Question about Viking VGIC485-6G Gas Kitchen Range
Looking for conversion kit for viking VDSC365-4GSS to lp
4 Suggested Answers
SOURCE: LP Conversion Kit?
I'm looking for the same thing! My kitchen is covered in black soot and the inside of my new oven is BLACK!!!
Posted on Jan 06, 2008
SOURCE: LP conversion for Thermador 4 burner range top
I have a Thermadore 6 burner gas cooktop PCG366E purchased January 08. I purchased the LP conversion kit, they only make one kit for all models. The instructions included with the kit were written for an older model and have not been updated by Thermador. The gas regulator is located next to gas inlet pipe. You have to get at it from above. Remove the 2 star burners over that side of the cooktop. You will need a 20mm socket to remove the nut at the center of the star burner. Lift it off and disconnect the wire to the ignitor ( You need to push on the spring lock in order to seperate the the connector terminal). Remove the stainless steel pan and then remove the metal pan underneath ( you will need a Torxs bit for this screw or vise grips). You should now see the regulator. At the top of the regulator is a cap with the letters NG visible. Twist this a 1/4 turn ccw, lift up and turn over to expose the letters LP reinsert. The regulator is now ready. You will need to replace the orifice tips at each burner. Use a 7mm socket with an extension. Put a piece of tape in the socket to hold the orifice in place while you insert it. You also need to adjust the valves. You must pull off the knobs and and remove the trim bezel. If you look through the screw hole on the right you will see a screw head (bypass screw). Insert long skinny flat blade screwdriver through the hole and turn the screw CW all the way (about 1/4 to 1/2 turn in my case). My cooktop had two burners with a low simmer feature, This devise is located in front of the bypass screw. It has a hole in it but does not align well with the head of the bypass screw and makes it difficult to turn the scew. Thats it, I hope this info has been helpful. I have not yet connected the propane therefore have not tested the unit but it should work.
Posted on Feb 27, 2008
richroth
  • 9472 Answers
SOURCE: Convert NG to LP
See if this document helps you.
Posted on Oct 18, 2012
Need part number for LP conversion kit
Good Morning Friend,
I understand you are looking for the part number for the LP conversion kit for your Frigidaire range. The LP conversion kit part number is PCK4200. I hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
I'm looking for natural gas conversion kit for a Vermont Castings Radiance Model 2240 currently LP gas fired freestanding stove
Try going to www.ibuyfireplaceparts.com 1-888-634-4289..They deal directly with the manufacturer and would be able to tell you if a conversion kit is available and how to go about ordering it
Jan 25, 2013 | Kitchen Ranges
LRG3095ST I need the conversation kit to switch for LP to natural gas
http://www.appliancepartspros.com/lg-conversion-kit-asm-ebz37171903-ap4448315.html
Jan 10, 2013 | Kitchen Ranges
WE HAVE A BRINKMAN GRILL AND BOUGHT THE LP TO NG CONVERSION KIT THAT IS RECOMMENDED FOR THIS GRILL ...KIT HAS TOTAL OF 6 ORFICES AND THE GRILL IS A 5 BURNER, WITH SEAR AND SIDE GRILL SO THAT MAKES 7..NOT...
Some Brinkman grills have the LP orifice installed on the NG orifice directly from the factory.
If that is true, you remove the LP orifice and the NG orifice is already there. Check instructions in the conversion kit and look for this detail carefully. I just did a Brinkman conversion and instructions were very confusing. The orifices in the kit are not used (on my unit).
Gary
Aug 21, 2011 | Garden
We are in need of a Tech Manual for a VGRT5364G conversion from LP to Nat. Gas. Thanks
Manual exist in the location: http://www.retrevo.com/support/Viking-Range-VGRT536-4G-Ranges-manual/id/23666dj391/t/2/
It clearly mentions that:
"A certified
technician is required for any adjustments or conversions to Natural or LP gas."
So pls dont' try unless you already know (and it seems that you don't)
Safety comes 1st!
Jul 28, 2011 | Viking VGRT5364G Cooktop
LP Conversion for Jenn Air CVG316 (about 10 years old)
I have the same stove and I got the LP Conversion Kit at Sears Part Direct.:
http://www.searspartsdirect.com
Thisis the Part Number for the LP conversion for the Jenn-Air CVG316B: Part# Y04100687
Hope that can help you
Eddie Rentas
Tupper Lake NY
Nov 21, 2007 | Jenn-Air Cooktops
Viking VGIC485-6G Gas Kitchen Range Logo
94 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
