Question about Amana AGR5835QDS Gas Kitchen Range
The stove does not heat up
I set the stove up for 375 and click bake . the display starts at 100 and just sits there. The stove does not heat up
  • 187 Answers
Check the flame of the gas jet and make sure they are unobstructed and the flame is a steady blue. See if changing the temp affects the flame. It sounds liKe your temperature sensors might not be working. They are not that usually very expensive but trouble shoot the little things. If you have a knob control pull it and make sure that the inside is not broken just to be safe. The sensor is s usually at the left rear panel of the oven. Make sure it is intact. The other regulators would be under the floor of the oven where the gas jets are. good luck.
Posted on Nov 16, 2009
  • wire12me Nov 16, 2009
    I forgot to mention that you should not use those disposable oven covers or anything else on the bottom of your oven. It can damage the oven and alter feedback to sensors.
Why t takes long time for oven to heat up?
Does the oven actually heat up with the temperature more than 100 or does it just stay at 100? Alternatively, when you open the oven can you see the orange glow of the flame through the vents in the bottom of the oven and hear the gas hissing?
Aug 18, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
I have a Kenmore Ultra Bake. Stove was on bake set to 375. Only the broiler element came on at full power. Tuning off oven did not turn off broiler element. Stove was to hot to move so I turned the braker...
Hi
F3-E2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 01, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
The oven preheats, but then "cools down" before I
Most likely the problem is your bake element. When the oven is preheating it uses both the bake and the broil element. When it's done preheating it uses only the bake element, so the broil element is heating it up, and since the bake element is not working the temperature drops until it starts preheating again.
Jan 30, 2011 | KitchenAid KERS807SSS Electric Kitchen...
The temp for bake says 200c what do I set it on for 375 degrees?
265c63b.jpegPress BAKE and BROIL hi/lo
pads for 2 secs till display
show "SF".
Press BROIL hi/lo pad. The
display will show "F", if yall
want "fahrenheit" then hit
START. Press Boil hi/lo again
and yall will see a "C", if
yall want "centegrade" then hit
START. Most stoves.
If you ha listed a make and model it woulda been much easier.
Sep 21, 2010 | Ovens
My Maytag Performa oven and stove top will not turn on (heat up)
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises.
However....."broil" feature works just fine.
Please help.
Mar 09, 2010 | Maytag 30" Built-In Single Electric Wall...
Temp indicator chimes although temp is really 100 degrees low.
Yes you do need a new thermostat, just make sure that the sensor is not obstructed by anything. first.
Plz rate my solution
Thanks.
Dec 18, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
MAYTAG STOVE PROBLEM...NEED HELP
the broiler came on automatically??? not a sensor issue. sounds as if you have a broken wire perhaps, or a faulty control panel energizing the broil element w/o being prompted to. does it say its broiling when element comes on??
Mar 05, 2008 | Kitchen Ranges
GE JRS04BOW3BB Will not turn on.
turn the broil on high by itself wait a couple min. and see if it comes on. if it does the your bake element needs to be replaced or you may just have a burned wire where the bake element plugs in. just remember to turn the breaker off to the oven before trying to pull out the element
Nov 25, 2007 | GE JRS04 Electric Single Oven
Amana AGR5835QDS Gas Kitchen Range Logo
141 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal DeAngelo
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
