Question about KLH CDR2000 2-Disc CD Recorder
Invalid disc prompt,whenever i install a disc
I am trying to record using the inputs, but i keep geting the invalid disk prompt, also what is the recording process for this unit?
  • 103 Answers
This is a dedicated audio recorder. Therefore, you must use dedicated audio discs (not data discs). You can tell the difference as audio discs specify the recording time (usually 80mins) instead of data capacity (usually 700MB).
When you have the right disc inserted, press the record button & it will go into record standby, ready to record. First, set a level, then press record again, and you are recording.
Posted on Jan 09, 2008
Why when i power up i get a ,, missing operating syst
This issue may occur if one or more of the following conditions are true:
  • The basic input/output system (BIOS) does not detect the hard disk.
  • The hard disk is damaged.
  • Sector 0 of the physical hard disk drive has an incorrect or malformed master boot record (MBR).
Check your BIOS or System Setup to see if it detects your hard disk drive.
If it does see your hard disk drive then follow these instructions to fix your master boot record (MBR)
windows XP XP Repair or Fix Master Boot Record Using Recovery Console
windows 7
Step one: Turn your computer on, booting from either your Windows 7 Installation DVD or Windows 7 System Recovery Disc. Remember, you may need to change the boot order inside your BIOS to have the your DVD drive boot first.
Step two: After the installation or recovery disc loads, if prompted, select your language settings and then continue. If you are using the installation DVD, when prompted by the following screen select Repair your computer.
Step three: The computer will take a moment now to scan itself for any Windows installations, after which you will likely be given a choice to select which installation you wish to repair. Select the appropriate Windows installation from the list and then continue. If by chance a problem is detected in one of your Windows installations at this initial stage, the system may also ask you if it can try to repair the problem automatically. It is up to you if you wish to let the system try to repair itself, but otherwise just select No. Step four: Once you have reached the System Recovery Options screen, as shown below, you will be faced with a list of choices that can aid you in repairing a damaged Windows 7operating systemicon1.png. If you wish to try the Startup Repair option first, it is often successful in automatically fixing many different start up issues, but in this article we will be using the Command Prompt option to resolve our problems manually. So, click Command Prompt to continue. Step five: Now sitting at the command prompt, enter the following command and then press enter:
bootrec.exe /FixMbr
While the above command does fix the MBR, and sometimes that is enough, there still might be an error with the system partition's boot sector and Boot Configuration Data (BCD). This might occur if you have tried to install another operating system alongside Windows 7, such as Windows XP. To write a new boot sector, try the following command: bootrec.exe /FixBoot
hope that helps
Aug 11, 2014 | Computers & Internet
Will not record and also keep geting error nodisk
Did you try a disc cleaner? Maybe the lens is just dirty.
Jan 03, 2008 | Televison & Video
How can I record TV on my laptop?
Step 1:
b> While TiVo and other devices allow users to record and play back their favorite TV shows and movies whenever they want, those who watch television on their laptops have been forced to rely upon a number of different Internet websites that host movies and television shows. Fortunately, hardware and software now exists that allows laptop users to record TV shows directly onto their laptops and replay them whenever they like. All they need is an open USB port.
Connect the USB TV tuner to the laptop using a free USB port. Connect the cable wire to the USB tuner's cable input. Insert the TV tuner's installation disk into the laptop and follow the on screen directions to install the appropriate drivers and software. When prompted by Windows, select "install software automatically" to install the device drives. When prompted by the WinTV software to choose which programs to install, ensure that the option for the WinTV scheduler is checked. Launch the WinTV 2000 software now installed on the laptop. Press the "scan" button to load all of the available television channels. The channels that the tuner is able to locate will be displayed in the bottom half of the screen. Press "close" when the scan is complete. The amount of time to complete this step will vary depending on the number of channels being added. Choose a channel to record using the channel selection buttons on the left hand side of the on screen menu now displayed. Press the "record" button located on the bottom of the screen to record the program current displayed on the screen. Alternatively, recording can be scheduled using the WinTV Scheduler software included in the WinTV installation package. From the WinTV Scheduler main window, press "add program". Next, enter the time and date in addition to the channel to be recorded. Finally, click "save program". While recording TV on the laptop is not nearly as straightforward as it is with Tivo and other similar devices, the above methods are both reliable and relatively intuitive.
Feb 15, 2013 | Computers & Internet
Invalid disc reading
I find that I get the Invalid disk message most likely when I use a DVD-R disk. So now I use only DVD+R for this machine. I have also read somewhere that the problem could be solved by using a Laser Lens Cleaner Cleaning disk.
Sep 15, 2011 | Lite On LVC-9016G DVD Recorder/VCR
My ilo dvd R/P will not record and keeps saying invalid disk,
Mar 08, 2010 | iLO DVDR04
Recorder fails during 92% finalizing.
The free CDBurnerXP Pro is supposedly able to close unclosed disks, but I have never figured out how to do it. Maybe you'll be luckier than me or the newer version is more user friendly.
Sep 16, 2009 | Lite On LVW-1107HC1 DVD Recorder
Recording Fall, Invalid disk
Try using Sony +R discs. or +RW's are good, any brand as long as they are +'s. For some reason alot of +R discs brands will not work, I wait and just get Sony +R or the +RW's on sale and stock up and I have no more troubles. Mine is the 05MU. The ZU is a little strange with the RW but will still record. Hope this helps.
Sep 24, 2008 | iLO DVD Recorder DVDR05
Error message: Can not record on this disk???
In many devices, DVD-R and/or DVD-RW discs do not work. You must use DVD+R or DVD+RW discs. Good luck!
May 20, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Invalid disk
I contacted Gateway and found out that the AR-230 will not work with anything more than 4x DVD's. Usually it will format DVD-RW's but avoid memorex brand. Usually any other cheep brand will work.
May 04, 2008 | Gateway AR-230 DVD Recorder
KLH CDR2000 2-Disc CD Recorder Logo
261 people viewed this question
Top KLH Audio Players & Recorders Experts
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
