Question about Dell Inspiron 1526 Laptop
Hi, my problem on dell inspiron 1526 is this: SYSTEM MODULAR BAY cannot be indentified.... problem is that CD/dvd drive show signs of work(when i turn my computer on Green led blinks,motor starts to rotate cd), but bios doe's not show unit. i Have also inspiron 1525 model, and i try to check this dvd drive.it works fine. how can i fix this problem? this is not DVD problem. Maybe it is BIOS or motherboard error? please help.
  • 3,940 Answers
If the drive functions in another system the the issue is either the motherboard contacts or the controller. Flash the BIOS to the most current version and reset the BIOS defaults. If the drive still doesn't detect, then a motherboard replacement is likely in order.
Posted on Nov 16, 2009
Hi my dell d610 does not recognise any dvd rom i
insert a good quality dvd in the drive. If no response, go to my computer and select dvd drive and double click, it may open. GL
Aug 19, 2013 | Dell Latitude D610 Notebook
Dell Inspiron 1525 1526 24x CDRW/DVD Combo Drive cannot read to boot osDell Inspiron 1525 1526 24x CDRW/DVD Combo Drive Module Burner
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it if this fails you might try cleaning the lens it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
Jun 22, 2012 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Dell Inspiron 1100 problem
For Dell Inspiron 1100 Support just dial 1-800-204-4427 Dell Inspiron laptop support number to fix you error by expert technician. For more Click here : http://www.delltechnicalsupportphonenumbers.com/dell-inspiron-laptop-support
Jul 08, 2017 | Dell Inspiron 1100 System Board (...
I forgot my administrator password to my Dell Inspiron 1526.
If i forgot windows password, how do i bypass windows password?
Step 1: Download Bypass Windows Password software and install it.Step 2: Burn a bootable Windows Password Recovery CD/DVD or Windows Password Recovery USB flash drive with the program.
Step 3: Reset Windows Administrator Password to blank with the burned CD/DVD or USB, then bypassing windows password and regain access to your locked computer.
Apr 25, 2012 | Dell Inspiron 1526 Laptop
My cd rom drive wont quit going in and out its saying that i have it disabled but clearly i dont HELP
You might have to physically unplug the cd/dvd drive this should activate the found new hardware wizard also click start control panel administrive tools computer management device manager scroll down cd dvd rom drives if you see a yellow question mark? right click you will have options to update driver if your computer came with a motherboard disk the drivers could be on it
Hope this helps
Jun 02, 2011 | Dell Latitude Inspiron Modular Bay 24X CD...
Dell inspiron 1525 blank dvd r not regognized
You will need to use a different brand of blank DVD-R disc, some DVD-R disc will not work with some optical drives. Try using a Sony or Phillips DVD-R discs, these two brands work best.
Feb 13, 2011 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
At boot up , my vostro sends and error message "System in the modular bay not recognized" , and the Dvd/cd doesnt seem to work. It doesnt appear at MyPc and neither does it read any disc.
It may be due to the loose contact of the cables connected to the drive, if the tray ejects that means it receives power, tightining the cables should resolve the issue
Jul 28, 2010 | Dell Vostro 1400 / Inspiron 1420 - 24X...
When I turn on the laptop ...it says the dvice in the system modular bay can not be identified
Did you ever solve the non-recognition problem?
My C840 fails to recognize the/an extra HD in the modular bay, after I "overfilled(??)" it.
What to do to regain access to information stored on HD that the computer no longer recognizes? (Other components, including other HD's continue to work ok in the modular bay).
kcdd30a@aol.com
Nov 07, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Dell inspiron 1525 cd drive not recognizeing
ok what you do is go to control panel and system and then click ur driver and then install the dvd one
Aug 03, 2009 | Dell Inspiron 1525 1526 24x CDRW/DVD Combo...
Dell Inspiron 1526 Laptop Logo
586 people viewed this question
Alun Cox
