Question about Sony PlayStation 2 (PS2) Console
Ps2 is on but won't reconize there is a disc in the console and will not spin the disc to play.
Cerfer39
  • 709 Answers
SOURCE: Disc does not turn
Hi Brad1Christy,
The laser is either dirty or burned out. When the disc does not spin, it usually is because the controller does not see any initial data coming from the laser. Clean your laser and see if you get any response.
Posted on Nov 17, 2007
Cerfer39
  • 709 Answers
SOURCE: Disc won't spin. Disc doesn't show up in browser
You got a problem with the lasers data getting back to the Motherboard.
One of these could be your problem
  1. Laser lens is melted. Look at the lens with a magnifying glass to see if it or its supporting frame is melted. REplace the laser in this case.
  2. The ribbon Cable going from the Laser to the motherboard is damaged or loose.
  3. Your laser is burned out. Press the two interlock to override the door being open, to see if the laser even lights up. 2 switches, one at rear left corner, one behind the On/reset switch.
  4. Your Laser is dirty and needs cleaning look at it with a magnifying Glass to make sure you got it clean. Use Q-tip and window glass cleaner, not alcohol.
Posted on Nov 25, 2007
SOURCE: Ps2 slim won't start, plays intro sound and TV screen goes blank
try on other tv
Posted on Jun 07, 2008
FixMyConsole
  • 174 Answers
SOURCE: PS2 slim- Disc not spinning
definately the laser has died.
Give us a shout if you need any help.
FixMyConsole
Posted on May 24, 2009
SOURCE: PS2 was dropped, now disc won't spin and can't be read.
I just looked at a friend's PS2. Same story, tripped over cord, unit fell to floor. Unit powers up and sys. config. screen comes on but the drive didn't seem to be spinning up. Opened the case and found that the shaft of the drive motor for the laser tray had popped out of it's centering retainer ( little black bushing/holder). With the top off the unit, looking at the unit from the front, on the right side in the rear corner you'll see the motor. The worm shaft (bronze colored rod) runs towards the front of the unit. Where it ends it should sit centered in a black plastic holder, if it's off to the side a little pressure will pop it back in. Put the cover back on, and power it up, you should hear the drive spinning up. If it does you should be set. Hope this helps.
Posted on Jun 02, 2009
Ps2 Disc won't respond to a Ps3 when inserted.
Only the first version of the PS3 had PS2 backwards compatibility, They did make a special edition Metal Gear Solid version with it included but other than that no other PS3 will play PS2 discs... No matter what Add-On you install.
Oct 07, 2012 | Sony PlayStation 2 (PS2) Console
American disc won`t play on my ps2 console in the uk all i get is please insert disc
if your ps2 is not a modded one sorry to tell you but yours is a pal ps2 (means you live somewhere in asia europe)so there is some difference i the american ps2 disc(ntsc) and pal ps2 disc both are designed to play in specific consoles so if you bought they console from ntsc territory(japan ,north america) it should work for sure but sometimes in japan and all they sell pals also but there is still chance try returning the cd to the shop and buy a pal disc or you can mod your ps2 from ps2 technicians (they are all around the world,every console shop has one) and then you can play american disc this is the only chance it will only take a small 25 bucks from you just mod it and u can play games u burned from your computer and also any pal ,ntsc territory original discs also
Dec 25, 2009 | Sony PlayStation 2 Slimline Console
How to fix my playstation 2 that won t read grand theft auto san adreas
Your console is an old one,and your lens too is probably weak.Try cleaning your PS2 lens Watch Video at end of solution to clean your PS2 at home....
You can also follow these steps to make your PS2 to play GTA San Andreas:
  1. Turn on your PS2 without inserting any disc.
  2. On menu screen go to [options] by pressing 'triangle' button.
  3. A new screen will appear select by pressing 'X' [DISC SPEED]and set it to [FAST]
  4. Then insert the game disc.
  5. Turn off your PS2.
  6. Press and Hold the [Reset Button] till the blue light turns on.Release the Reset button and press it again.
It will take a bit more time to play game,but first i recommend you to clean your PS2 lens,watch this video.
I've got something else to add.......you can follow above steps to play DVD movies if your PS2 dont play any.....!!!
Nov 19, 2009 | Sony PlayStation 2 (PS2) Console
My slimeline PS2 wont spin discs
you need to open your ps2 and fix the disc spinner.
Aug 12, 2009 | Sony PlayStation 2 (PS2) Console
The ps2 has trouble spinning and reading disc.
it means your playnstation lenses have a problem
Jun 15, 2009 | Sony PlayStation 2 Slimline Console
Disc won't spin so I can't play the game/DVD/CD
replace the motor. The motor has burned out causing the disc not to spin.
Jan 20, 2009 | Sony PlayStation 2 (PS2) Console
PS2 won't work at all
The laser or main power unit might of died i would just go buy a new one there not that much and these problems will probaly run u more than the new one.
Jan 12, 2009 | Sony PlayStation 2 (PS2) Console
Disc read error
get it repaired. obviously the drive is not spinning correctly for ps2 disc. so take it to a shop ask for a quote to repair.
most ps2 are about $99.00USD
Jun 07, 2008 | Sony PlayStation 2 (PS2) Console
Sony PS2 station wont play
check the disc again, make sure is in.
Jan 01, 2008 | Sony PlayStation 2 (PS2) Console
Disc won't spin,
If your PS2 slim console is chipped for playing fake games then try it by replacing the modification IC otherwise replace the lens with new one and your problem should be solved.
Aug 21, 2007 | Sony PlayStation 2 Slimline Console
Sony PlayStation 2 (PS2) Console Logo
64 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
