V 17" LCD Monitor
Quickly after I turn on my Samsung SyncMaster 175v flat screen computer monitor it blacks out. Is there a simple fuse I can repalce? or is the problem more serious? The color/resolution is normal for the short time I can see what is on screen, but then I loose all picture within less than a minute. It was working perfectly until suddenly this problem. I would like to keep this monitor if there is an easy fix. I looked on youtube without any success in finding out if something could be done without a service call. Thanks for any insight you may have. Linda
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 575 Answers
It seems the picture board in the monitor
Posted on Apr 17, 2017
    Master:
  • 507 Answers
It seems the picture board in the monitor has gone bad and is needing to be replaced
SOURCE: Error message on Samsung SyncMaster Monitor 19"
had exactly the same issue as you.i contacted samsung after trying everything that was suggested and they have sent me a replacement monitor within 7 days .i believe that they are aware of an issue with a chip in the monitor and are replacing like for like free of charge as long as you are still within your 3 year warranty.give them a call you have nothing to lose.
Posted on Jan 06, 2008
tantong
  • 138 Answers
SOURCE: Samsung LCD Monitor SyncMaster 203B
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen blacked out or stopped working, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
SOURCE: Samsung 215TW Monitor Flicker
Its the capacitors on the backlight power supply. Samsung installed crappy ones and they blow up after a year or two. Change out the caps and you're good to go
Posted on Jun 09, 2009
  • 152 Answers
SOURCE: Have a Samsung SyncMaster 225bw.
Dyderich, Yes, You should read up on all the causes of LCD monitor failures!! Your symptom will be among the top three cause/complaint of failures. LCD units can be repaired. If you have never used a soldering pencil, digital volt meter, DMM or Oscilloscope, then you should keep yur gruby fingers on the outside of the monitor. Your monitor's "switch-mode-power-supply" and the "cold-cathode-fluorescent-tube's" and the "inveter" power supply that lights up the tubes will need to be evaluated(trouble shoot) by a TECHNICIAN who knows all there is to know about CCFT's and what it takes to get them to light up!!! Or you can trade up to a younger model, and repair/refurbish the old and keep as a spare. You could also see if SAMSUNG has some sort of swapout program for newly refurbished same model monitors? ? ? Check with a Samsung dealer and or their website. Bye for now. I'm louie12fix on fixya or lmistyrel @aol.com
Posted on Sep 25, 2009
avnish1011
  • 253 Answers
SOURCE: my Samsung syncmaster 730a monitor wont come on.
Hi friend,
You need you check your display cable. it should be connected in your CPU. sometime cable lose in CPU..then monitor not given any display ...
Posted on Dec 20, 2009
I have this monitor for like around 6 or 7 years and now it seems like the light on it is darkening is that because is wasting?
thats what happens to that of lcd screen they arnt mad to perform that lond considering they are every where and alot out there to acer makes a 22" for 190
May 09, 2010 | Samsung SyncMaster 175V 17" LCD Monitor
On bootup monitor goes blank and only the green light blinks. Bad monitor?
Possibly. Try it on a different computer and then if it works you know it's a bad monitor.
Dec 27, 2009 | Samsung SyncMaster 175V 17" LCD Monitor
Display is fuzzy
Go into monitor controls on monitor and adjust as they come up. Unhook monitor, power up computer, cut off, plug in monitor power up computer, right click on screen, settings, adjust for screen size and additional monitor by clicking 2 and saying yes in box. Hope this helps.
Jul 05, 2009 | Samsung SyncMaster 175V 17" LCD Monitor
Repair samsung SyncMaster 175v lcd flat screen went black right after it start
usually that is an indication that the back lights on your monitor is not illuminating your screen.... here's a test start up your machine and look at the monitor real close.... or shine a flash light at it... you may see your desktop afintly... which means your monitor may need a new inverter board or possible to change some capacitors on it.
you can also try another monitor just to make sure it is ur monitor which is problematic
Dec 01, 2008 | Computers & Internet
Flashing Off
save your self the trouble if you have a flat screen TV you can connect to it NOW! if you need a second monitor you can go to a goodwill and buy a monitor under $40.00 I think is a good choice.
Feb 08, 2018 | Samsung SyncMaster 2253BW LCD Monitor
Monitor will turn on but stay on for only a second.
make sure the monitor cables are firmly connected at the monitor side, also try different cables, if it didn't help.
Mar 02, 2008 | Samsung SyncMaster 175V 17" LCD Monitor
All I get is a white screen
copied from http://www.fixya.com/support/t190380-turn_screen_displays_white
I have a Samsung Syncmaster 175v Mfg Oct '03 displaying the __ White Screen . I removed the screws on the back , removed base stand, separated case with flat screwdriver starting at bottom, unplugged the small wire to the panel menu buttons , removed metal cover from back of LCD. Now you can see the powerboard \ inverterboard combo and the attached video signalboard. Follow the 30 wire plug to the LCD screen, the 30 wire plug goes under a metal panel , remove the 3 small screws securing the panel and you will see the hidden LCD screenboard. Very close to where the 30 wire plug attaches to this screenboard on the Rightside you will see with a magnifying glass a SurfaceMounted Fuse named F1 with a value? of "K". On my LCD the fuse tested with a volt-ohmmeter to be Open or Blown. The right thing to do would be to replace the fuse however I acquired my LCD from a trashcan / dumpster so I stretched a drop of solder connecting both sides of the fuse. Now I do not have the protection from power failures and surges that the fuse could offer but upon reassembly my screen works like new again .
PS : i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
Jan 18, 2008 | Samsung SyncMaster 175V 17" LCD Monitor
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Samsung SyncMaster 175V 17" LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
