Question about GE Refrigerators
GSH25JFRFWW evaporator fan makes loud deep noise at times
GSH25JFRFWW evaporator fan makes noise like it is rubbing against housing. I can turn refrig off, wiggle fan blade, turn refrig back on and noise is gone for a while. It happens less if I take the ice maker out.
    Problem Solver:
  • 13 Answers
GE refrigerators have a faulty design, and so don't defrost completely, so ice builds up in the evaporator coils and on and in the evap. fan motor. Melting the ice will make the fridge more efficient, and the fan quiet again.
The slow, easy way to fix is take out all the food, unplug the fridge, leave doors open all day. Ice will melt, and all will be fine ... for a few months, until the ice builds up again. The fast way is here.
Posted on Aug 26, 2010
Recently had fan replaced, now it is doing the same thing in heat and air cycles. when time for fan to come on to send air into the house it makes and aweful noise again and doesn't come on. Any...
Visually inspect the fan and the inside of the fan housing. It sounds like it's rubbing against something or is loose and therefore rubbing against something. May be as simple as adjusting and tightening a bolt or removing something that got into the fan housing.
Oct 27, 2013 | Coleman Heating & Cooling
Our refrigerator is making a high pitched ringing/buzzing sound. Any way to fix this? Thanks!
You need to pull the refrig. out from the wall and determine the source of the noise. It maybe comming from the "condensor fan" usually located at the bottom rear. The blade maybe rubbing against something. Eg. paper or shield around the fan. It is also possible that the noise is comming from the inside. In this case, it could be the "evaporator fan" rubbing against something. Good luck ...Jerry
Mar 04, 2013 | Refrigerators
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
I have a rooftop unit 10tons when i turn the fan on it makes a rubbing sound i remover the fan and the motor the motor make no noise I changed the berrings in the fan but it still makes the loud rubbing...
the unit may settled and it is rubbing against something it may be the cover...run the unit on low and see then to high that may lead you to the location good luck
Sep 08, 2009 | Heating & Cooling
Loud fan
The fan is rubbing against the fan shroud. it may be misaligned or, the shroud has become loose. try aligning the shroud or making sure that it is screwed on correctly. The shroud mounting screws can become loose. This will allow the fan to rub against the shroud. this will create a loud noise. If during the inspection of the shroud you find that the fan is not rubbing against the shroud, this will confirm an issue that concerns the integrity of the electric motor sator assembly. the windings are bad. have the motor replaced if this is the case.
Aug 07, 2009 | Samsung Refrigerators
Loud noise from refrig.
The defrost timer is faulty. replace it asap.
Jun 25, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
After shutting off the engine, something whines loudly.
Hi ,that noise can be the blower fan rubbing against the housing ,this is a very comon problem in many sistems ,they get worn with time and out of balance and start making noise....C1
Nov 29, 2008 | 2003 Buick LeSabre
Loud thumping noise in rear air
Hi, you should check if the blower plastic fan is rubbing against the fan housing ,they get lose with time and make those noises.good luck C1...
Nov 27, 2008 | 2003 Chevrolet TrailBlazer
Lous Noise
It could be the blower fan is loose and needs to be tightened. If so, and you're handy, shouldn't be too difficult. Depends on the specific design.
Jun 16, 2007 | Kenmore 72175 Air Conditioner
Refrigerators Logo
262 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
