Question about AT&T Nokia 6555 Cell Phone - Black
Replace inside screen - AT&T Nokia 6555 Cell Phone - Black
Screen problems on my sylvania rear projection tv.....
If the lines are not actually in the picture but on the screen it may be if they are straight fine tape used around the inside edges of the screen---if in the actual picture a different story.
Aug 27, 2012 | Sylvania OSRAM RCA HDLP50W151YX4...
Can I replace inside screen of samsung plasma? IF not what is the cost to have repaired?
If inside screen has damaged, it will be best to buy a new TV, rather than try to replace it because 2/3rd price of the total cost of a Plasma TV is with its screen itself. Take a wise decision.
Aug 07, 2012 | Maxent MX-42HPM20 42 in. Plasma HDTV
How to replace LCD screen
To replace the the LCD screen of your laptop, You need to be very careful in replacing this screen. Please kindly follow the steps below to be able to guide You in replacing the screen.
  1. Shut down the Acer laptop, unplug the AC power adapter and all extensive devices.
  2. Remove the battery pack from the battery tray that is at the bottom of the screen.
  3. Open the display panel as far as You can open it.
  4. Pry the rubber screw covers from the display panel's front cover with a small, flat-head screwdriver.
  5. The front panel is the front plastic piece covering the LCD screen.
  6. Remove the Phillips-head screws fastening the front cover to the display panel.
  7. Remove the front cover from the laptop with your fingers.
  8. Remove the Phillips-head screws from each side of the LCD screen that fasten the screen to its metal frame inside the display panel.
  9. Tilt the screen forward, then disconnect the large ribbon cable from the connector on the back side of the screen.
  10. Peel away any tape securing the cable in place. Lift the screen out of the display panel.
  11. Place the new screen inside the display panel.
  12. Reconnect the LCD ribbon cable to the back of the new screen.
  13. Align the screw holes on each side of the screen with the screw holes on the metal framing inside the display panel.
  14. Replace the LCD screen's retaining screws.
  15. Replace the display panel's front cover, and its retaining Phillips-head screws.
  16. Then replace the rubber screw covers.
  17. Replace the battery pack, then reconnect all cables and devices to the laptop.
That is how to replace the screen of your phone.
Hope this was helpful. Thank You for using FixYa!!
Jan 12, 2011 | Acer Extensa 5620 Notebook PC
Need a replacement screen, its cracked any chance on getting a replacement, is it worth replacing?
Hey how are you!!!
What is your unit? If your unit is a laptop ou need to follow this.
You replaced the broken LCD screen in your laptop with a new screen. Does this sound like your problem? Let’s find out what could be wrong and how you can fix it.
First of all, I assume that your new LCD screen is compatible with the old one. Different screens require different video cables. Make sure you new screen is compatible with your laptop.
OK, let’s say you accidentally damaged the LCD screen in your laptop. A part of the screen still works fine but you cannot use it like that so you decided to replace the screen yourself.
Her is some instructions to follow.
Before you start to panic, check all cable connections again. Check connection between the video cable, LCD screen and inverter board. Reconnect cables just in case.
Take a closer look at the connection between the video cable and LCD screen. It’s possible you accidentally pulled the video cable from the connector during the screen installation.
The video cable has to be seated properly, all the way down.
Also, on some older LCD screens there are very thin pins inside the connector. Take a look inside the connector, make sure there are no damaged (bent) pins.
You can straighten bent pins with a very small screwdriver but this procedure requires a lot of patience and concentration.
Fortunately, most newer LCD's have a different type of connector, without fragile pins inside.
OK, you have reseated all connectors and cannot see anything wrong but the new screen still is not working. What’s next?
Remove the new screen and connect the old one. If the old one works properly (except the damaged area) but the new one is dead, apparently the new screen is defective and has to be replaced.
Hopefully it has warranty.
Here’s another scenario. The new screen kinda works. You can see a very faint image but there is no back light.
If that’s the case, disconnect the new screen from the inverter board and plug in the old screen instead, as it shown on the picture below. If the back light inside the old screen lights up, apparently the new screen has defective back light lamp and has to be replaced.
Good luck
ICmanServer
Aug 14, 2009 | Memorex MM7000
My screen is cracked only on the inside.  What is a reasonable price to have the inside screen replaced?
Hi
you have defective LCD this needs to replace. this is the links to help find the lcd,. clickhere
Thanks!
Jun 05, 2009 | HTC G1 Smartphone
I need replacement screens
the inside screens for this tv is screen assmbly rca part number 258513.. the outside plexi is known as the "supersheild" rca part number 258797
Apr 05, 2008 | RCA D52W19 52" Rear Projection Television
Crack inside of screen
This screen has multiple layers of plastic before you get to the main screen, if the picture isnt affected, you've only cracked oneof the plastic pieces, these are cheap to replace
Dec 31, 2007 | Philips 51PP9100D 51 in. Television
Screen looks melted in the inside
you have physically damaged the lcd screen inside. you must replace this, or get used to the screen being impeded visually
Oct 28, 2007 | Apple iPod nano
AT&T Nokia 6555 Cell Phone - Black Logo
50 people viewed this question
Top AT&T Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you an AT&T Cell Phone Expert? Answer questions, earn points and help others
