Question about Black Widow Vehicle Parts & Accessories
I have a BW-852 keyless entry system installed in my '98 Mitsubishi Montero Sport XLS. The lock/unlock features work, but the 'panic' function (buttton 4) only works the lights - no sound from horn. Same to my lock/unlock - also no sound from horn. How could I wire the horn to working to the sytem?
  • nathanlegob Nov 16, 2009
    Thanks! Will work on tomorrow.
  • 2,359 Answers
Locate the BW-852 box,
Inspect the BROWN / WHITE wire.
Third wire on the large connector.
This is the HORN relay output wire.
In order for the horn to work,a relay must be install.
If there is a relay attached then check for contact sound (CLICK,CLICK.....CLICK) when the alarm is triggered.
Check in-line fuse protection
BW-852 installation file HERE
Download it for reference.
You should get a 30/40 amp 12 volt relay + socket to trigger the horn.
Connect brown / white wire to trigger pin on the relay.
Connect a RED wire + 5 amp fuse/fuse holder on the supply side of the relay
Connect the output lead the + side of the horn.
This is a nice 1 hour job for DIY'er.
Posted on Nov 16, 2009
Which fuse powers the power door locks on a 2012 equinox? None of the doors lock or unlock with the fob, battery ok
The Lock's lock from the door switches ? If they do it's not a fuse problem . Which of these does your vehicle have ?
Keyless Entry System Description and Operation (with Accessory 2 Way Remote)
Keyless Entry System Description and Operation (without Accessory 2 Way remote)
The keyless entry system is a vehicle entry device. The keyless entry system is used in conjunction with the body control module (BCM) to remotely activate certain vehicle features. Keyless entry will lock/unlock the doors/liftgate when a corresponding button on the keyless entry transmitter is pressed. This is accomplished by the transmitter sending a radio frequency to the remote control door lock receiver (RCDLR). The RCDLR interprets the signal and activates the requested function via a serial data message to the BCM. A low transmitter or vehicle battery or radio frequency (RF) interference from aftermarket devices, such as 2-way radios, power inverters, computers, etc., may cause a system malfunction. High RF traffic areas may also cause interference that could lead to a malfunction. Keyless entry allows you to operate the following components:
• Door locks
• Liftgate lock
• Vehicle locator/Panic alarm
• Illuminated entry lamps
• Remote vehicle start
The keyless entry system has the following components:
• Keyless entry transmitters
• Keyless entry antenna
• 2 Way Advanced Remote Start RCDLR
• BCM
Your best bet , take it to a GM dealer .
Jun 06, 2018 | Chevrolet Equinox Cars & Trucks
How do you reset the alarm system on a 98 olds silhouette after it triggers without the remote entry
Theft Deterrent Arm/Disarm Modes
Important: Although mode 2 provides increased security, the content theft deterrent system disarms only by pressing unlock on the keyless entry transmitter. This can pose a problem if the keyless entry transmitter is damaged, lost, or inoperative for any reason while you attempt to disarm the content theft deterrent system.
Mode 1: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter. The system does not arm when you lock the doors with a power door lock switch.
Mode 2: The system arms when you lock the doors with the keyless entry transmitter. The system disarms when you unlock the doors with the keyless entry transmitter. The system does not disarm when you unlock the doors with the key.
Mode 3: The system arms when you lock the doors using a power door lock switch or the keyless entry transmitter. The system disarms when you unlock the left front, right front, or liftgate door with the key or the keyless entry transmitter.
Changing the Feature Customization Modes
  1. Turn off the IP dimmer switch.
  2. Turn the ignition switch to the LOCK position.
  3. Remove the BCM PRGRM fuse.
  4. Turn the ignition switch to the ACC position. The BCM flashes the fasten belts indicator and sounds the chime 4 times, which indicates that BCM type 4 is installed on the vehicle. At this point, the BCM has entered the feature customization mode.
  5. In order to change the theft deterrent/shock sensor mode, turn the headlamp switch from OFF to PARK and back to OFF.
  6. The BCM flashes the fasten belts indicator and sounds the chime a number of times equivalent to the theft deterrent/shock sensor mode. A transition past mode 4 repeats the sequence starting with mode 1.
  7. Complete the following steps in order to change the theft deterrent arm/disarm mode:
6.1.
Insert the key in the left front, right front, or liftgate door lock cylinder.
6.2.
Rotate the key from the center to the unlock position.
6.3.
Press the horn button on the remote keyless entry transmitter.
6.4.
Count the number of chimes that you hear. The number of chimes tells you which mode you have set.
6.5.
Press the horn button again in order to change the mode. Continue to press the button until you hear the number of chimes that indicates the mode that you want.
6.6.
Turn the key back to the center position and remove the key from the door key cylinder.
In order to exit and save the current feature customization modes use the following procedure:
  1. Turn the ignition switch to the LOCK position.
  2. Reinstall the BCM PRGRM fuse.
If you are unable to change locking modes Theft Deterrent System Feature Customization Inoperative
Aug 25, 2015 | Cars & Trucks
My anti theft system is blinking and won't allow
the demobilized feature is activated, lock and unlock your keyless entry remote to deactivate the demobilized feature, then try cranking your truck again.
Sep 18, 2014 | 1999 Mitsubishi Montero Sport
2008 cadillac cts key fob not working
Testing would need to be done , scan tool hooked up checking DTC'S - diagnostic trouble codes . View data etc...
Keyless Entry System Description and Operation - Active
The keyless entry system is a vehicle entry device. The keyless entry system is used in conjunction with the door locks to unlock the vehicle. Keyless entry will lock/unlock a door or open the rear compartment lid when a corresponding button on the keyless entry transmitter is pressed. This is accomplished by the transmitter sending a radio frequency to the remote control door lock receiver (RCDLR). The RCDLR interprets the signal and activates the requested function via a serial data message. A low transmitter battery or radio frequency (RF) interference from aftermarket devices, such as 2-way radios, power inverters, computers, etc., may cause a system malfunction. High RF traffic areas, such as gas stations that use pay-at-the-pump RF transponders, may also cause interference that could lead to a malfunction. Keyless entry allows you to operate the following features:
• Door lock/unlock
• Rear compartment lid release
• Panic alarm/Vehicle locator
Your best bet , take it to a qualified repair shop . Dealer
Feb 18, 2018 | 2008 Cadillac Cts
2008 HHR Remote Starter not working
Is this an issue with all 2008 HHR remotes??? Highly doubtful , probably the vehicles keyless entry system . Taking the vehicle to a qualified repair shop an having the keyless entry system checked for DTC'S - diagnostic trouble code's . Do you know what a DTC is ?
The keyless entry system is a vehicle entry device. The keyless entry system is used in conjunction with the body control module (BCM) to remotely activate certain vehicle features. Keyless entry will lock/unlock the doors, or release the rear compartment lid when a corresponding button on the keyless entry transmitter is pressed. This is accomplished by the transmitter sending a radio frequency to the remote control door lock receiver (RCDLR). The RCDLR interprets the signal and activates the requested function via a serial data message to the BCM. A low transmitter or vehicle battery or radio frequency (RF) interference from aftermarket devices, such as 2-way radios, power inverters, computers, etc., may cause a system malfunction. High RF traffic areas may also cause interference that could lead to a malfunction. Keyless entry allows you to operate the following components:
• Door locks
• Liftgate lock
• Remote rear doors (Panel only)
• Vehicle locator/panic alarm
• BCM
Guessing will not fix this .
Jan 12, 2018 | 2006 Chevrolet HHR
2001 Mercury Villager keyless remote is malfunctioning
Keyless Entry
The keyless entry system consists of the following:
  • smart entry control(SEC)/timer module
  • keyless entry remote transmitters
  • power door lock actuators
  • body side door power door lock actuator
  • liftgate actuator
  • power door lock switches
  • door ajar switches
  • Principles of Operation
    All doors can be locked at once by turning the door key lock switch to the locked position. An individual door can be unlocked by moving the door key lock switch to the unlocked position and turning it again within five seconds; all the doors (including the liftgate) will unlock.
    The smart lock system is designed to keep the driver from locking his keys in the car. It will lock and then unlock all the doors if the smart entry control(SEC)/timer module detects the following conditions:
    • The ignition key still in the ignition.
    • A front door is open.
    • A door lock switch has been pushed to the lock position.
    The panic feature has a duration of 30 seconds from the last time the PANIC button is pressed. When locking the doors from the remote transmitter, the horn chirp/lamp flash feature can be disabled or enabled by holding the LOCK and UNLOCK buttons for two seconds. The hazards will flash three times to confirm that the feature has be enabled or disabled.
The control module probably see's an input that shouldn't be there . lock Switch , door ajar etc... Don't think it has anything to do with the remote . Some part stores have a tester to see if signal from the remote is working . Or the dealer ! Take it an see if your remote is sending a signal without you pressing any buttons .
If it is you need a new one .
May 19, 2017 | Cars & Trucks
Keyless entry does not work
I would suspect the remote is defective.
Jun 15, 2012 | 2000 Mitsubishi Montero Sport
Keyless remote entry does not function, panic button does.
This link will take you to very good instructions try it worked for me www.wikihow/program-a-keyless-entry-for-a-chevy-silverado this works on GMC models also.
Mar 30, 2009 | 1999 GMC Sierra
Vehicle Parts & Accessories Logo
66 people viewed this question
Top Black Widow Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Black Widow Vehicle Part and Accessory Expert? Answer questions, earn points and help others
