Question about Toshiba Televison & Video
The volume on my Toshiba Tv/DVD combo does not output very high. On the highest setting we have trouble hearing it at our kitchen table. Is there a way to adjust the volume, or can we connect external speakers, and will that help?
    President:
  • 2,187 Answers
Check the panel if it has audio output for earphones. You can connect an external speaker there provided you have the matching jack. The external speaker has to be stronger than the one installed on the TV for you to observe the improvement. As for the volume should there be no port, there may be an issue with the resistor inside the TV. It may need cleaning or replacing. Check as well the wires and the connections if there are loose ones. The one that regulate the volume is the resistor which increases its resistance should you want low volume and increase resistance should you need more juice.
Posted on Nov 15, 2009
I have a sharp tv with the volume at its highest but i can't hear anything
Hello
Check its speaker first. If voice coil of the speaker or tis cone paper has damaged, speaker will produce a dull low sound output. If the speaker is found OK, check the audio output section of the unit. This section circuits can be located inside the TV circuit board. look for any loose or bad soldering terminals at the audio output IC. It is best to resolder all the suspected solder points by applying a little more solder, withut making any solder bridge short in between adjecent solder terminals. If this also does not help you, replace the audio output IC. It is damaged. OK.
Dec 26, 2011 | Sharp 13VT-R100 13 in. TV/VCR Combo
I have a toshiba 26LV610U that has low volume. Most of the time I keep the volume at 40 - 50, but some DVD's are impossible to hear at max. Is there an internal volume adjustment that will amp up the...
Tries tv menu Sound Setting adjustment.Tries all the setting to the max like treble,bass,balance and surround sound is on.This should help make the audio louder.
Jun 10, 2011 | Toshiba MD19N1 19 in. TV/DVD Combo
I have a philips universal remote and i need the code for my tv which is a sv2000 with the dvd player built in
Hello crystal and welcome to FixYa. I think you were searching for the remote codes for a SV2000 TV/DVD Combo. Generally speaking TV/DVD Combos do not have a traditional codeset but instead use a DVD one instead. Follow these steps below.
Search the TV codes Using AV1 or AV2
Press and hold Mute and Select for two blinks
Enter 9 11
Enter 2
Press and release Volume Up
Press and release Channel Up until you hear the volume change
Next after hearing the volume change press Select to lock in the code
You should be all set. I hope this solution works out for you and good luck.
Apr 22, 2011 | Televison & Video
The TV is black but the fuse is good. I was told that it might be the horizontal output transistor. Where is it on that model?
If the fuse is intact in all probability the power supply unit is OK. If your Horizontal Output Transistor fails you will hear a high pitch whistling sound . Any way its the black three legged device mounted on an aluminum heat sink near a transformer from which a Red wire goes to the top of the picture tube.
Mar 08, 2011 | Toshiba MD20Q42 20" TV/DVD Combo
Sound but no picture
This indicates a failure in the horizontal output section where the high voltage for the CRT is produced and the deflection signal for the horizontal sweep.
Some parts may be available for this set although it is doubtful whether the flyback transformer is still made. Some parts for you set can be found here:
TV parts
Mar 07, 2011 | Toshiba MW20FP1 20 in. TV/VCR/DVD Combo
A new DM7 drum set line out has very low output. It is connected with drum combo Stagg EDA40 and if combo drum inputs are used there is practically nothing to hear . With combo maximum volume there is...
The sound on all the stock kits I found to be too low. What I did was create a custom kit and altered the dynamics of all the pads and cymbals - once you're in the dynamics settings, just hit the pads/cymbals the hardest you normally would and save that setting!
Dec 29, 2010 | Alesis DM7 USB Electronic Drum Kit
Toshiba 13' tv dvd combo, Fios remote control need code
Greetings!
Here are the codes: take a deep breath:
0181, 1283, 0183, 1292, 0087, 0677, 0859, 0872, 1183, 1383, 1683, 1731
You may find that these don't work. Often, with combination pieces like yours, you will find you are lucky if you can get a universal remote to turn it on and change the volume and little more. The fact that Toshiba did not build this peice can compound the problem. My suggestion, if you can't get the universal to program up, is to use the original remote for the set. If you do not have the original remote it is available from www.encompassparts.com for around $15.00 plus shipping. The original part number for the Toshiba remote is 72796929.
Rob
Jan 14, 2009 | Toshiba MD13N3 13 in. TV/DVD Combo
Toshiba 19LV505 combo/dvd tv that has absolutly the worst sound, the setting only goes up to 50 and you still have a hard time hearing the tv. Is it just poor speaker quality. I have cable hookup and hdmi...
Bob, you need to first raise the volume on the actual cable box itself. On each cable box there is a channel (up and down) as well as volume (up and down). Set the cable box volume to maximum, you can only do this manually at the cable box. This should work.
Dec 16, 2008 | Televison & Video
Televison & Video Logo
119 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
